ran at the track
Old Nov 28, 2005 | 12:34 PM
95turbo gxe's Avatar
ran at the track
I ran at the track on saturday and I had the street z tires and rims on the front. I did my previous best time on 10psi with no cams or head work. I ran almost a whole second slower than my previous time. I made my pass at 9psi with the head work and the cams.But due to spinning it was worst. When i shifted to 3rd gear they starting spinning bad. My 1/8 was like a 9.5 but yet the 1/4 time was like 14.2. Well I know that im making more power at 9psi with a very rich air/fuel ratio. I could not get a kock level over 18 at the track ....thats very rich to me. The plugs are black. But yet the tires would cut loose in third. So I need tires and a tune before i will return to the track. oh yeah trying to launch at 2400 rpms my 60ft was like 2.4
Old Nov 28, 2005 | 03:44 PM
maxmaxima91's Avatar
what was your trap speed?
Old Nov 28, 2005 | 03:53 PM
104.1 mph . My highest before was like 105. i ran that with 11psi with no head work or cams though.
Old Dec 1, 2005 | 08:23 PM
does anyone know why my trap was down?
Old Dec 2, 2005 | 01:31 AM
Nealoc187's Avatar
SLOW
It's because you're not making the power you think you should be. Trap speed is a direct result of the power your car is putting out and how much your car weighs. What does your dyno look like? Do you have a scan of it we can see?
Old Dec 2, 2005 | 06:14 AM
cardana24's Avatar
Blown
also if you spin a lot your trap speed will be higher...its kinda like getting a running start, because once you finally do hook up your car will 'take off'. This is all assuming you stay in it when you are spinning. your e.t.'s will get higher but your trap speed goes up.
Old Dec 2, 2005 | 07:31 AM
only the old dyno sheat ......before 240ish hp and 340 torque
I dont know why I was thinking 260 it was 232.5
Old Dec 2, 2005 | 08:10 AM
C MAX's Avatar
with your trap speeds you should of run at least a 13.5 with proper traction.
Old Dec 2, 2005 | 08:24 AM
Maxpwer's Avatar
No turbo, no care!
Do you have a LSD
Old Dec 2, 2005 | 08:28 AM
Originally Posted by Maxpwer
Do you have a LSD
yes the 3rd gen ve 5speed tranny witch has a lsd .Dont work that great though
Old Dec 2, 2005 | 09:06 AM
cardana24's Avatar
Blown
Originally Posted by 93turbo gxe
only the old dyno sheat ......before 260hp and 340 torque
thats a really strange turbo dyno....the numbers you got look more like the results from a 100 shot, are you sure the dyno was right. Normally with turbo maxima's they are pretty close to hp=tq
Old Dec 2, 2005 | 10:52 AM
mtcookson's Avatar
He has a VG engine which are very torquey motors. Their dynos tend to look like that until they start making some pretty high hp numbers.
Old Dec 2, 2005 | 10:57 AM
Nealoc187's Avatar
SLOW
Boost spikes will do that, and cars that just don't flow as well up top, VGs are an engine that doesn't flow that great I think, I know he has ported heads and what not, but I don't know who ported them. It's possible to port heads and have them be worse than they were originally. Just a possibility. Without a flowbench or a conclusive before/after dyno or consistent track times both before and after the mod, it's hard to tell what a mod did and whether the results were positive or negative. Unfortunately how it "feels" is often a result of placebo effect.
Old Dec 2, 2005 | 12:48 PM
hey guys I have not redynoed since the cams and ported heads. That dyno was with Stock heads and stock cams. But at 10 psi back then the tires would not start roasting in the top of second gear like they will now. and they even spin when you shift from2nd to 3rd for a breif second. Thats why I thought that I may would have more power at the same boost level(10 psi) thats why I was wondering why my trap was down at the track
Old Dec 2, 2005 | 01:32 PM
Different weather conditions can contribute to that greatly, as can a tougher clutch. and didnt you have drag radials on last time you ran the track.
Jeremy
Old Dec 2, 2005 | 03:30 PM
[QUOTE=maxmaxima91]Different weather conditions can contribute to that greatly, as can a tougher clutch. and didnt you have drag radials on last time you ran the track.
Jeremy[/QUOTNo I had full street tires on the last time and before thehead work and cams when I ran my best time i had street tires on and heavy crome wheels.
Old Dec 2, 2005 | 04:56 PM
hmm.. sounds like something is keeping your from makeing the power you think you should be then.. What size turbo do you have? and how much power are you trying to push out of it? Also is there anything else in your setup that you think could be limiting your performace?
Jeremy
Old Dec 2, 2005 | 09:11 PM
Jeremy
well I was just at least trying to match my results from before the heads and cams. The cams are claimed to make 25whp alone. Yes im running rich but I was thinking with the head being ported, intake manifolds being ported and thes e cams should have put me where I was before.
ok got a Stock ct26 I ran my best time on 11psi with stock heads and cams and I ran the other week at 9psi. Dam what a differance!Not unless me being so rich is holding back that much power? I did not think that it would be no 30 hp I guess I need to get on the dyno and see what up at 10 psi like I dyno before the work!
Old Dec 2, 2005 | 09:55 PM
This is the dyno I did on stock heads and cams At 10psi That I ran my best trap of 105 on. the rpms are off just a bit. The dyno was fine and I talked to locals and they daid its a good working dyno. Their was A guy with a ford focus that dyno right after me and he said that is was right on cue with his previous dyno the week before. Org member BLU may came chime in on this and let you know about this dyno. I started at 2000 rpms and ran it up to 4000rpms the graph show me to stop at about 4200 to 4400
Old Dec 5, 2005 | 02:24 PM
Boosted Maxima's Avatar
You realy need to get a wideband in the car and get your AFR's right. "RICH" or thinking your rich isn't going to get you anywhere. You'll need the wideband and
the correct O2's to shoot for at WOT and all other loads. That upper plenum is also unballanced along with the pipe leading to it. I almost did cams like you did but decided to stay stock being that my Maxima is realy my winter beater.
Before and after head work/cams all comes down to tune at this point. Since you don't know your AFR's before and still don't know your AFR's now there's no place to start!
Information is critical to tune and power. That's why some guys with all stock parts or little money are running quicker times and mph than those with big money in there cars. All the money and parts in the world won't fix a tune problem.
~Scott
Old Dec 5, 2005 | 03:32 PM
~Scott
yeah Im hunting a wideband now hoping to get one by xmas. Oh yeah the ecu got shipped today look for it soon
Old Dec 16, 2005 | 02:48 PM
twinturbozs's Avatar
You might want to try to reset your ecu first. If you had detonation the ecu might might have retarded the timing.
Old Dec 17, 2005 | 12:47 PM
Brad92SE's Avatar
I was just wondering, are you sure that dyno is right? From the sheet is says that your torque is peaking at around 2600 rpm, that looks more like a v8 dyno. It also stops at 4200rpm, did you let off? Maybe I'm just missing something.
Old Dec 17, 2005 | 01:32 PM
the rpms are off and I did infact let off around 4200.Im going to get it redone soon thin we will see again
mkaresh
Mar 12, 2018 06:48 PM
jonreidhead
Jan 6, 2016 09:38 AM
salty318
Sep 29, 2015 01:21 PM
