First ever Rear Mounted Turbo maxima
Old Sep 20, 2011 | 06:17 PM
  #441
SYNASTR's Avatar
To small in what since? I mean i know its a 4 cylinder turbo but would it not still be useable? He made 25 PSI off stock turbos before. It's practically free. So why not use it?
Old Sep 20, 2011 | 06:30 PM
  #442
Kevlo911's Avatar
Kevlo for President
It will likely choke at the top end. find me a compressor map of it
Old Sep 20, 2011 | 07:12 PM
  #443
SYNASTR's Avatar
http://www.ztechz.net/id6.html it shows only the 16g which is smaller and the 20 g which is bigger. so its somewhere in the middle. " it's 3/4 down the page"
Old Sep 20, 2011 | 07:14 PM
  #444
SYNASTR's Avatar
http://www.stealth316.com/images/td05h-18g-cfm.gif here is the 18G
Old Sep 21, 2011 | 04:49 AM
  #445
streetzlegend's Avatar
SYNASTR, many people make this mistake: They are given a turbo for free and then assume that everything else would be cake (or cheap). IMO the turbo is actually the last piece of the puzzle, it should be sized properly. So just because its free does not mean you can take advantage of it, unless you just want quick acceleration from 1500 to 3000rpm and then be as slow as the civic next to you after 3k rpm. I recommend you use that turbo as paper weight, and get a better sized turbo for our car. Also, dont go by what people say that RMT will require a smaller quicker spooling turbo, although there is a VERY slight difference its not enough to completely change the turbo size just because its going to be RMT setup.
Old Sep 21, 2011 | 10:47 PM
  #446
SYNASTR's Avatar
thanks streetz. I figured in all honesty. if i build the system off this turbo and it is 2 small. i can always get a bigger one and retune. The charge pipe won't change. flange. oiling. etc. So even if its dying past 3500. I can still daily drive the car. You understand kinda where im coming from?
Old Sep 25, 2011 | 08:27 AM
  #447
Clashez's Avatar
Some really good info here, Something i will be doing soon.....
Old Oct 4, 2011 | 06:30 AM
  #448
freshmax260's Avatar
@Streetzlegend. Bro can't I do this same setup on my 6th gen???? I'm planning on starting this after seeing yours and reading up on it. Seems to be fairly easy on doing. Any suggestions would appriciate bro. I used to be on here like 4yrs ago. I pretty much know what I'm doing this isn't my first max or boosted, my dude has swapped out a ka for the Sr20 all on his own. And is now 450hp strong.
Old Oct 4, 2011 | 06:52 AM
  #449
@Streetzlegend, I'm only wanting to run 4-6 psi as I didn't mention that.
Old Oct 4, 2011 | 10:34 AM
  #450
Yeah you can do it on any car really. its as simple as cutting the muffler, putting the turbo, putting a pipe from turbo to exhaust tip location or dump where u want. then a charge pipe from turbo to the front where ever u think u have most space. and if your car is too low you can get oval piping.
then you get a oil line or even a nitrous line, hook it up to a sandwhich plate on the oil filter, run it to the turbo, then a 1/2" line from turbo into the trunk or where ever you have a scavange pump, then run a line from there to the front of the car and into the valve cover, or a fitting you put on the block above oil level.
Then you get bigger injectors, get some piggy back to tune with and make sure you can adjust timing to lower it. tune it. and your good to go.then u got a bunch of small details which u can find through this thread. Line a timer for the scavange pump, etc..
Old Oct 4, 2011 | 10:56 AM
  #451
I figured. Thanks a lot bro, I will be getting back with you throughout this project once started.
Old Oct 21, 2011 | 08:55 PM
  #452
SYNASTR's Avatar
Ok im all into doing this now. I had a full 2.5 inch exhaust ran with no cats, resonators, or any small bends, aside from the muffler at the end. So i got full flow to my soon to be rear turbo. But i have a question or two. Can u T off of the oil sending unit spot and run it to the turbo Since it has oil pressure there? 2nd. Would the 30 to 50 psi of oil pressure be too much for the turbo? If so how would u lower it without affecting anything. Thanks guys.
Old Oct 21, 2011 | 09:06 PM
  #453
Get a sandwhich plate that goes on before you put on the oil filter, it has ports where you can put a 4an fitting, run a line from there to the turbo.
at the turbo, to control the flow to it, you can use nitrous jets, or buy a fitting that already has a built in restrictor. its basically a very small hole.
http://msvarchive.com/do.php/t-homem...or.html?tid=24
Old Oct 22, 2011 | 07:23 AM
  #454
Kevlo911's Avatar
Kevlo for President
If anyone wants to do a RMT, you should just read this thread and my thread. I think all the parts/situations are covered with pics and links.
Old Oct 28, 2011 | 05:41 PM
  #455
95BLKMAX's Avatar
Thats right!
::trolling::
Old Jul 6, 2012 | 01:05 AM
  #456
carsnwomen91's Avatar
this is pretty awesome, affordable and very convenient setup. i totally forgot about rear mount setups
Old Jul 6, 2012 | 01:08 AM
  #457
excellent
Huttig2009
Sep 25, 2015 03:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
RealityCheck
Aug 5, 2015 06:18 AM
