Turbo Specialties VQ30 turbo kit review
Old Nov 14, 2007 | 06:36 PM
  #241
BlackBIRDVQ's Avatar
drag racing is for wussies
I'm running a internal WG on my setup also, I am trying to keep it as "stealth" as possible with no traces of anything but a few pipes here n there.
Friend has a welding shop and can hook me up with CRAZY fabrication skills as far as welding goes. Surgical welds on my IC pipes FTW.
Too bad winter is almost here, I'm itchn to see what this setup of mine can push.
Old Nov 14, 2007 | 06:39 PM
  #242
Nealoc187's Avatar
SLOW
Originally Posted by kzoosho
I would use and internal. They are just as adjustable as external. and just as reliable. ALso if doing a custom job leaves for less pipe work also. If you look docs setup is an internal wastegate. My old dsm runnig 22psi was internal. Yea extenal looks cool but i would much rather have an internal.
I tend to disagree. I don't trust internal gates at all. I've seen too many have trouble holding there desired boost. I'd never run an internal gate personally - I feel external gates are functionally superior in every way. I do agree that it makes for easier and cheaper piping though.
Old Nov 14, 2007 | 06:45 PM
  #243
kzoosho's Avatar
Well if you look at the maxima no one here is going to be pushing as much boost as i was through my dsm. so an internal will be fine. Now for a hi po dsm like i had then most would have went with a external but i still used an internal. I have an external now but i would love to have an internal gate. Im not disagreeing with you Neal not at all as i have seen bot internal and externals fail( i have one) but for a maxima i wouldnt hesitate to use and internal.
Old Nov 14, 2007 | 07:11 PM
  #244
Nealoc187's Avatar
SLOW
If you check out the 350Z community, those guys have all kinds of problems with internal gates on the kits they run. My buddy had problems on his TT 350z with the gates on his Garrett GT2560Rs even at like 12psi... I don't know man, I just don't trust em. I know there are a million guys out there running them but I don't like them.
Old Nov 14, 2007 | 07:48 PM
  #245
kzoosho's Avatar
Ok we agree to disagree. Still love ya man. I mean if we go to looking at other comunities there are tons of turbo mopar guys running 20+ with internal gates so i mean it can go both ways u know. U have o decide what you want with yours and if you will be happy with it. When i change my setup this winter i am going to internally gated turbo and will prolly sell my tial i have now. like it but i dont likw that i had to run extra piping for it. It is pretty tho
Old Nov 14, 2007 | 09:13 PM
  #246
MaxBoost925's Avatar
Drug Money
Haha, I like my external gate just because I have one.
Kinda hard to change that fact now.
Old Nov 15, 2007 | 08:19 AM
  #247
doc2278's Avatar
Doctor D I presume???
yeah but were there internals set up properly? (since they can be adjusted)
Old Nov 16, 2007 | 01:16 PM
  #248
shiftnatredline's Avatar
Godzilla
This is the turbo they're talking about in the email I have below: http://www.turbobygarrett.com/turbob..._700382_20.htm
It may work the best for our application.
HI AGAIN,
THANKS FOR GETTING BACK TO ME.
THE GT 35 YOU LOOKED AT WOULD BE DIFFICULT TO ADAPT, IT DOES NOT HAVE AN INTERNAL WASTE GATE, THE INLET IS DIFFRENT, THE FLANGE TO MANIFOLD IS T-3 STYLE AND THE OUTLET FROM THE TURBINE IS WHAT IS CALLED V GROVE.
HOWEVER THE GT 3071R (700382-20) IS COMPATIABLE WITH OUR KIT. I WOULD HAVE TO ORDER AND I DON'T KNOW WHEN I WOULD GET IT.
FOR PRICING GIVE US A CALL OR E MAIL YOU # AND WE WILL CALL YOU. THERE ARE OPTIONS AND DIFFRENT PRICES FOR UPGRADE TURBOS.
BEST REGARDS,
JASSON/DOUG
TURBO SPECIALTIES
17906 CRUSADER AVE.
CERRITOS, CA 90703
(562) 403-7039 TEL.
(562) 403-7040 FAX
EMAIL: TURBOSPECIALTIES@AOL.COM
WEBSITE: http://www.turbospecialties-race.com/
Old Nov 16, 2007 | 05:43 PM
  #249
GT3071R is baller.... I got one
Old Nov 16, 2007 | 05:57 PM
  #250
babymac's Avatar
BOOST 4 LIFE!
That is a beautiful site.
