apexi auto timer
Old Jun 11, 2007 | 11:49 AM
absoundlab
apexi auto timer
does anyone here have an apexi auto timer installed in there car?
Old Jun 11, 2007 | 12:20 PM
JeEvE's Avatar
I have one, it works good.
Old Jun 11, 2007 | 01:03 PM
absoundlab
alright I have some questions about the wiring. did you buy a vehicle specific harness?
they dont make one for the 5th gen so this is what I came up with so far :
gray - parking brake switch (which wire on the parking brake switch does this go to?)
black - ground
white - o2 sensor signal
red - 12 volt constant
blue - IG2 output (where is this and what is it?)
green - IG1 output (where is this and what is it?)
Old Jun 11, 2007 | 09:38 PM
JeEvE's Avatar
I didnt use a harness so I looked at the factory service manual to find the correct wires. I wired everything up except for the o2 sensor. Not sure if the wires are the same color but I can check for you tomarrow if I get a chance before work.
Old Jun 12, 2007 | 05:35 AM
absoundlab
alrigh thank you
I know where the red and black wires need to go.
for the parking brake switch which wire does the gray wire tap onto? (ground?)
I can probably figure out the o2 signal wire
my main thing is figuring out the IG1 and IG2 output I have noe clue where that Is
aw11power
Oct 10, 2021 04:57 AM
AaronL
Aug 8, 2020 10:31 AM
BobTX10
Oct 7, 2015 08:43 AM
dshinn
Sep 26, 2015 08:07 PM
