Oil Feed HELP! Need It By TOMOROW!!!
how do I run my oil feed line from my v2 sc? and it has two things sticking out of the sc ones oil feed and whats the other? please write ups anything I need help on how to run it
You should have a "T" fitting. That goes into the block on the rear of the motor in the "oil pressure sender switch hole". One of the outs goes to the Blower and the other is an inlet for the Oil pressure sender switch that was removed from the motor.
-matt
-matt
It has been stated in one of your other threads to download and read Ptatohed's supercharger writeup found on VQPower.com. It has Stillen's installation instructions in it as well. All the info is there. Start
litch
123
01-04-2024 07:01 PM
06-06-2017 02:01 PM