Old Nov 16, 2007 | 06:02 PM
  #251
440cc injectors, HKS SSQBOV (got it for free, new so I can't complain) Spearco Bar & Plate IC, turbo specialties manifold and motor mount, 3" V-band turbo back.... 300ZX FP (I do not like Walbro) 300ZX MAF, Emanage Ultimate, PLX M300 wideband....
If I max this baby out, I'm going to step up to a GT3076R in its largest iteration. This is my "starter" turbo that is responsive. I am not done installing all the junk yet- winter is almost here which means no more 5th gen.
I'm thinking of boosting the 3rd gen too....
I've owned way too many SE-Rs in my past, boost can get quite addictive. Especially since I been runing 53J DETs since 1997
Old Nov 16, 2007 | 06:23 PM
  #252
Nealoc187's Avatar
SLOW
what are the specs on the 300ZX fuel pump?
Old Nov 16, 2007 | 07:05 PM
  #253
maximabebe's Avatar
I would also like to know the same thing....how would it compare to the Walbro?
Also, what don't you like about the Walbro. They are a solid unit and have a great rep.
Old Nov 16, 2007 | 07:11 PM
  #254
Walbros are not consistant and I seen a few have residual pressure check valves fail on them. Hard starts are very common on them.
According to RC Engineering 300ZX pump puts out 241LPH, 43psi @ 13.5V. Its pretty much a 255lph pump at 14V. Its very reliable- but kinda loud. I had one in my B13 SE-R 10 years ago, and it sounded like I had a jet engine in the trunk ! OEM > Walbro.
Old Nov 16, 2007 | 07:34 PM
  #255
kzoosho's Avatar
SO you think i should get that 300 fuel pump before a walbro?
Old Nov 16, 2007 | 07:39 PM
  #256
Its like 3x as much $$$ as a Walbro, just to let ya know it lists for like 350 bux I believe.
Old Nov 16, 2007 | 07:40 PM
  #257
kzoosho's Avatar
O wow ima cheap *** lol. I will look into it. Now which pump is it so i can search for it.
Old Nov 16, 2007 | 07:43 PM
  #258
http://cgi.ebay.com/ebaymotors/WALBR...spagenameZWDVW
This will work just fine.
Old Nov 16, 2007 | 07:45 PM
  #259
kzoosho's Avatar
OK cool. I will deff look into that.
Old Nov 17, 2007 | 03:39 AM
  #260
00SEMAX19's Avatar
Not a bad deal.
I wonder if a used or new 300z or possibly a Q45 pump would work. Anybody know the pressures and fitment issues that may be of issue?
Old Nov 17, 2007 | 06:05 AM
  #261
babymac's Avatar
BOOST 4 LIFE!
Originally Posted by 00SEMAX19
Not a bad deal.
Just get a walbro, there is no need to spend triple the money
Every major engine build up from supra's to civic's all use walbro's. There is nothing wrong with them.
Old Nov 17, 2007 | 09:14 AM
  #262
Q45 pump is just as expensive as the Z one, I think it flows alot more. On a Q45 there is a fuel pump control module that varies the output of the pump.
G50 is the pump you would want to use, later models use a smaller pump.
I just do not trust Walbros.
Old Nov 17, 2007 | 09:19 AM
  #263
doc2278's Avatar
I have a Walboro on in my tank, and no problems as of yet
Old Nov 17, 2007 | 10:25 AM
  #264
babymac's Avatar
BOOST 4 LIFE!
I have never heard a problem with a walbro and like I said before EVERY major build up uses a walbro or two in some applications. I would probably trust a walbro over any oem fp.
To each his own...
Old Nov 26, 2007 | 04:18 PM
  #265
fawad's Avatar
Hello,
My name is Fawad Rafiq. Question for the Doc2278. Did you ever finish that turbo project you started. I just recently joined Maxima.org, I was going to but the same exact kit until I read this Thread. Can you please reply becuz I'm like a deer in headlights. I also called Doug Adams at turbo specialties. He said he can give me the kit for $1900.00. Would the piping and the rest of the parts would work if I were to go the GT3076r or would it not. Please if anybody can help me or give me suggestions of what you think. I'm kinda lost.
Old Nov 26, 2007 | 04:31 PM
  #266
You are gonna have to modify your manifold to accept a T3 turbo and a external wastegate if you want to run a GT3076R. I thought bout doing that turbo on my car, but GT3071R was plenty fine.
Old Nov 26, 2007 | 08:25 PM
  #267
fawad's Avatar
So let me ask you this, rest of the kit without that t28 turbo is fine as long as you get Gt3071R which one of my freind recommended. I guess so get the adapter flange which will adatp to the Gt3071R. Do you have to upgrade any of the fuel components or anything in that nature. In other words this kit still would be 100% complete, just get the different turbo I guess. There are not any fitment issues are there ?
