EU question, wiring the maf
Old Mar 3, 2007 | 08:01 PM
MaxInProgress's Avatar
Proud of his GroceryGetter!!!!
WHat wires on the emanage ultimate did you guys use for your in and out for the maf, is the in blue out purple?
Old Mar 4, 2007 | 11:04 AM
GodFather's Avatar
Made in Taiwan
Yeah, I did the write-up, and Maf is wrong. I'll talk to Luke about changing it soon.
The blue wire, you'll hook that to the wire coming from the engine, that's in.
The purple wire, you'll hook that to the ECU, that's out.
On the write-up, I had to opposite. And I'm working on possibly correcting the VSS in and out corrections, too.
Sorry.
-Peter-
Old Mar 4, 2007 | 11:08 AM
BoostedSileight's Avatar
Be careful not to mix them up, if you wire it up wrong you could blow the chip on your ECU. I wired mine up incorrectly, I had the 5volt from the Ecu going to power, and the 12volt power wire going to the ECU, too much power and it kept blowing my custom chips.
Old Mar 4, 2007 | 11:11 AM
i got the car running last night but the maf isnt connected to the emanage right now because were just bypassing it with the pressure sensor, i have direct controll over injectors which is better then having to controll them through a maf.
Old Mar 4, 2007 | 11:38 AM
jmeister's Avatar
Seems you would use the white input to EU and green output to ECU on connector b per hotwire instructions instead of the purple/blue wires at all since that's the karman vortex setup???
Old Mar 4, 2007 | 12:08 PM
GodFather's Avatar
Made in Taiwan
When we wire the maf wire up wrongly, it'll just have 0 volts going into the EU and 0 volts conflicting to the possibly 0.9-1.7 volts coming from the Maf. This is not a big deal unless the car has started and reved high enough to send higher voltages into the EU. But even so, it will not fry up any EU chips because EU will detect an error code at this time and stop working.
So either way, it'll not damage the ECU at all.
-Peter-
Old Mar 4, 2007 | 12:33 PM
yeah my car just didnt even start, cranked but didnt start.
The Frye
Sep 2, 2021 11:03 AM
9aj9
Apr 5, 2020 12:11 AM
ballerchris510
Sep 10, 2015 09:35 PM
Jamie Bowen
Sep 6, 2015 09:59 PM
dcardello
Sep 3, 2015 11:44 PM
