Supercharger install (almost) complete... question
How the hell did you guys loosen and tighten the belt tensioner with the blower on???
It's barely accessible as of now... Also, I am trying to put the darned belt on, and it's the hardest damn thing to do ever (FAR harder than the stock belt). I can't seem to get ANY slack at all. Any advice or special tools? I am open to almost any suggestion save the old "cut it and tape it back together" bs...
![](https://maxima.org/forums/images/smilies/support.gif)
As long as your using the right belt for your application, just put it around everything BUT the MAIN pulley on the motor (harmonic balancer), make sure the tensioner is ALL the way lose, and get alittle of the belt on the pulley and turn the pulley with a 17mm?? rachet. It will turn and sequentially turn the belt on. Thats what I do
-matt
-matt
-matt
Are you referring to the largest pulley? (the one located the farthest towards the rear of the car)? I also assume that you get the belt onto the top of the main pulley first and then turn the pulley clockwise... is that correct?
i think i used a swivel head with a some extensions. I loosened all of the tension from the tensioner and placed the belt around every pulley but the A/C one. I found it to be the easiest to slide the belt on and off. If there still isn't enough slack you could do what matty suggested but i left the a/c pulley last again.
Like Matty said,
ratchet>loooong extension>elbow> 14mm socket. Piece of cake.
As far as your belt, it should not be difficult. I think either your tensioner pulley isn't loose enough yet, or you have the wrong belt.
dutch078
Wheels/Tires
08-03-2015 06:58 PM