Old Nov 26, 2007 | 08:41 PM
  #268
03CTMax's Avatar
congrats, wish i had the $$$ to do it
Old Nov 26, 2007 | 08:57 PM
  #269
t6378tp's Avatar
Turbo 3.5
this is good new for the kit, wonder what the price will be
Old Nov 26, 2007 | 09:06 PM
  #270
doc2278's Avatar
this kit comes with a set of auxiliary injectors that attach in front of the throttle body. There is an injector phase computer to prevent knock. Welcome to boost if you buy the kit. To answer your question Yes, Im going bigger turbo (just got sponsored by Turbospecialties). I will put on a photo How to (if you will) On how to upgrade the kit. I will do my best to give you a step by step approach. Welcome Fawad to the org, I look forward to assisting you in your venture with this kit.
Old Nov 26, 2007 | 09:07 PM
  #271
doc2278's Avatar
Hello,
I did finish the project and the car runs great, now its time to upgrade the boost !!!!!
Old Nov 26, 2007 | 09:10 PM
  #272
doc2278's Avatar
Blackbird, keep me updated on your progress and power #'s. I Look forward to seeing your kit complete!!!!!!
Old Nov 26, 2007 | 09:43 PM
  #273
00SEMAX19's Avatar
So you install the injectors in the intake like you would a shark nossle for nitrous? That is much easier than I was imagining.
Old Nov 26, 2007 | 09:52 PM
  #274
This kit has a T2 flange on the "manifold" and GT3071R is THE largest T2 turbo you can buy. Its more like a rather large T3 turbo, its just a smaller frame/smaller flanged turbo.
Internally wastegated so there is less work to be done. If you do buy the turbo, make sure you get the right kind you need, the 4" inlet one supposed to help with compressor surge.
Also I highly recomend you upgrade the injectors, this "piggyback" fuel control unit is kind of ghetto. I'm affraid that with fuel being sprayed infront of the TB some of the cylinders will get more fuel than others. I would want all 6 cylinders to get exactly the same amount of fuel. If they don't.... you will be doing a engine on your car soon.
It might not be a big "issue" at lower power output- bellow 300WHP, but once you are into the 400+ WHP you will DEFF want to ditch the stock injectors for larger units. There are quite a few diff choices for injectors- 5th/5.5 gen guys can use anything 350Z uses, and 4th gen guys can use 95-96 300ZX TT injectors, 94-96 Q45 injectors, or any SR20DET injector- those are all 370cc. There are many choices available to us.
I dunno if you ever heard of AMS, they do some big # EVOs.... friend of mine does their advertising and PR work. I won't stop till my Max wins Ultimate Street Car Challenge by SCC :P
Old Nov 27, 2007 | 04:17 AM
  #275
cld12pk2go's Avatar
Ditto what Blackbird said on the pre TB injectors.
You can definitely get uneven distribution that way, which can lead to a large AFR spread between your cylinders if you are trying to supply too much fuel through them. Where that threshold is is anyone's guess.
However, your WB02 won't tell you that you have this problem. It will be either you reading your plugs (if you are lucky) or from picking up piston pieces.
Good luck.
Old Nov 27, 2007 | 06:28 AM
  #276
fawad's Avatar
Hey Doc,
This is newbee again (Fawad). I really appreciate this Doc. Now I can finally get a turbo after a long time. Just didn't want to throw my money away. I'll be looking forward for those instructions and how to's. I mean I can do the work myself just need some guidance. By the way I had GT3071R in my mind. Do you think that be good or would I have to modify whole lot of fuel system or what not.
Old Nov 27, 2007 | 10:39 PM
  #277
2kMax103's Avatar
i was under the impression if you got a turbo any larger than a t2 for instance a t3/t4 the IC piping at 2 inches would insuffcient and larger piping would be needed. But i guess with the GT3071R you can just get the adapter flange to make it work.
Old Nov 28, 2007 | 10:10 AM
  #278
i30dvr's Avatar
that is might thought as well but i was wondering if larger piping would fit....any clearance issues using 2.5in piping?
Old Nov 28, 2007 | 10:17 AM
  #279
fawad's Avatar
I think alot of people are curious, especially me. But I guess just gotta wait. Doc said he'll post up the pics and intructions on how to's and stuff. So I'm gonna wait for the Doc.
Old Dec 1, 2007 | 08:45 PM
  #280
fawad's Avatar
Hello,
Hey Doc this is the newbie again, sorry to bother you. I was wondering about the kit so is it okay to buy the kit without the turbo or not. Everything else works out or not like piping and all that other stuff. I'm still looking forward to your finished project can't wait.
