**Gauging Interest: V1 Supercharger Starter Kit for 3.5 Ltr. Motor**
Old Jun 6, 2007 | 06:16 AM
  #121
NmexMAX's Avatar
dot dot dot ...
Originally Posted by TurboS13Hatch
least a dozen, and have observed no ill effects..
Not sure if it was you, but the last B15 I remember dynoing w/ a 3.5L, one point that was brought up in the thread was that the coolant temps were @ 210ºF.
Old Jun 6, 2007 | 06:24 AM
  #122
matty's Avatar
Well if that line is eliminated, which most likely will be, the 3.0 and the 3.5 thermostats are exactly the same bolt pattern to the motor, but are they the same tempurature setting ??
I only ask because the way the 3.5 thermostat is contsructed from Nissan, you cant modify it cause the shaft goes all the way out to the bend and therfore unable to modify it and make it closer to the motor. Kind of a hard to explain without seeing it.
-matt
Old Jun 6, 2007 | 08:00 AM
  #123
DandyMax's Avatar
3.5 in the works
I just checked the 02 FSM, it opens at 180F, as does the 3.0.
Old Jun 6, 2007 | 08:04 AM
  #124
TurboS13Hatch's Avatar
Doesn't surprise me.. hot day.. hardly any air blowing over the radiator from being at a standstill.. 210 isn't hard to believe..
But, that really shouldn't have anything to do with the oil cooler.. if anything, the water temp should be lower without the oil cooler in place.
Old Jun 6, 2007 | 08:10 AM
  #125
Originally Posted by SR20DEN
LOL
Yes it's that too. Which is why I normally refer to it as the heat exchanger.
I don't doubt you've seen any ill effects, as it would be difficult to prove anything without monitoring the oil temp. But everyone should be aware the cold oil is just as bad as hot oil. So it isn't all about keeping the oil cool as much as keeping the temperature stable. The 170-185* VQ35 thermostats are most likely the ideal temperature for the recommended 5w-30 motor oil.
So will it hurt to be removed? Most likely not, especially since the VQ30 runs just fine without the thing. But I personally would choose to keep it. I've always liked the idea of having the oil temperature rise quicker from a cold start. If that is really how it works out in the real world.
Yeah.. we had to decide on what to do with it.. I rigged up a oil drain plug with a thermocouple for a autometer oil temp gauge, so that I could easily swap it over from vehicle to vehicle without drilling into the pan/motor. I took oil temp samples on a VQ30 that we had here... and then took oil temp samples on a VQ35 with/without the oil cooler.. I noticed only slight variations (around 5-10 degrees F) depending on engine load. I hammered on a VQ35 without the cooler for about 30 minutes.. and noticed a 20 degree rise in temps.. HOWEVER.. after beating on the VQ35 WITH the oil cooler for the same period of time.. the temp increase was almost identical at around 18 degrees.
My thinking is the same as yours.. maybe this oil "cooler", is actually an oil "warmer" to help the oil get to it's working temperature much faster..? Maybe it has a lot less to do with actually cooling the oil..
Travis
Old Jun 6, 2007 | 08:28 AM
  #126
matty's Avatar
Perfect. Looks like there is NO way to use the 3.5 thermo housing do to that long shaft on the 3.5 thermostat.
Old Jun 8, 2007 | 02:47 PM
  #127
636specman's Avatar
very interested. trav or matty, i need some boost...i cant deal with the bottle anymore.
Old Jun 10, 2007 | 09:48 AM
  #128
machinehead131's Avatar
lets get this rolling. ahaha
Old Jun 19, 2007 | 09:31 PM
  #129
coinage's Avatar
Count me in... I am roughly 2.5 hours away, i would consider lending the car depending on how long you need it... PM me and we can talk...
Old Jul 2, 2007 | 07:46 PM
  #130
02altimaSEny's Avatar
Matty I am late with the PM but get back to me thanks.
Old Jul 2, 2007 | 08:40 PM
  #131
maxspeedse02's Avatar
Thinks he is fast
Matty have you considered what some of the 3.2L acura guys have used from comptech? Comptech is now out of business or is going out of business so all I could find was this picture http://images.google.com/imgres?imgu...%3Den%26sa%3DG
It basically has a long tube so the actual S/C is mounted on the driver's side eliminating some of the issues involved with clearance on the 3.5L FWD cars. It appears to be more of a roots style blower if my memory serves me correctly. Any thoughts in using a S/C from a car that came equipped with them i.e. GTP, 3.8L T-bird, Cobra anything that could be fabricated to work and cost effective?
Just a thought oh and I'm in.
Old Jul 7, 2007 | 04:07 PM
  #132
No updates????
Old Jul 13, 2007 | 08:19 AM
  #133
95 maxima se's Avatar
Silver Tooth S2K 9k FTMFW
+1 even tho i dont have one but i want a 5.5 gen maxima
Old Jul 13, 2007 | 04:39 PM
  #134
NmexMAX's Avatar
dot dot dot ...
