On a Supercharged Max, what is the drain interval
Old May 18, 2007 | 07:38 AM
Fearfox's Avatar
Im going supercharged soon, was curious if those maximas out there if you continue your regular drain intervals with synthetic at 3k or 7k etc. Also for your tranny to do you still follow Oem recommended drain intervals.
Some info about my car
Its Infiniti I 30 99, Auto Tranny.
Old May 18, 2007 | 08:29 AM
David,
For motor oil, 3k. For tranny, 30k. That's what I do anyway.
Old May 18, 2007 | 07:21 PM
matty's Avatar
I do about 2500 on Synthtic but thats cause I dont drive my car all that much...about 150-200 miles a week
I like to have clean oil in my motor
-matt
Old May 20, 2007 | 12:49 PM
ptatohed's Avatar
Licensed to Spell
There is no need to change oil every 3,000. 5,000 is fine. It's been proven over and over with lab tests (wether you're SCed or not).
Auto tranny fluid drain and refill, filter change, new gasket, clean pan and magnets - technically every 30,000 miles but for some of us, that's 3 or more years. It's fairly cheap and easy so I would suggest changing it at 18-24 months if that comes before your 30,000 miles.
In a nutshell, there is no need to reduce your service intervals with an SC. Stick to the schedule you had previous to the SC. You might consider an engine oil cooler and a transmission cooler, but not required.
Old May 20, 2007 | 01:12 PM
VIP Maxima
since u live in LA, who is doing the install for u?
Old May 21, 2007 | 01:03 PM
Fearfox's Avatar
Maxlinegtr is gonna help me with the install.
Old May 22, 2007 | 11:30 PM
VIP Maxima
nice.... he def knows a lot. he used to have a boosted max back in the days. he also did his own 5spd swap. def will know the how to's
Old May 23, 2007 | 12:31 PM
TJ_Max's Avatar
Paradox Systems Vendor
I agreed with post 4. Oil changing intervals are getting larger, but these damn oil filters still need to be changed.
Old May 24, 2007 | 02:08 PM
Ziggyrama's Avatar
The only real way to know is to test your oil. Get a sample out to Blackstone Labs and have it tested. FI cars are usually harder on oil than NA cars just because the temps at loads are higher. Also, oil does work in the SC as a cooling agent, if I am not mistaken. So, it does do more than just lubricate. I'd say do the first oil change at 3K, test the oil and if it comes back as fine, extend the drain interval to 5K and if you're really curious, test again.
The key is to pick the right viscosity and use quality lube that will hold up to the punishment. Some oils are better than others but I'd rather not get into that. Everybody's got their own favorite.
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
Apr 16, 2020 05:15 AM
Forge277
Jun 13, 2016 09:26 PM
