Where can I get this? What is this called? Cost?
Old Mar 20, 2006 | 10:53 AM
VQ30DENX_SC's Avatar
Please help me identify what this is for a friend. His max is turbo and this piece circled is leaking. I it is for extra injectors. Part of the fuel system.
Thanks. Where can he get it replaced and how much does it cost?
Old Mar 20, 2006 | 11:04 AM
Nealoc187's Avatar
SLOW
That is a banjo fitting. Probably get it at any auto parts store, not really sure because I've never looked for one. It's the same type of fitting our brake lines use to connect to the caliper, so auto store is a likely place. Maybe a hardware store too. Cost: cheap, few dollars probably. Could be the washers leaking (fitting itself could be fine) or the banjo bolt stripped some how and leaking. Better take it apart and inspect it, or just buy an entire new fitting, bolt, and washers and replace 'em all.
Old Mar 20, 2006 | 02:07 PM
RA030726's Avatar
I'm nutty for Nissans
if the banjo fitting is indeed bad you need to replace the whole length of hose.
Old Mar 27, 2006 | 08:50 PM
96_vqmax's Avatar
And you sure that's not for a pic for honda,and it's for the Nissan?Most of the time it's the washer,or maybe the thread on the bolt and the filter itself is strip like other was saying.
Old Mar 31, 2006 | 08:54 PM
crewchief264's Avatar
YOu should have an fitting/hose builder in your area, they build hoses for forklifts,tractors, heavy equipment etccc... I would ask aorund in some cat/yale sale/service places-johndeere etc
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
bigfrank
Oct 1, 2015 12:51 PM
Noela
Sep 26, 2015 08:22 AM
