**Gauging Interest: V1 Supercharger Starter Kit for 3.5 Ltr. Motor**
Old Jan 22, 2007 | 07:51 PM
  #81
matty's Avatar
Im working on it guys...Im going to make some contacts over the next few days, make some orders and I will be going through with first production of a plate. It will be slow from the start but I should have something soon for fitting and testing.
Sorry for leaving you guys hanging. Been busy with my New job and Family and gf.
Thanks guys
Old Jan 25, 2007 | 06:25 PM
  #82
matty's Avatar
I need some input. Im putting some things together and talking to my guy, and I have some questions...
1) The Oil Cooler line that runs from the 3.5 Thermostat housing to the oil pan, how critical is that ?? I mean, can you remove that totally with no ill effects ?? Obviously I would have a good weld on the stock thermostat housing that would come with the kit, then on the other side of that hose on the motor, you would need to cap it with a 10mm bolt and some thread locker. Lemme know what you think about doing away with that line and the ill effects if any ??
2) Guys with the electical box next to the timing case, you will need to see if you can up-route that and move it to a different location. Ive been looking over everything and theres no way my kit will work with that block box there.
There are also power steering lines that are not as big of a deal as that box.
Old Jan 27, 2007 | 03:34 PM
  #83
reeloop's Avatar
*bump up to the top for people to see*
Old Jan 30, 2007 | 08:16 PM
  #84
BLK2BLU's Avatar
There is that much of a difference in the 3.5 and the 3.0L? Looks like the 3.0 is a tight fit tho.
Old Jan 30, 2007 | 08:34 PM
  #85
steven88's Avatar
Need A Light?
the biggest difference is the VTCs on the 3.5L...everything else is nearly identical in terms of coolant reservoir location...fuse boxes...etc...i'm talking bout the 5 and 5.5 gen that is
the 6th gen will have more problems with this kit...becuz of their new engine bay setup...the 5th gen ALREADY has a s/c kit out...its only the 5.5 gen that doesn't exist...its main reason is due to the VTC getting in the way...
Old Jan 30, 2007 | 08:39 PM
  #86
BLK2BLU's Avatar
I forgot about the 6th gen ppl (sorry guys) so caught up in getting one for my 5.5
Old Feb 1, 2007 | 07:46 PM
  #87
matty's Avatar
Bump it up..I need an answer from all you guys on this. A consensus from you guys on this problem would help
-matt
Old Feb 2, 2007 | 01:37 AM
  #88
Hoooper
dont put my on the list, but i want you to know im interested and when the time comes, probly 2+ years, i will buy this. thats if my max hasnt been totalled, the 5.5s are going fast lately. anyway, another interested but short on funds here.
Old Feb 6, 2007 | 10:55 PM
  #89
BLK2BLU's Avatar
1) The Oil Cooler line that runs from the 3.5 Thermostat housing to the oil pan, how critical is that ?? I mean, can you remove that totally with no ill effects ?? Obviously I would have a good weld on the stock thermostat housing that would come with the kit, then on the other side of that hose on the motor, you would need to cap it with a 10mm bolt and some thread locker. Lemme know what you think about doing away with that line and the ill effects if any??
Ask in the 5th gen forum?
Old Feb 11, 2007 | 08:01 AM
  #90
BLK2BLU's Avatar
bump....and ask in the 5th gen
Old Feb 15, 2007 | 10:55 PM
  #91
reeloop's Avatar
bump!!!!!!!!!!!!!
Old Feb 18, 2007 | 07:49 AM
  #92
Chaser's Avatar
N E thing New
Bump!!!!!!!!
Old Feb 21, 2007 | 07:13 AM
  #93
3.5altman's Avatar
bump bump!!!
Old Feb 24, 2007 | 06:48 PM
  #94
Chaser's Avatar
Something to look at!!!
http://www.comptechusa.com/store/new...ercharger.html
Old Feb 24, 2007 | 07:39 PM
  #95
matty's Avatar
The reason why I am trying to build a kit that puts the Vortech blower on the Pass side of the motor is because the Vortech units are fairly easy to come back and arent a fortune. Other units, like the Roots Type blower shown above, are $$, hard to come by, and include many variables for the install.
-matt
Old Mar 8, 2007 | 04:35 PM
  #96
Han's Avatar
Han
I'd be interested in adding V2 to my 3.5L...Put me down.
Old Mar 8, 2007 | 04:38 PM
  #97
Han's Avatar
Han
Still working on it in my mind
Im starting my new job come first of the year so I will have some time to start looking over things and see if its feezable.
Right now with the holidays and such, its kinda hard for me to find any time.
I will keep you guys posted on this. If it possible to produce these, I will have one made and start contacting people for a test car where I will mount the blower, run it, run oil through it, with NO boost put to the motor. After running it for a bit I will have an idea of belt alignment but that will all be done before that day so it should all line up no problem.
-Matt
Let me know if you need a test mule car and I'll loan you mine...
Old Mar 8, 2007 | 05:03 PM
  #98
nismology's Avatar
Your engine can use the existing starter kit. This thread is for 3.5's with the 3.5 timing cover.
