Piston Appearance
Old Jan 20, 2007 | 05:52 PM
Chris Gregg's Avatar
Get Off My Lawn
Piston Appearance
Just removed my heads from my VG30ET after the timing belt incident occured. Just with 2k miles on the car, the pistons have a black coating on them. I did some research, appears to be indicative of running too rich. This is possible even though I have an A/F guage. Of course I hear the simple Autometer electrical guages are not accurate. I maintained a lean reading when running. I will be going with a better way to meter my A/F.
Just wanted to check in about piston appearance and see if this is consistent with what I've learned or should I be worried about something else? Thanks for input.
Old Jan 20, 2007 | 06:09 PM
wunfstmax's Avatar
Lean mixtures cause high combustion chamber temps, if your lean enough you could have detonation, which could be leaving the marks.
Old Jan 20, 2007 | 07:47 PM
505max94se's Avatar
You need a wideband o2 and a good guage to get an accurate a/f reading. You are running rich if you have carbon build up (black stuff) on your pistons but that's not necessarily a bad thing. Turbo cars should be tuned a little bit rich anyway. You might be running too rich, but there's no way to tell without a wideband o2. How did you tune your car in the first place?
Old Jan 21, 2007 | 04:54 PM
Get Off My Lawn
I tuned it on by the "feel" of the car. How it was idling, running, accelerating, returning to idle after acceleration, smootheness through rpm band, and smoking. My Autometer guage I thought was okay, but it seemed to run lean regardless of how high I bumped up the fuel pressure.
Simple response to how I tuned...I guessed. I'm running Live Edit and installed a program that ran the car best through the above mentioned criteria. I will be getting a Wideband, looking at the new NGK unit. Not sure if best or cost effecient though. I'm posting pictures on my Cardomain page tonight. If anyone's got a moment, take a look. It's low res though. Black coating doesn't seem too thick. Once I get everything back together, I hope to be able to do a better tune. There's just no one around me who knows anything about Live Edit or has a dyno to really get me where I need to be. It's like I've got all the tools I need to produce the power, just no way of "accessing" it. Thanks for feedback.
http://www.cardomain.com/ride/329804/5
Old Jan 23, 2007 | 07:04 PM
Get Off My Lawn
Pics are up using the link provided in last post.
Apr 16, 2020 05:15 AM
Forge277
Jun 13, 2016 09:26 PM
6spd4dsc
Mar 4, 2016 05:19 PM
tgreen
Oct 18, 2015 06:18 PM
MichMaxFan
Sep 30, 2015 09:18 AM
