Vortech Bolts - Timing Cover Leak?
Hey,
I recently boosted my 4.5 gen (V2 Kit), and I'm missing a bolt or two on the plate (attaching to timing cover).
I noticed that I was leaking oil onto my alternator, and went ahead and swapped valve covers, yet the leak is still there. I've come to realize that it's coming from the timing cover. My question is, can the bolt or two that's missing from the plate cause the oil to leak (can the blower be pulling the timing cover up a bit?).
I don't know what's up, I have big plans for the car, but can't do anything till I fix this leak. If someone could shed some light on the subject I'd appreciate it.
Also, does anyone have the exact specs on the bolts that attach the blower to the timing cover, or know someplace to get them. Need help ASAP fellas....thanks in advance.
Originally Posted by 98MaXeDouT
Hey,
Which bolt are you referring to exactly? Look at page 62 of Josh's supercharger install writeup for a diagram of the plate and the all the bolts that go with it.
http://www.ericj.org/maxima/doc/scifd.pdf
Josh spent countless hours putting that writeup together. It's a shame more people don't read it, follow it, and get valuable information from it. Stillens instructions are even included as a reference.
Sure about the timing cover? It's often the oil drain back plate associated with the SC install.
Trust me...I;ve done the install 10x. It's not the drain back plate. The oil is coming from the timing cover
So did you have a leak before the SC install?
No...I had a leak a few weeks after, and it was the drainback hose on the blower side. I fixed that, and now notice the oil was also leaking onto the alternator from the timing cover...I'm hoping I can just add these bolts when I get them, and not have to reseal the timing cover. I got my fingers crossed.
Hey,
Im on my 2nd motor and im going thru the same poop you are. Im tierd of the freaking oil leak...Dont know what to do.
Anyone know what length??
I know the thread is M6...unsure of the length...
Originally Posted by C MAX
i had the same problem the oil leaked right on my alt and blew it out. the bolts are 10mm and you can build them up with washers. the original standoff bolts lock the timing cover to the motor before you put the sc on. when you tighten the sc you are pulling the cover away from the motor. if you lock down the cover before you put the sc on your car shouldnt leak, it worked for me.
Is it possible you guys are overtightening the bolts which mount the plate to the engine? Stillen provided torque specs for a reason.
Originally Posted by matty
I dont understand that either...build them up with washers ?? please explain
-matt
-matt
I think he means that if the bolts are too long, you can always add some washers and lessen the amount of bolt going into the plate/timing cover.
I'm confused by your post......which bolts are 10mm?? OEM? The timing cover is not threaded itself, so I don't see how the cover would be pulled away from the motor when the blower plate is installed. Once the plate is mounted to the engine, the cover is just like it was before the install, and snug as a bug.
...and i just went out and torqued them down to spec, cause it was bothering me so bad after i read this right before i went to bed.
Picture ?? I never heard anything about these
How can you put anything between the plate and the timing cover and still have the belt line up...
BTW: I am lost
-matt
BTW: I am lost
-matt
I never heard of such a thing. Im sorry but I thought you just put the bolts in the case and your done.
I dont think this exists for the V1 install http://forums.maxima.org/showthread....ht=stand+bolts
Maybe take some pics ??
-matt
-matt
-matt
-matt
i can try to get a pic but it's hard to see with the plate on. on the timing cover near the thermostat the cover indents about a 1/2in from the rest of the plate. these bolts have a 1/2 in head build up and you put them in before you remove the rest of the bolts to put the plate and creates a flush environment for the sc plate . it locks the cover so it doesnt move and leak while installing the sc plate. the screw is a 10 mm bolt with a 1/2in head that threads right thru, and after you drop the plate over it you screw straight thru the plate and the bolt. i forget you work a lot with the v1 plate, but this is one of the main reason's why people had belt issues because they never knew these exsisted. i have never had belt issues, you can ask tj max 98maxeout and everybody else that i have met, my belt has never and will never have a belt issue as long as it's installed properly.
And yes, he's NEVER had a belt shredding problem
the timing cover can be pulled back if you dont lock it, thats why stillen provided stanoff bolts, if you have any idea what those are. the 10 mm bolts used to lock the plate are not oem you have to build them because stillen doesnt make them anymore. i built a few for people in the past who had this problem and it worked fine. i can get stillen to make one but it's very costly.
They screw into the engine just like the OEM bolts did. Then the plate gets mounted and the bolts secures the plate to the standoff bolts. How is this "locking" again? It isn't. This isn't rocket science. There are there simply as more points to connect the blower plate to the engine. You even say it yourself in the text below. If someone was to remove the OEM bolts and get longer bolts to try to secure the plate to the engine, w/o spacers, standoff bolts, or anything of the sort,then they would be making a very poor decision and asking for problems. IMO, if one doesn't have the proper standoff bolts, they should leave the OEM bolts intact and not mess with it at all. The plate has enough mounting points as it is.
IMO i believe shredding issues has more to do with a properly aligned plate and blower more than it has to do with v1 or v2. think about it, if the plate is not perfectly parallel with the timing cover in both lenght and width, you are going to shred your belt.
IMO, installing the plate to the engine is idiot proof and can't be screwed up, provided you use the correct bolts and follows Stillens instructions or the SCIFD. If someone can't do that right, they shouldn't be installing a SC to begin with. How can it not be properly aligned if using the correct bolts etc etc and not trying to McGyver $hit with washers, incorrect bolts and stuff????
stop being macho it is not idiot proof, that kit has some hard to reach bolts and if there not aligned properly you will get flex which leads to shredded belts.
I hate it when people make a bigger deal out of something than it really is. Sure, the kit has some hard to reach bolts, but what do hard to reach bolts have to do with flex and installing the plate correctly? Nothing, absolutely nothing. Your logic makes no sense whatsoever. Or maybe you just stink at explaining what you mean. The plate goes on one way, and one way only. After installing the plate using the numerous easy to reach bolts, the individual should then attempt the hard to reach bolts. Since all the other bolts are in place, the hard to reach bolts will line up by default. IF, and this is a big IF, the final hard to reach bolts don’t line up and screw in smoothly, the individual should loosen the other mounting bolts just enough to wiggle the plate ever so slightly, so that the remaining bolts can be installed properly. This is not rocket science, it’s common sense. Then all the bolts should be tightened properly given the torque specs in the Stillen instructions. After using the correct bolts and installing it per Stillens instructions (ie correct torque etc), a perfect install will be achieved every time. A flexing plate is total bs IMO. Until you have real proof, please stop spewing misinformation.
i.ve owned a few sc kits since the early 90's so i know them very well.
i had the v1 and several v2's and havent had any issues at all. either way his car is fixed after following my advice so the issue is dead. p.s i also have one of the baddest sc maximas in ny lol, so that's proof enough i know my stuff.
if you brought a kit brand new from stillen they provide standoff bolts. they lock the timing cover in place prior to the sc installment. i have been installing these since 97 and have brought several brand new sc's from stillen so i know exactly what im talking about. and matty for you to ask such a question is shocking i thought you knew all about this, but either way 98maxeout i can probably meet up with you and show you exactly what you need to do.
All is good. Carry on.
MaximaDrvr
Aug 19, 2015 08:20 PM
