Track Results 4/8
Old Apr 8, 2006 | 06:30 PM
I30tMikeD's Avatar
Track Results 4/8
Finally hit my goal of 12's. Car is not as fast as I think it should be, but I am happy to finally get some decent ET's. Car still has more in her at this boost level though.
Stock motor and trans
T4/To4E 46 trim
10psi
MEVI
3" cut out
104 octane
Byron Dragway. Sunny and 50 degrees
Street tires
60' 2.322
1/8 9.105
mph 87.82
1/4 13.57
mph 112.34
60' 2.29
1/8 8.99
mph 89.19
1/4 13.51
mph 111.31
ET Streets 26x10.5
60' 2.067
1/8 8.648
mph 87.22
1/4 13.076
mph 111.06
60' 2.085
1/8 8.572
mph 88.87
1/4 12.977
mph 106.8 (lifted in 4th)
60' 2.073
1/8 8.574
mph 88.34
1/4 12.971
mph 111.54
Still not too good with the slicks, but I am getting there. I am about at the limit of this clutch. If I did more than two runs back to back I would get some slipping in 3rd and 4th. But it held on the launches.
Old Apr 8, 2006 | 06:37 PM
MardiGrasMax's Avatar
111-112 mph is purty good. Till you pull 1.9 or 1.8 60's you holding back. Drop the pressure to in the slicks to 12psi hot, burn them down in 2nd gear, rev to 6k and quick release. Scary at first, but its addicting.
Old Apr 8, 2006 | 06:49 PM
Nismo3112's Avatar
Custom User Title
Nice job.. Your car is
Old Apr 8, 2006 | 07:44 PM
Tatanko's Avatar
Bacon Lover
So if that's not good enough, what ARE you shooting for?
Old Apr 8, 2006 | 08:03 PM
JeEvE's Avatar
Congrats on hitting 12s. How were you launching on the ET Streets?
Old Apr 8, 2006 | 08:11 PM
Bags's Avatar
VG Ridah's Biatch Hoe
good deal... 112 is moving
Old Apr 8, 2006 | 08:19 PM
Nealoc187's Avatar
SLOW
With those traps his car has a 12.5-12.6 in it, but his clutch isn't going to allow that.
Old Apr 8, 2006 | 08:47 PM
matty's Avatar
Mike,
I thought you were runnin the Clutchnet 6 puck clutch. Your at the limit of that ??
-matt
Old Apr 8, 2006 | 09:04 PM
Nealoc187's Avatar
SLOW
That is what he's running.
BTW I think his car has another couple MPH in it with a launch that isn't a bad bog or a massive spin like all his launches today were.
Old Apr 8, 2006 | 10:50 PM
maxmaxima91's Avatar
I was also with mike today...
Origonal Stock Engine + Trans @ 184k miles
T04B 1.32A/R
13 psi
Full Exhaust
93 octane
Sumitomo HTR+'s (street tires)
3300 lbs
2 valves
3rd best
60" 2.342
330" 6.045
1/8 8.941
mph 86.48
1/4 13.448
mph 110.00
2nd best
60" 2.350
330" 6.015
1/8 8.885
mph 87.54
1/4 13.368
mph 110.41
Best
60" 2.285
330" 5.945
1/8 8.822
mph 87.10
1/4 13.331
mph 109.59
Im rather happy... Actually went faster than i thought i would...
Old Apr 8, 2006 | 11:44 PM
96_vqmax's Avatar
WOW congrats Mike,you break into 12's with just 10psi,that's awesome.
Old Apr 8, 2006 | 11:46 PM
I30tMikeD's Avatar
After my last dyno I was really expecting/hoping more like 114-115 mph.
I was getting better and better with the ET Streets as the day went on. Next time out I should be able to pull 1.9's. It takes a bit to get used to heating them up and launching on them
Old Apr 8, 2006 | 11:50 PM
I30tMikeD's Avatar
I mean, my goal from the begining was for 12's. But a 12.97 is kinda....well...not that exciting. I am happy and all but I would like to get a bit deeper in the 12's. But I broke 12's and didn't break anything so I am no complaining.
Old Apr 8, 2006 | 11:53 PM
96_vqmax's Avatar
T04B 1.32A/R
13 psi
Full Exhaust
93 octane
3300 lbs
2 valves
3rd best
60" 2.342
330" 6.045
1/8 8.941
mph 86.48
1/4 13.448
mph 110.00
2nd best
60" 2.350
330" 6.015
1/8 8.885
mph 87.54
1/4 13.368
mph 110.41
Best
60" 2.285
330" 5.945
1/8 8.822
mph 87.10
1/4 13.331
mph 109.59
WOW congrats,you should be in 12's too if you get some better tire and cut those 60ft down,good luck.
Old Apr 8, 2006 | 11:59 PM
I30tMikeD's Avatar
Originally Posted by matty
Mike,
-matt
yes, clutchnet 6 puck sprung hub.
After back to back to back runs dumping it from 5K on slicks it would slip a bit in 4th. Not complaining at all, clutch did a good job. Launching on slicks is really hard on a clutch. Unless I want to go with a hard core set up like Mardi's then just about any streetable clutch will give a bit under those conditions.
I had a total of 20 passes on the ET Streets. I think the Clutchnet held up pretty darn well.
Old Apr 9, 2006 | 12:15 AM
Thanks.. yea. im working on a better tire+wheel combo for the track... i need somthing.
Old Apr 9, 2006 | 08:12 AM
russianguy's Avatar
sick times
Old Apr 9, 2006 | 11:31 AM
Neil, how are the Nittos holding on the street now that its a bit warmer?
Old Apr 9, 2006 | 11:39 AM
95maxrider's Avatar
Lightly modded
Nice times Mike. At least you crossed the 12's barrier.
Old Apr 9, 2006 | 06:13 PM
Aaron92SE's Avatar
NWP Engineering.com
Not bad! It's a good start! Keep the times coming.
Old Apr 9, 2006 | 06:24 PM
Nealoc187's Avatar
SLOW
Haven't driven it, the car is down right now I've got some things to do to it.
Old Apr 10, 2006 | 06:53 AM
il99max's Avatar
Good times Mike. It was a fun day. You broke into the 12's twice that day. Glad I got to see your car run the 1/4 mile before you move to Oklahoma.
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
jonreidhead
Jan 6, 2016 09:38 AM
Sep 27, 2015 08:37 AM
