Oil restrictor
Old Dec 11, 2006 | 06:30 AM
JaKillz2's Avatar
Oil restrictor
Whoever has a turbo vq30dek, (about 6-8psi) did you have to install an oil restrictor? If so, what would you recommend? Thanks.
Old Dec 11, 2006 | 07:45 AM
95BLKMAX's Avatar
its not about the motor or the amount of boost. Its about the turbo you use. The oil seals inside a turbo are not meant to seal with the direct oil pressure from the engine (which can go into the high 90s PSI in the high rpms). Thats why you need a restrictor.
As far as what to use, search on google. There's people that use an actual restrictor that can be bought off ebay, other people actually use a nitrous jet of similar size as a restrictor (I forgot the exact size of the jet, but Im sure you can find out if you google).
Good Luck
Old Dec 11, 2006 | 10:52 AM
JaKillz2's Avatar
I have seen a few like you mentioned, I also read that generally you only need them for -4an lines would you agree? I might get one when I order my lines just so I have it, run the turbo for a couple days and see if its leaking or smoking due to oil leaking through the seals. Then add the restrictor. I also read that generally only ball bearing turbos need them, if you have a journal bearing turbo and its smoking, the seals are bad, it wouldnt be due to overpressure. Any input? BTW thanks for the original answer.
Old Dec 11, 2006 | 11:19 AM
95BLKMAX's Avatar
applies to both BB and journal bearing. The turbo that I have is a T04b journal bearing (its not installed on my car as of yet). The guy I bought it off of (also a Maxima) told me (more like ORDERED me) to use a restrictor with it. He had nasty smoking when he'd floor it when he first installed it because he did not have the restrictor on.
Old Dec 11, 2006 | 05:35 PM
JaKillz2's Avatar
Rogggggggggger that .. thanks guys
Old Dec 11, 2006 | 05:55 PM
Aaron92SE's Avatar
NWP Engineering.com
I just made a post about this last night. It was in reply to James' post about oil lines. I also talked about oil restrictors; thought you might find the info useful.
http://forums.maxima.org/showpost.ph...18&postcount=2
Old Dec 12, 2006 | 06:16 AM
JaKillz2's Avatar
i saw that post actually i just wanted a little specifics thats all. THankk you
Old Dec 12, 2006 | 11:48 AM
streetzlegend's Avatar
or you can get a nitrous jet like 95blkmax said, and put it into a fitting that will go on ur turbos inlet, you drill the jet to w/e size u want. most commonly iv seen online a 1/16 size hole being used as a restrictor for t4, t3/t4, etc...
Old Dec 12, 2006 | 02:29 PM
Maxpwer's Avatar
No turbo, no care!
http://www.atpturbo.com/Merchant2/me...egory_Code=OIL
This is an "Oil inlet restrictor for all T3, T3/T4, T04, T72 etc."
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