Old Mar 8, 2007 | 05:29 PM
  #99
matty's Avatar
You have a 3.0 Timing Chain on your 3.5ltl. You can make use of my V1 Starter Kit that I have in stock.
-matt
Old Mar 8, 2007 | 07:24 PM
  #100
AllBlackMax's Avatar
aka The Doom Ship
Not to beat a dead horse but,
Using the 3.0 timing on the 6th Gen won't work because there appears to be other stuff in the way?
Old Mar 8, 2007 | 07:36 PM
  #101
matty's Avatar
He has a 3.5 ltr motor in his 3.0 motor car. Meaning hes using the 3.0 timing equipment.
I am working on kit that will fit over the 3.5 timing cover.
-matt
Old Mar 8, 2007 | 08:04 PM
  #102
aka The Doom Ship
-matt
Well, we're still counting on you Matt.
Old Mar 21, 2007 | 10:53 AM
  #103
Starchild2K2SE's Avatar
:werdsign:
Old Mar 30, 2007 | 08:25 AM
  #104
Utsutsu's Avatar
friendly bump
Old Apr 2, 2007 | 12:57 PM
  #105
Kashanova's Avatar
wats the latest on this?
Old Apr 2, 2007 | 01:06 PM
  #106
steven88's Avatar
Need A Light?
i think its dead?
Old Apr 2, 2007 | 07:03 PM
  #107
Chaser's Avatar
bump that steve!!
Old Apr 26, 2007 | 06:02 PM
  #108
matty's Avatar
Wheels are in motion guys...Give me some time
-matt
Old Apr 27, 2007 | 07:18 PM
  #109
aka The Doom Ship
-matt
Funny how those simple words breathe life back into my hopes.
Old May 2, 2007 | 06:43 AM
  #110
LeX's Avatar
LeX
Nissan by Nature
-matt
glad to hear it! If i keep my maxima (since the guy who bought it backed out) there is a 100% chance I am going to boost that sucker until it blows So Matty will be king when this is done
Old May 29, 2007 | 04:26 AM
  #111
matty's Avatar
I sent out a few peliminary PMs to guys to try and get this rolling.
I still need to know
1) The Oil Cooler (coolant) line that runs from the 3.5 Thermostat housing to the oil pan, how critical is that ??
Im throwing around the idea of using a three ltr thermostat housing, and doing away with Coolant line going from the thermostat to the lower motor. Is that line even needed at all ?? The 3.5 ltr thermostat cant be modified do to a very long shaft on the 3.5 thermostat. They are the same part, just longer shaft
Guys that recieved the PM, please contact me back.
-matt
Old Jun 2, 2007 | 11:23 PM
  #112
maxspeed96CT's Avatar
The original VQ...
wow how did I ever miss this thread?
I am definatly down for this.
Good luck, i gotta start savin some $$
Old Jun 4, 2007 | 09:22 PM
  #113
matty's Avatar
Can anyone give me an answer on the extra line coming out of the Thermostat ??
Will everyone be heart broken if this kit Eliminates that Cooling line. It really cant do much if you ask me
-matt
Old Jun 5, 2007 | 05:14 PM
  #114
Utsutsu's Avatar
I hope you get the answers you need, to advance with this project cause I'm really looking forward to it.
Old Jun 5, 2007 | 05:22 PM
  #115
aka The Doom Ship
Post this question in the 6th Gen forum. There should be some savy guys there.
-matt
Old Jun 5, 2007 | 05:27 PM
  #116
SR20DEN's Avatar
VQ Wizard
-matt
That line goes to the oil cooler. I wouldn't advise that it be omitted.
Old Jun 5, 2007 | 05:28 PM
  #117
SR20DEN's Avatar
VQ Wizard
Sure, post this question in the least savvy area of Maxima.org. That will get you an accurate answer.
Old Jun 5, 2007 | 08:58 PM
  #118
TurboS13Hatch's Avatar
-matt
We eliminate the oil "warmer" as I like to call it, when we do VQ35 swaps into the B15 chassis.. I have done at least a dozen, and have observed no ill effects.. Worst case scenario.. if you want to be **** about oil cooling.. you could run a remote oil cooler using about 200 bucks in parts..
Travis
Old Jun 5, 2007 | 09:10 PM
  #119
nismology's Avatar
No one's really arguing that it's a make-or-break feature of the motor. It's just that it's better to have it than to not, IMO. And if you can keep it somehow, why not?
Old Jun 5, 2007 | 09:37 PM
  #120
SR20DEN's Avatar
VQ Wizard
Travis
LOL
Yes it's that too. Which is why I normally refer to it as the heat exchanger.
I don't doubt you've seen any ill effects, as it would be difficult to prove anything without monitoring the oil temp. But everyone should be aware the cold oil is just as bad as hot oil. So it isn't all about keeping the oil cool as much as keeping the temperature stable. The 170-185* VQ35 thermostats are most likely the ideal temperature for the recommended 5w-30 motor oil.
So will it hurt to be removed? Most likely not, especially since the VQ30 runs just fine without the thing. But I personally would choose to keep it. I've always liked the idea of having the oil temperature rise quicker from a cold start. If that is really how it works out in the real world.
