Emange Ultimate can advance timing...
Old Feb 5, 2006 | 02:57 PM
Kevlo911's Avatar
Kevlo for President
EU can advance and retard timing w/o the crank signal...
How do I know? I had my buddy Jeremy test it on his. The rpms go down when you retard and the rpms go up when you advance.
Old Feb 5, 2006 | 04:29 PM
Kevlo911's Avatar
Kevlo for President
Tomorrow, revlimit
Old Feb 5, 2006 | 05:21 PM
Nealoc187's Avatar
SLOW
Test the two step for me. I know there's no reason it shouldn't work, but I just want to know someone's done it.
Old Feb 5, 2006 | 05:25 PM
DandyMax's Avatar
3.5 in the works
Which rpm source is he using... ign or tach?
Old Feb 5, 2006 | 05:30 PM
Kevlo911's Avatar
Kevlo for President
What is the two step?
IGN for rpm source.
Well rev limit shouldnt work w/o the crank or cam signal. I believe the EU will need real RPM source so it can past the stock revlimit, so it can continue to fire the coils and injectors. I still havent figured out the injector hold times and stuff either. Will do all that tomorrow or later in the week.
Old Feb 5, 2006 | 05:42 PM
DandyMax's Avatar
3.5 in the works
Two step is the launch control (two step rev limit).
See this is puzzling me... I had absolutely no fluctuation in idle speed playing with timing that way using ign inputs. Unless the 4th gen ECU maintains idle speed using the IACV somehow... Until I can get on a dyno in the spring I'm not going to assume that timing advance works for sure. It may, but I'm not 100% convinced.
But yet Icey seems to have gotten the rev limit working on his 5th gen...
I'm still wondering if my unit is actually working properly on my 4th gen (the ignition parts anyways...)
I dunno.. I'd rather just get the crank signal working and erase all the uncertainties with the tach/ign methods.
Old Feb 6, 2006 | 09:27 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Was this on a 4th gen Kevlo?
Old Feb 6, 2006 | 09:32 AM
IceY2K1's Avatar
Idle is controlled via timing, IACV, etc. and the ECU is constantly controlling it to the target RPM.
I'm not saying you couldn't cause a quick blip in RPM by changing the timing value of a cell, however does the EU allow "on-the-fly" fuel/timing changes in the maps? I didn't think so.
Old Feb 6, 2006 | 11:18 AM
DandyMax's Avatar
3.5 in the works
Ice, Kev is referring to jeremykedel's car.. so 5th gen.
And yeah I wasn't clear, but that was my point that perhaps since my ECU is controlling idle speed to the target value I wasn't able to discern any real change in rpm that I could conclusively say was due to changing timing in the map. A fair amount of rpm fluctuation can be seen just in the normal reading from the CPS using a fast sampling scanner like the Consult clone I have. Ideally I'd like to verify this kind of thing using a dyno.
I believe anything you change in the EU map is applied in real time as long as the laptop is plugged in and communicating (ie - in online mode). So it might be possible to get a blip but you'd have to be sure it was only caused by the timing change, nothing else.
Old Feb 6, 2006 | 11:34 AM
turbo97SE's Avatar
Looks very kludged! Put a timing light on there. How can you use IGN as TACH source? ECU would be advancing and retarding. I would say this is not very reliable. Only way is to go off cam and crank signals. Even going off a tach is risky. Retard might be OK for these piggybacks, advance? .... hmmm.
Old Feb 6, 2006 | 11:44 AM
IceY2K1's Avatar
The EU is guessing based off previous ignition events to advance.
We all agree, the crank/cam is far better, but with Greddy who knows when it could be fixed.
Old Feb 6, 2006 | 11:57 AM
Nealoc187's Avatar
SLOW
Do any of you guys have an OBD-II reader that you could hook up to see directly if timing is indeed changing like you want it to?
Old Feb 6, 2006 | 12:00 PM
IceY2K1's Avatar
Since the EU intercepts the output of the stock ECU, ie signal to coil, the OBD scanner won't show any changes per DandyMax insight.