The SC you're talking about, and the SC matty's thinking about are different. Centrifugal vs roots type. You knew that. Good idea, but there is less work re: mattys idea since it's almost the same from FWD VQ35 -->VQ30, and of course we all know there are already V1 equipped A32/33's .
Old Jul 16, 2007 | 02:34 AM
  #135
matty's Avatar
Bare with me guys
-matt
Old Jul 16, 2007 | 10:49 AM
  #136
Import Roller's Avatar
i didnt read the whole thread. did you find a way for this to fit the 3.5 correctly? Im interested in a kit for my 4th gen altima
Old Jul 16, 2007 | 10:53 AM
  #137
<3 superchargers
Old Jul 18, 2007 | 08:22 AM
  #138
DasYears
wish i knew if this was going to for sure happen (even if 2 years from now) or not. i would LOVE a T-trim for my 3.5
Old Jul 18, 2007 | 08:27 AM
  #139
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showpost.ph...&postcount=135
Old Jul 18, 2007 | 08:48 AM
  #140
DasYears
since when does bare with me mean its for sure gonna work out? im not saying hurry up or anything, more just saying good job to matty and i cant wait for it to be finished
Old Jul 18, 2007 | 09:03 AM
  #141
SR20DEN's Avatar
VQ Wizard
Screw the T-trim. I would go straight for the YSi.
Old Jul 18, 2007 | 09:15 AM
  #142
matty's Avatar
The TSi is a larger case and may not even fit...
The T-Trim is a very nice upgrade
Old Jul 18, 2007 | 09:23 AM
  #143
SR20DEN's Avatar
VQ Wizard
The YS and YSi fit on the standard S-Trim bracket. But yes the blower is physically larger.
Plus, it can't really be driven with an inadequate 6 rib belt. It requires an 8 rib or a cog.
Old Jul 18, 2007 | 09:58 AM
  #144
DasYears
not to mention that they are race only and i wouldnt drive with one on the street.
PS: it might fit on the bracket, but the YS and YSi may not fit within the given space (dont know how much bigger it is)
Old Jul 18, 2007 | 10:10 AM
  #145
SR20DEN's Avatar
VQ Wizard
Believe what you want, I am not telling you what to do. I am telling you what I would do.
Ok there mockingbird.
Old Jul 18, 2007 | 11:13 AM
  #146
DasYears
i must not know what a mockingbird is cause that doesnt make any sense to me
Old Jul 23, 2007 | 06:52 PM
  #147
bwinter7's Avatar
I would def. drop the loot for this mod...... you could count me in, if you're still taking names....
Old Jul 30, 2007 | 07:34 PM
  #148
The Law's Avatar
I R The Law
any new updates?
Old Aug 3, 2007 | 07:11 AM
  #149
Subzero's Avatar
I think us 3.5 peeps should try to get someone to manufacture a front or rear mount turbo kit and give up on the whole supercharger dream.
Old Aug 3, 2007 | 07:31 AM
  #150
NmexMAX's Avatar
dot dot dot ...
Keep 'em both alive
Old Aug 3, 2007 | 07:32 AM
  #151
SR20DEN's Avatar
VQ Wizard
What is stopping you?
Old Aug 10, 2007 | 08:40 AM
  #152
DasYears
yeah, i agree with nmex. both FTW. competition and choices make me happy
Old Aug 10, 2007 | 09:29 AM
  #153
AllBlackMax's Avatar
aka The Doom Ship
At one of the local car meets I was admiring a custom turbo setup on a Spec-V. So happen the shop that built the car was out there and we spoke a little bit about a custom turbo setup for my car. After speaking with him he didn't seem to have any hangups about doing it. I mentioned engine/fuel management and he said some things that I can't remember verbatum but he described what they had to do with the Spec V.
Now I know a QR25 and VQ35 are 2 totally different beasts and we talked about that.
To make a long story short I'm getting a price on a custom turbo manifold.
Old Aug 23, 2007 | 11:55 AM
  #154
Utsutsu's Avatar
any progress??
*bump*
Old Sep 1, 2007 | 01:52 PM
  #155
maxspeed96CT's Avatar
The original VQ...
Bump, I would love to see a S/C or Turbo kit for the 3.5 max.
Old Sep 4, 2007 | 02:21 PM
  #156
DasYears
any new news coverage?
Old Sep 4, 2007 | 05:59 PM
  #157
NmexMAX's Avatar
dot dot dot ...
I'm pretty sure when there's an update, we'll be the first to know.
Old Sep 4, 2007 | 06:04 PM
  #158
nismology's Avatar
Stop making sense.
Old Sep 4, 2007 | 07:50 PM
  #159
aka The Doom Ship
I think they designed the space shuttle in less time.
j/k
Old Sep 26, 2007 | 06:22 PM
  #160
bwinter7's Avatar
It's been 22 days since the last bump,
so, bump
