sandwich plate on VG
Old May 30, 2007 | 06:05 PM
akurtzer57's Avatar
got a 1991 max VG30E need a sandwich plate or some sort of adapter for my oil filter on turbo setup any ideas
WILL THIS WORK?
http://cgi.ebay.com/ebaymotors/ws/eB...7721523&rd=1,1
Old May 30, 2007 | 06:41 PM
mtcookson's Avatar
Are you just wanting to reposition the oil filter or need it for an oil feed to the turbo? It does need to be repositioned but I would use a 300ZX or 2nd gen Maxima setup for the oil filter. Just a little tube that the filter threads onto instead of the big aluminum piece.
As for oil feed to the turbo, there's a bolt on the left side of the engine, on the front, that is the oil feed for the Z31 Turbo. Crappy picture, but this is the location:
Old May 30, 2007 | 07:23 PM
95turbo gxe's Avatar
or for moving the oil filter down if need you can do the pathfinder oil filter its just a thread rod that the oil filter goes on with out the big aluminum peice. Ethier way it should work out for you.
Old May 31, 2007 | 02:23 AM
Big_E-Dog's Avatar
2nd Gen Boostinator
good luck gettin that damn aluminum peice off in the engine without removing that dang power steering rack or the exaust y pipe, it has 4 bolts that go on it and the top one is the hardest to get off, then like 95turbo said you could use tha pathfinder nub but why not just a 300zx oil cooler?
matts95max
Apr 23, 2025 10:44 AM
knight_yyz
Nov 1, 2015 01:34 PM
ricky7780
Sep 24, 2015 06:50 PM
