turbo progress pics
Old Jan 14, 2007 | 05:27 PM
95turbo gxe's Avatar
turbo progress pics
Well im not quite ready To turbo the car yet due to I wanted to run at lest 13.5-13.7 na. But Im bored and wanted to get some of the stuff out of the way well here what I got so far!
Old Jan 14, 2007 | 05:46 PM
Tatanko's Avatar
Bacon Lover
Wouldn't it make more sense to rotate the turbo 180º and have the charge piping go down the driver's side, then come back up on the passenger's side and crossover into the throttlebody, Stillen-style? Not knocking your work, just seems like it would get rid of a lot of harsh bends. Good work either way!
Ever get your idle steady and get the VIAS working properly?
Old Jan 14, 2007 | 06:21 PM
wunfstmax's Avatar
No, the downpipe would be very difficult to make work. He could change the the way the charge piping is ran, but not the position of the turbo it self.
Old Jan 14, 2007 | 06:28 PM
Tatanko's Avatar
Bacon Lover
True. Didn't think about those considerations.
What about clocking the compressor housing 180º (so that the outlet faces the front of the car)? Wouldn't that put his charge piping facing almost the way it is now, except with the air going driver's side -> passenger's side instead of vice versa? I would need to see what kind of space there is in that area, but from the pictures it looks like there's room for that if you push that fuse box out of the way a bit.
Also, I never noticed this before, but, are your couplers color-coded? Looks like your "hot" air piping has red couplers and the "cold" air piping has blue couplers
Old Jan 14, 2007 | 06:32 PM
absoundlab
I dont like the 90 going into the turbo
Old Jan 14, 2007 | 06:47 PM
Yes after i get everything done im going to see what type of room I got to change that I know their will be enough to change it!
Old Jan 14, 2007 | 07:00 PM
Tatanko's Avatar
Bacon Lover
It's not going IN, it's going OUT
Old Jan 14, 2007 | 09:19 PM
mtcookson's Avatar
On that compressor you can remove that metal piece that is around the compressor wheel. Its there for reduced noise but to me it seems like it would take away its anti-surge capabilities as well as the map width enhancement groove from what it looks like. There is a steel ring holding that in that you can remove with a screw driver. Here's what it would look like:
http://www.machzracing.com/Maxima/Holset/hx3.jpg
Here you can see the cover and clip in the top left corner:
http://www.machzracing.com/Maxima/Holset/hx6.jpg
Old Jan 14, 2007 | 09:57 PM
jcy98maxse's Avatar
Turbo is too much fun!
I highly recommend some way of getting a filter in there, Otherwise, looking good.
Old Jan 15, 2007 | 01:06 AM
mtcookson's Avatar
Bah... sucking up a few birds won't hurt anything.
Old Jan 15, 2007 | 06:30 AM
Kevlo911's Avatar
Kevlo for President
I would wrap the pipes or the turbo itself. You dont want the charge pipe to get hot after it passes through the intercooler.
Old Jan 15, 2007 | 08:40 AM
hah I bet the engine and turbo will last longer than the TRanny!
Old Jan 15, 2007 | 10:43 AM
wunfstmax's Avatar
It wouldn't, it doesn't pass by anything hot after the intercooler.
Old Jan 15, 2007 | 11:33 AM
jcy98maxse's Avatar
yea but what would be the condition of the turbo after 6 months? 1 year? I had that mentality too but I'm still on the same trans. But its your car, do as you please
Old Jan 15, 2007 | 08:46 PM
absoundlab
going in going out same damn thing you know what im talking about
Old Jan 16, 2007 | 04:15 AM
Tatanko's Avatar
Bacon Lover
Actually it's not
Old Jan 16, 2007 | 07:25 AM
Kevlo911's Avatar
Kevlo for President
Turbo is right there.
Old Jan 16, 2007 | 09:49 PM
wunfstmax's Avatar
Not the turbine side thought, I dont think hell have many problems with that.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
