VQ30DET pistons?
VQ30DET pistons?
Does anyone have a part number, or source where I can find stock VQ30DET pistons? Also, is the compression height and wrist pin bore the same size as a VQ30DE piston?
VQ30DE. These pistons will drop the compression ratio from stock 10:1 to more boost friendly 9:1.
For our application there only needed for high turbo boost or supercharger and N2O combinations.
Nice.. I talked to Clark today.. he said that they feature anodized tops, and moly coated side skirts.. with beefier ring lands and skirts/pin area. I think I'll pick up a set..
Travis
Travis
Originally Posted by jcy98maxse
How much would these run you? Are you getting aftermarket rods also?
I took the stock rods to a good machine shop where they were shot peened then reshaped and polished. This is more than adequate unless your looking for 600 FWHP or more!
I'm actually running a custom set of Eagles that I'm picking up from a fellow org member.. I'll be using the smaller rod journal VQ30DE crank.
The pistons are around 50.00 a piece..
I believe Arias make pistons for VQDET www.arias.com
Originally Posted by i30krab
Call Jim Wolfe Technology, they sell them. They are plug and play for the
Originally Posted by 93turbo gxe
Hey will al the talk of built motors and high boost does anyone know what we can do for are 5speed trannys to hold all this good power?
but from recollections, the 5spd could only handle more than a little more than stock power output.
Originally Posted by nismology
He's asking about compression height, which is the distance from the wrist pin bore centerline to the crown deck. I'll go out on a limb here and say it's probably it's the same as DE pistons.
It is the same as a DE piston..
I don't understand your question. If the 2 pistons are plug and play what difference the distance from the wrist pin bore centerline to the crown deck make?
Travis
I took screencaps of the VQ30DET piston part numbers in Nisan FAST:
acemann.shutterfly.com
The last part number of the group is for the .20 oversize service piston. I sent a parts request for some standard size pistons just to get an idea of price and availabililty. I can get any part number for the RWD VQDE and DET
If you look at the stickies in this section, there is a thread that Neal started about some stronger aftermarket gears for the Maxima 5 speed. Theres some really good information there and hope it helps.
acemann.shuttery.com
For the record the rods have the same part numbers too, from DE to DET.
The DET rods are definitely different.. The journal is larger, and the rods have more material.
Sorry about that - I'll edit the above post or delete it so no one is led astray. YES they do have different part numbers. Thanks for the catch
Apr 16, 2020 05:15 AM
6spd4dsc
Mar 4, 2016 05:19 PM
imported_Nismo_max
Sep 21, 2015 07:24 PM
ballerchris510
Sep 11, 2015 05:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
