550 with a32 maf
Old May 28, 2007 | 12:37 PM
95turbo gxe's Avatar
550 with a32 maf
Ok im wondering if I can run my 550's with emange ultimite and the stock a32 maf? Im not worried about maxima it out as I can clamp the voltage and tune with my pressure sensor from their! But Im wondering if I could control them to with the a32 maf?
Old May 28, 2007 | 01:53 PM
RA030726's Avatar
I'm nutty for Nissans
whats your peak voltage? whats your hp level?
Old May 28, 2007 | 02:04 PM
not sure the car will up and running some time this week! Im clamping the voltage at 5.00 though
Old May 28, 2007 | 08:14 PM
DandyMax's Avatar
3.5 in the works
I'd clamp it a bit before that personally, maybe 4.7 or 4.8. You will have to adjust the fuel with EU most likely, as I said in the PM but as long as you have the pressure sensor to go past the limit of the MAF you'll be fine. Keep in mind you'll need to adjust fueling for intake air temp also when using a pressure sensor...
Old May 29, 2007 | 09:48 PM
streetzlegend's Avatar
clamping meaning letting the boost/map sensor take over for tuning?
Old May 30, 2007 | 08:36 AM
Clamping meaning that it wont let the ecu see more than 5v that way the car dont just die!
TallTom
57
Oct 14, 2025 05:16 PM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
ballerchris510
Sep 10, 2015 09:35 PM