Old Feb 6, 2006 | 12:15 PM
maximariceboi's Avatar
go back to school and stop messing with cars or put my 00vi on =]
Old Feb 6, 2006 | 12:52 PM
DandyMax's Avatar
3.5 in the works
Timing light would be another way of checking yes. Maybe I'll dig my old one out and fix it come spring.
But at this point I'm just staying focused on getting the crank signal working. It's a slow process with Greddy.. they are so extremely busy and hard to get a hold of and get information as to exactly where things are at but I'm keeping on it.
Old Feb 6, 2006 | 01:04 PM
Kevlo911's Avatar
Kevlo for President
I dont see why the idle would only changed when we messed with timing other than the timing.
This is how we found out the timing worked on the SMT
Retard 5 degrees and watch the idle go down, advance 15 degrees and watch it go up. Go back to 0 and it goes down, go up 5 and the idle goes up.
Old Feb 6, 2006 | 01:11 PM
DandyMax's Avatar
3.5 in the works
Watched it how.. on the tach? With a scanner? How much variation in rpms per degree of retard/advance?
Old Feb 6, 2006 | 02:46 PM
Kevlo911's Avatar
Kevlo for President
10 degrees did about 150rpms. 5 did 75-100.
Old Feb 6, 2006 | 02:48 PM
Kevlo911's Avatar
Kevlo for President
I believed he logged it too so you can watch the log files..
Old Feb 6, 2006 | 04:11 PM
Nealoc187's Avatar
SLOW
Would the same thing then apply to those using SAFC and emanage blue? I ask because MikeD is getting auterra and we had planned on using it on both of our cars to log timing. He has SAFC-II and thus may be affecting timing a little bit with his fuel adjustments, and I'm using blue and adjusting timing with that.
Old Feb 6, 2006 | 04:22 PM
SPiG's Avatar
SomePsychoGuy
SAFC would show up since it alters MAF readings and the ECU will actually change the timing itself.
From what I understand Emanage changes will not show up since it somewhat bypasses the ECU and either retards or advances.
Old Feb 6, 2006 | 04:48 PM
IceY2K1's Avatar
No, on the SAFC and yes on the emanage blue, since IIRC the blue intercepts the ECU->coil wires, correct?
Old Feb 6, 2006 | 07:13 PM
jeremykedel's Avatar
The EU definitely intercepts the wires, it seems to work on my car ,I adjusted the timing +15,+10,+5,0,-5,-10,-15 and it changed everytime.Was idling at 750 to start with, the went to 900,850,800,750,700 so on and so forth.It definitely seems to work i will datalog it again my laptopp took a crap on me.Then i will post the log.I should have it fixed tomorrow.
Old Feb 6, 2006 | 11:04 PM
turbo97SE's Avatar
Apprarently, datalogging and scanning with a scan tool is easier than getting a timing light and looking under the hood?
Old Feb 6, 2006 | 11:07 PM
Nealoc187's Avatar
SLOW
It is when you are talking about WOT, and it is when you have a scan tool but you don't have a timing light...
Old Feb 7, 2006 | 09:03 AM
DandyMax's Avatar
3.5 in the works
Well I guess come spring I'll have to go over everything again with a fine-tooth comb and try to figure out why this did not seem to happen on my car.
Better yet to have the crank pickup working and make this all a thing of the past.
Old Feb 7, 2006 | 04:05 PM
turbo97SE's Avatar
mmm ... when you are pulling OBD II port information, that gives you stock timing not actual timing especially if you are offsetting with the EMU. I know this because when i hook up to my OBD II port, it shows me what it thinks is the timing and I know for sure (with a timing light) and my AEM that it is not at that timing. I don't know of a lot of people who measure timing at WOT with a timing light, first step would be to measure timing at idle and see how much it advances to see if your +5 degrees or whatever match what your timing light is giving you. Yes, you may think the timing advances and retards by listening to the revs go up and down, but how much are you really advancing/retarding? It's like cooking beef. you know turning the heat up cooks faster, turning it down, it cooks slower ... but how do you know if it is cooked right ... by smell? you need to use the right tools or you will end up with beef jerky for a motor!
That is my only beef!
Geez all this talk of food is making me hungry.
