SC: 5th gen vacuum line placement & fuel line final questions
Old Jul 9, 2007 | 01:55 PM
Ephraim's Avatar
so im about ready to do my supercharger install this coming friday and satuday.
where are you 5th gens putting your two vacuum lines that are attached to the black box on the stock intake?
also for the fuel line, i bought some rubber lines from autozone or napa, i forget which, awhile ago and recently i noticed that it says 50psi max. should i be looking for higher rated fuel lines?
Old Jul 9, 2007 | 03:42 PM
matty's Avatar
Try and zoom out a bit but I believe the larger vac line is the front valve cover breather, which is taken off and a simple small breather filter goes onto the valve cover.
The other one, I would have to see more of it
-matt
Old Jul 9, 2007 | 05:13 PM
Ephraim's Avatar
Line 1 follows the throttle cables across the front of the intake manifold
Line 2 makes a T and goes into the VIAS and the Sensor i marked
Old Jul 9, 2007 | 06:30 PM
matty's Avatar
Its fresh air for that boost sensor which is pointless, and fresh air for the VIAS, another thing you can do without
-matt
Old Jul 9, 2007 | 07:06 PM
pmohr's Avatar
No more Maximas...
Did you get fuel line or fuel injection line?
Old Jul 9, 2007 | 08:00 PM
Ephraim's Avatar
well it is a rubber hose, not a solid rail.
i was just following the list here http://forums.maxima.org/showthread.php?t=455158
#13: 5/16th fuel hose
so anyone do anything special with the vacuum hose i have marked as '1' ??
Old Jul 9, 2007 | 08:05 PM
Tatanko's Avatar
Bacon Lover
It makes a difference which type of hose it is, different pressure ratings. I found this out the hard way during my 00VI swap.
Old Jul 9, 2007 | 08:08 PM
matty's Avatar
"#1" is not a vaccum line so its really nothing important. When you do the install, tie that into a fresh air line coming from "before the TB"
-matt
Old Jul 10, 2007 | 08:03 AM
Ephraim's Avatar
-matt
well now you getting at my original question, which is where is that line being placed.
-is it tapped into the air filter
-is it tapped into the intake tubing
i have looked extensively and have not found a definitive answer on relocating these lines for a supercharger install, or a turbo install.
should i assume that these lines are on the stock intake stuff for the soul purpose of receiving filtered air? if that is the case then i could probably just get it hooked up through the crank case filter that is used for a SC install.
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 11, 2015 12:23 PM
N2deep
Aug 16, 2015 08:30 PM
maxinout93
Aug 16, 2015 07:25 PM
Max Nu-BE
Aug 11, 2015 06:34 PM
