Before I fully commit.....
Old Jun 4, 2006 | 06:43 AM
dfownz's Avatar
I have a 2k Maxima and I'm about to invest some money in a supercharger. As of right now, here's what I think I'll need to get this thing up and running.
Matt's v1 kit, the sc, and all of those little hoses and whatnot, an intank Walbro 255lph pump, a cartech fuel management unit, and that is it.
Now, the only tuning option that I will have would be to play with the Cartech. Is this going to make my not run properly from lack of tuning options, or should this be enough?
Also, I know that my MAF is not up to par with more than 300hp or so. What is the part number for the Z32 MAF and where do I find one for cheap? Also, I am under the impression that this is a direct bolt on and does NOT require any reprogramming in order to be fully compatable with my car.
Please correct anything I missunderstand, or make suggestions!!!
Thanks everyone!
DF
Old Jun 4, 2006 | 06:46 AM
MaxInProgress's Avatar
Proud of his GroceryGetter!!!!
Are you gonna upgrade your injectors? You need a boost gauge also. A Z32 maf with the pigtail should run you no more than 100 used.
Old Jun 4, 2006 | 09:29 AM
matty's Avatar
It all really depends on what type of power your looking for, ie. pulley size. If you want to start off with a stock pulley to get going, then the cartech wont have to add much fuel. Once you start going down on the pulley size, (UP on boost), then the Cartech setting will have to be "tightened down" to add more fuel pressure. Then you can bleed air to get a good a/f reading up top, but that comes into effect if you get on a dyno for more presice settings. For now, leave that bleeder tightly closed.
I hope you understand a bit better
Old Jun 4, 2006 | 11:55 AM
dfownz's Avatar
Nah, I'm learning......and comprehending
Old Jun 4, 2006 | 12:00 PM
14psisupra's Avatar
the bigger the pulley you add, the more boost you will be making, more boost means you have to add more fuel, your air/fuel ratio, so running a low boost to begin with then you wont have to add much fuel to get you started. then bigger pulley , bigger intectors i assume if needed
Old Jun 4, 2006 | 12:09 PM
Its the smaller the pulley you get the more boost you will see not the bigger. You start out with a bigger pulley. Or am I wrong?
Old Jun 4, 2006 | 01:31 PM
14psisupra's Avatar
yea, you are right
Old Jun 4, 2006 | 04:00 PM
PharoNDmist's Avatar
Sounds correct to me
Old Jun 4, 2006 | 04:59 PM
dfownz's Avatar
Heh, and how much will my fuel use differ? How many MPG do you think i'll get?
DF
Old Jun 4, 2006 | 05:08 PM
Broaner's Avatar
2060lbs and falling...
Fuel econ should not be of concern if you're boosting a car. The two don't go hand in hand.
Old Jun 5, 2006 | 06:44 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
I had 24-26 mpg when I wasn't boosting. This thread seems funny to me for some reason.
Old Jun 5, 2006 | 08:07 AM
dfownz's Avatar
Yeah I just wanted an idea of what I'll be getting.
Old Jun 6, 2006 | 07:41 PM
dfownz's Avatar
Bump my fuel quesion and.....
Should I be get a v1 t trim or something less harsh for my stock engine?
Thanks,
DF
Old Jun 7, 2006 | 05:29 AM
Broaner's Avatar
Most would start with the S trim or SQ. If its your first time boosting I would take it easy.
jmlee44
Oct 2, 2022 02:13 PM
Mar 12, 2020 12:06 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
Socalstillen
Sep 20, 2015 11:46 PM
97_GXE
20
Sep 17, 2015 08:12 PM