Old Feb 7, 2006 | 04:52 PM
Nealoc187's Avatar
SLOW
Yep I know that now based on the response icey2k1 gave me earlier in the thread. I didn't know emanage changes wouldn't show up on OBD-2 scanners thus my suggestion to use one earlier.
Old Feb 8, 2006 | 08:17 AM
IceY2K1's Avatar
Any luck?..........
Originally Posted by Kevlo911
Tomorrow, revlimit
Old Feb 8, 2006 | 09:48 AM
DandyMax's Avatar
3.5 in the works
I think Jeremy's laptop crapped out on him so it might be a while before he can try it...
Old Feb 8, 2006 | 11:54 AM
matty's Avatar
I would really like to know if advance timing and retard timing works so I can order this already.... I spoke with jeremy yesterday and he said most likely we'll need the crank signal to use rev limit.
-matt
Old Feb 8, 2006 | 12:25 PM
IceY2K1's Avatar
http://forums.maxima.org/showthread....ht=Rev+limiter
Did you miss this thread matty? Why are you concerned about advancing timing on your SC'd stock ECU car?
I've already shown the Rev-Limiter works to at least 6800rpm. Going further is simple, but simply hasn't been logged. There is more evidence showing it does work, then doesn't. Retarding timing is proven to work on the Blue Emanage and from my tests, it appears to still.
You don't NEED the crank input, it would just make things easier/simpler along with a change in Greddys' RLC map fueling logic.
Old Feb 9, 2006 | 08:38 AM
Kevlo911's Avatar
Kevlo for President
My buddy Jeremy talked to Kenji and he said it will be about 1-2 months on the Crank board from Greddy.
Old Feb 9, 2006 | 08:44 AM
IceY2K1's Avatar
That's at least a year in reality then.
Old Feb 9, 2006 | 10:11 AM
DandyMax's Avatar
3.5 in the works
Bugger. How did he get a hold of him? I've been trying to for awhile now...
Old Feb 9, 2006 | 10:23 AM
IceY2K1's Avatar
Same game TS plays Dandy....
They don't have anymore answers/updates to give, so they avoid the guys hounding them and toss BS to everyone else.
I hope Greddy comes through, but I wouldn't hold your breath anytime soon guys. Buy the EU for what it does now or don't buy it at all unless you feel like leaving your engine management up in the air.
I let TS lead me on for over 2yrs. plus I spent money on spare ECUs to end up getting no where.
Old Feb 9, 2006 | 11:14 AM
DandyMax's Avatar
3.5 in the works
Ya I hear you.. but at this point I still believe the update is in the works.
Your TS experience sounds like a real nightmare, sorry to hear that.
I can't speak for anyone else but when I bought the EU it was worth it enough to me even for its current capabilities, but I was also looking ahead to the VQ35 swap. It already works on the VQ35 so I knew I could re-use it when I did the swap.
Old Feb 9, 2006 | 11:32 AM
IceY2K1's Avatar
You sure about the VQ35? I thought SR or someone said the CPS between the FWD and RWD were different.
TS pretty much finished the ECU, but decided it wasn't worth their time to sell for such a small 2001 market even with 20 or so tenative cash-n-hand orders. IMO, Greddy may find that what the module costs to make wouldn't be marketable.
Anyways, you just make sure you get yourself and I one, so we don't get left out.
Ya I hear you.. but at this point I still believe the update is in the works. What I take with a LARGE grain of salt is the timelines they give... haha. And I do have a backup plan to put more pressure on them if I find I'm getting nowhere and another six months go by.
Old Feb 9, 2006 | 11:36 AM
SPiG's Avatar
SomePsychoGuy
I just don't understand why we need a seperate box. Couldn't they just add it to the current software or just split up the firmware like for some engines have this one and other ones have this one if they were running out of space.
Old Feb 9, 2006 | 11:47 AM
DandyMax's Avatar
3.5 in the works
Hehe I will do everything in my power, and like I said, I do have a backup plan or two.
And yes I am 100% sure about the FWD VQ35. I have been talking off and on for a while with someone who's using it (crank signal and all) on an 04 (03 made) Altima.
