AFR w/ 550cc and Z32 untuned stock ECU. dyno inside
For those who are curious (I was too, that's why I dyno'd)...
Here is what the afr looks like when you run 550cc injectors, z32 maf, untuned with a stock ecu (btw, supercharger is not installed).
Observations: On the streets, I was pinging a bit between 3000-3500rpm which the dyno operator confirmed during the dyno.
Test data:
Looks like death below 3500.
Conclusion: Tune.
Test data:
Conclusion: Tune.
Originally Posted by MaxInProgress
HHMM i though it was gonna be a LOT richer than that. Wierd.
weird I was running 612cc's, Z32, walbro 255 on a stock ECU with my base FP at 32psi and my a/f was either off the charts rich or below 10.5. Same with I30Mike also which ran a similar fuel setup as mine. Something strange is definitely going on with your car.
BTW whats up with that torque number?
Oops, forgot to add I do have a Walbro 255 hp pump with the oem fpr, so base fp should be around 41 psi. I was also running two step colder sparks with .032 gapping (haven't switched them out yet).
The dyno was done on a dynopack, which measured power/torque from the hubs, as opposed to wheels on roller, so the numbers are slightly inflated.
Originally Posted by IceY2K1
Okay....my other guess is air leak post MAF.
It was also pinging a little (below 3500rpm) when I had the blower on. If I had a boost leak after the MAF, it would run richer.
im using a stock ECU with Z32 MAF and 550 injectors. Fuel pressure at 36psi and it runs super rich. Have to pull about 30% on the S-AFC to get it to close to 14 AFR.
litch
123
Jan 4, 2024 07:01 PM
AaronL
Aug 8, 2020 10:31 AM
05RLS2
Apr 14, 2016 11:49 AM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
