Spark plugs
Old Apr 24, 2006 | 03:07 PM
chris'smax's Avatar
Spark plugs
can some one post me a link as to where i can find some 2 step colder NGK spark plugs for a 3.5L in copper. All the places in town only have the stock platinum plugs.
Chris
Old Apr 24, 2006 | 03:27 PM
SPiG's Avatar
SomePsychoGuy
I would use Iridium since it is supposed to give a stronger spark, laster longer than copper (remember you have to take off the IM to change them), but are cheaper than Platinum. They are also boost friendly like copper.
It seems they don't make 2 step colder plugs for the VQ35. I can't seem to find them.
LFR6AIX-11 Iridium 1 step colder
LFR6A-11 Copper 1 step colder
http://www.rockauto.com
http://froogle.google.com
Old Apr 25, 2006 | 07:13 AM
meximax's Avatar
SC Overspinning Swapper!!
You can get them here
Old Apr 25, 2006 | 11:11 AM
SPiG's Avatar
SomePsychoGuy
He is going to want to use NGK.
Old Apr 25, 2006 | 12:46 PM
meximax's Avatar
Are the Denso iridium plugs that much different than NGK?
Old Apr 25, 2006 | 01:12 PM
Jime's Avatar
You can get 2 step colder iridiums (LFR7AIX) here but no 2 step coppers.
http://www.clubplug.net/
Old Apr 25, 2006 | 01:52 PM
chris'smax's Avatar
thanks for the help guys,
I have seen on my350z that shariff always uses 1 step colder plugs because he says the 2 steps foul really quickly. Would running 1 step colder be dangerous?
Old Apr 25, 2006 | 01:54 PM
Chunger's Avatar
My other car is a Hybrid
I was running 2 steps colder with the Iridium IX but went back to 1 step colder... I'm running 3.12" pulley. I really doubt you need 2 steps colder unless you actually are experiencing detonation...
Old Apr 26, 2006 | 09:26 AM
SPiG's Avatar
SomePsychoGuy
Yeah you really don't need 2 step. The only reason you would need 2 step is if you were running a LOT of boost or boost and N2O.
1 step colder iridiums are probably your best bet.
Old Apr 26, 2006 | 09:28 AM
SPiG's Avatar
SomePsychoGuy
Originally Posted by http://maxmods.dyndns.org
Only run NGK spark plugs in the Nissan engine. This point cannot be stressed enough. The engine and ignition system was designed with the internal resistance and exact parameters of NGK spark plugs in mind. Maybe some people have had some success stories running other brands, but others have lost 15hp, have lost gas mileage, have hesitation problems, or had to replace their whole engine, just by running non-NGK plugs. Don't say we didn't warn you ahead of time.
NGK is the only brand that should be used in a Maxima.
Old Jun 2, 2006 | 05:14 PM
T-One's Avatar
Do you know if the NGK's sold at the dealer are the same as say AutoZone NGks?
Old Jun 2, 2006 | 06:24 PM
GodFather's Avatar
Made in Taiwan
Yes, they are the same, however, in Autozone, you'll find lot's of alternative NGK plugs available for our cars. They are way cheaper, but those are not the same. The same ones are $10+ each.
Old Jun 5, 2006 | 08:21 AM
d00df00d's Avatar
Old enuf to pick his own gears
Yes they are. Densos use a finer electrode tip than NGK (0.4mm for Denso vs. 0.6mm for NGK). That means better spark and shorter life.
That paragraph from Maxmods keeps coming up in spark plug threads and it's a bunch of crap. Some other brands have quality control issues and make plugs with weird designs that do more harm than good in our engines (e.g. Bosch), but NGK is definitely not the only company that makes plugs that will work properly. Denso, for example, is 100% fine.
For the record, I ran Denso Iridiums for a while and switched to NGK Iridiums pretty recently. I liked the Densos better.
Old Jun 7, 2006 | 09:30 AM
dfownz's Avatar
You can replace them without removing anything but the coil-on-plugs, you just have to get crafty.
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
