s/c intercooler question
Old Jun 11, 2007 | 09:28 AM
liqidvenom's Avatar
brotherhood of tq
sup guys, I fully understand that a fmic on a max is a custom job and will vary from car to car depending on the parts used. I was just wondering those of you that have a vortech and a fmic what path did you route the charge piping and what were the dmensions on the fmic that you guys choose.
also for those of you that are with blown what type of fmic do you guys have?
im a bit "curious"
Old Jun 11, 2007 | 09:47 AM
absoundlab
this has been covered mayn times over.
here are some pictures to help you
Old Jun 11, 2007 | 03:00 PM
liqidvenom's Avatar
brotherhood of tq
thank you for you pics and taking the time to post them, i understand that this has been talked about many times before and i have done some reading up on it but....
ehh never mind i'll just search and pretend i never asked.
Old Jun 12, 2007 | 11:54 AM
im a bit "curious"
It varies more than "car to car depending on the parts used". My advice is to not just follow in the footsteps of others and just use someone elses IC dimensions. Find the shortest path possible, buy and read "Supercharged" by Corky Bell and read the intercooler chapter a few times. Then choose your intercooler based on the power YOU are putting down, then go a little bigger to allow for growth/future upgrades. There's a lot of variables to consider when getting the right IC. What's good for one person is not necessarily good for you.
The only person who actually documented air temp difference, difference in psi (before and after), hp before and after, and did an actual study/review of his IC is Stephan Max, to the best of my knowledge. IIRC, Stephan netted a zero gain. If I"m forgetting somebody else, I apologize in advance.
Old Jun 17, 2007 | 11:38 AM
LatinMax's Avatar
My car is going to be different (since it is a 2000) but I did loose alittle boost. But mid range was a little stronger on the powerband. The only thing I would have done wqas go with a little smaller FMIC. I even bought one to put in there but got lazy and am going to change it since I am selling.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
