Squeeling at startup with loss of power steering?
Hey guys,
My maxima has a supercharger and when i start it sometimes it will squeel for awhile and i will loose my power steering for say 30secs. Does this have anything to do with the belt on the supercharger and should i have it replaced? Flame on if needed.
You may need to tighten it. Last winter, mine squealed like that. Jack the car up and see of you can twist it more than 180 degrees on the segement that is next to the oil pan. If so, tighten it up.
Originally Posted by Mymax97
What IT am i looking to twist the belt?
Do you know how to tighten the belt? Which kit do you have? V1 or V2
You have air in the Power Steering lines. Jack the front of the car up, remove the PS fluid resivor lid and top off. Turn the wheel lock to lock very slowly 10 or so times with the moror off. Then crank it up and repeat with the motor running. That should take care of it.
Choray
Choray
lowpost99
Oct 26, 2025 06:53 PM
rbarnes
Dec 31, 2015 06:29 PM
fastcarny
Oct 12, 2015 07:06 AM
ColdCananda
Sep 20, 2015 10:45 PM
