Pic of reclocked blower and 3" piping.
Originally Posted by IceY2K1
Even bigger then the 50mm Tial?
Originally Posted by matty
Stephen,
Does the Mondo Vent air at idle ?? How tight do you keep the mondo. ?? Looks like i may need to upgrade to a mondo.
-matt
-matt
I have the preload spring on my Mondo set to give just enough air release under vacuum to prevent surging during cruising. You have to experiment.
Originally Posted by Stephen Max
It's about the same. I like the Tial better, though. It sounds better (quieter) when releasing high pressure air between shifts, and it looks really nice. It also has a V-band clamp with the flange.
Originally Posted by VQ30DENX_SC
Question: When you buy this piece:
how did you mount the SSQV on i? screws in? bolts in? welds in?
I broke a set of pliers on that damned snap ring.
Ended up taking it down to the local shop and having them do it.
At least they were cool and didn't charge me.
Damn snap rings. Of all the **** I went through with my TC install the damn little snap ring on my HKS SSQV was one of the most PITA things. Spent a while night on it and spent like $50 in different pliers
LMAOOOOOOOOOO, what exactly is a snap ring? A rubber piece of some sort that wedges and creates an air tight seal around the flange?
Thanks guys. Good info. I will need this 3" pipe with setup you're selling? I know I asked about the BOV assembly, but I'm asking about the actual 3'" pipe its on.
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
bigfrank
Oct 1, 2015 12:51 PM
