wow thats fast! turbo last week blowed 3rd this week
Well I got done with the turbo install on thursday and wow blew 3rd gear this moring. I have a bid exhaust leak causing boost to not build as fast as it should but I was out doing a test run and shifted to 3rd and it went. only had maybe a 150 turbo miles on the tranny. Im not sure what kind of power im putting out but im am maxing the stock maf meter out at about 6200 and I have stock dek injectors running about 42 psi and they are at 100% after 6000 and the air fuel will creap up to 11.7
Ok so what can i do to build this tranny to hold some power?
Also Is their a better stronger 3rd I could use from another tranny
dam that sucks. Dont they have bullet proof trannies or cant you get the tranny treated to strengthen the gears? 3rd gear is always the first to blow for everyone...died on me with my last maxima when I was boosted....
Originally Posted by 93turbo gxe
The hell with im doing a 6speed swap.
Ah yes, Always a GOOD DECISION!
. lol. Yea to really hold up to high torque and horses, we have 2 options, shot-peening and cryo-treating our 5spd tranny, or just swapping a 6spd into it. Tyllies proved their strength (and that of the OEM 6spd clutch) with his 11.55 run on it.
I am building up a 5spd at the moment that will handle the power, and I will post my results when I am done. I would think that 350-400hp is well over the design limit of the 6spd as well, so it is only a matter of time till that breaks as well. It is too big a installation headache to do a 6spd swap only to break gears again.
I agree 100% with you. Even NA I was fed up with the 5-speed. 6-speed all the way, itll be a pain but once done youll be able to sleep at night. And anything you can do to the 5-speed, you can do the same with better results on the 6-speed. Longer 1st gear for traction, and 2-5 are shorter. Way better all around, and more recent and easier to find in good condition for YEARS to come.
I got tired of the glass drivetrain and Travis said the 6-speed internals are way beefier, which agrees with pretty much everything I have read.
Actually, with most turbo setups longer gears tend to do much better due to the way the engine makes it torque.... but... since the 5-speeds are so weak there's not really much that can be done about that.
I don't even have the option for the 6-speed so I'm currently devising a way for me to have a nearly indestructible 5-speed. No one will likely want to try it though but it'll be awesome. I'm just going to leave it at that for now.
I know my beefed up 4th gen will hold the power but who knows, any oem part not strengthened can break. Either your lucky or not!
well take apart the tranny and see what exactly broke. from there determine what parts you need to make stronger.
i guess the saying goes...if you're not breaking parts you're not going fast enough...or something like that
Originally Posted by i30krab
How do the 3rd gen auto trannies hold up with this much extra HP?
Originally Posted by Alex_V
Mark- Just mill 1/2 off the 6 speed bell housing and get an adaptor made!! Ask maxmaxima91 about the cnc work...
Maybe Its best if you just ignore 3rd lol.
~Alex
~Alex
Ahh, ok (I wasn't sure if you were talking about the 240 or not, I got confused
). As soon as I get it finished I'll definitely have lots of pictures for everyone. It might be a while since I'm juggling the Maxima and the Z project at the same time. It should be an indestructible tranny for the Maxima though.
I need to go to bed though... I should have been in bed 2 hours ago and I have a big order of donuts to make tomorrow.
Originally Posted by BoostedSileight
Has anyone looked into Z32 Trannies? (90-96 300ZX) I'm sure the bell housing would have to be changed or even a spacer, but multiple 240SX guys are running Z32 trannies, and they hold a good 400+
Need help
23
Oct 2, 2015 08:56 AM
Andy29
Sep 29, 2015 05:32 AM
pears
Sep 18, 2015 05:25 AM
