so ive got a 99 and i wanna boost
Old Aug 13, 2006 | 06:18 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
ive weighed all my options between boosting and the 3.5 swap and my final descition is to supercharge. HOWEVER ive got a 99 and that means no upgradeable ecu so for you boosted 99's what r u using to to tune the car so it runs right after boost.
also i wanna put in the 00vi with the boost install but i need a higher rev limit any ideas ? what have you guys done ?
Old Aug 13, 2006 | 06:37 AM
Tatanko's Avatar
Bacon Lover
Since you want a higher rev limit and also want to tune, why not go with something like the Emanage?
Old Aug 13, 2006 | 06:38 AM
95turbo gxe's Avatar
Yeah me too im working on my set up now. Trying to get the dek in with the 5speed first, then off to boost. Here is a link to some of my progress on the inside and swap to black on black leather.
http://forums.maxima.org/showthread.php?t=486746
Old Aug 13, 2006 | 10:06 AM
sean05's Avatar
might want to fix your sig before a mod gets you.
As for the
ECU upgrades with the you could go emanage blue, emanage ultimate, or AEM make a unit also.
Old Aug 13, 2006 | 10:45 AM
PharoNDmist's Avatar
I'm not to familar with the emanage, but does it raise the Rev limiter on the 99's?
Old Aug 13, 2006 | 12:04 PM
matty's Avatar
Yes. And it can control larger injectors, pull timing, and has a self tune option as well. The thing is great for all around tuning and controlling large injectors.
-matt
Old Aug 13, 2006 | 12:07 PM
DandyMax's Avatar
3.5 in the works
the Emanage Ultimate that is...
Old Aug 13, 2006 | 02:08 PM
sean05's Avatar
Hows the unit coming along for you? Did they take the 2.0v off the site? Im defiently going to get this after i get my superchager all hooked up and operational.
Old Aug 16, 2006 | 09:29 PM
2slow4u's Avatar
The other option to go w/ i'm researching myself is a megasquirt stand alone. Its a build yourself standalone and than create your own wiring harness (not fun but worth it and not too expensive)
Old Aug 17, 2006 | 12:28 PM
DandyMax's Avatar
3.5 in the works
It is doing fine. There are still a couple of areas I'd like to see Greddy make some improvements in, but all things considered it has been a resounding sucess.
Maxboy23
55
May 1, 2025 06:09 PM
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
aw11power
Oct 10, 2021 04:57 AM
MichMaxFan
Sep 30, 2015 09:18 AM
