choosing turbo also what are specs on your turbo 3rd gen guys?
Old Apr 16, 2007 | 05:38 PM
akurtzer57's Avatar
Looking for the right turbo and wastegate what size of turbo are you 3rd gen guys are using on their setups. Really want to know what trim and what kind of boost and power you making. I have a 91 max with the VG.
Old Apr 16, 2007 | 05:51 PM
akurtzer57's Avatar
Turbo T3/T4 Compressor
3" Inlet Diameter ad 2"Outlet
Wet Float Bearing
1/8 NPT Oil Inlet
.50 A/R Compressor
.63 A/R Turbine
.57 Compressor Wheel Trim.
What you guys think?
Old Apr 16, 2007 | 06:40 PM
mtcookson's Avatar
The 57 trim is ok but the 50 trim will support a little more power on the VG and is more efficient. What kind of power range are you aiming for?
Old Apr 17, 2007 | 08:54 PM
maxine'sMan's Avatar
has anyone heard of xs-power?
are these units any good?
http://xs-power.com/turbos/index.html
some of them use garrett internals.
Old Apr 17, 2007 | 08:56 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
whatever nissan made.......
Old Apr 18, 2007 | 02:03 PM
Chris Gregg's Avatar
Get Off My Lawn
Sad to say, I never got the specs on my turbo. After market T3, replacement for stock VG30ET turbo. There may be better turbos than stock trim, but I honestly can't complain about the kick in the pants this thing shoves into the engine.
Ultimately, question is: What is your setup? That in itself is going to expand or restrict the turbo you could use. Stock setup below front (Left) manifold you'll need stock size or smaller. Installing turbo over tranny you can go stock and much larger. Further, moving piping and installing turbo closer to where battery "used" to be, you can go even larger. So, what are your design plans and trying to accomplish?
Old Apr 18, 2007 | 03:47 PM
maxmaxima91's Avatar
im an example of how big you can go with a custom setup..
ive got a 1.32 A/R T04b hotside, and a 62-1 Cold side.
and since no one believes me that my spool inst bad ask Alex v, he rode in it.
2500 it starts building boost and has fool boost by 3500-4000, and makes good power to 7000 stock engine.
This kinda setup inst for everyone tho.. you need HIGH FLOW everything.
MAXSE5SPD
Aug 23, 2015 12:06 PM
maxipower
Aug 21, 2015 11:10 AM
carlosvq30
Aug 17, 2015 11:32 AM
Turbobink
Aug 15, 2015 07:20 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
