Rear Mounted Oil Cooler
Ive mentioned it before a couple of moths ago, So I finally did it!!! 190 Degrees at running temp!!! Its a Perma Cool 450hp rated oil cooler from Jegs. Gets more air flow than you think.
Rear Mounter Oil Cooler.......
My car with no oil cooler is about 205-210F on the highway under constant cruise. But I can get the temps up to 300 if I get on it alot - like road racing.
I finally got my Nismo (6 month backorder) T-Stat for 3.5L and I am hopping with the reduced engine coolant temps- the oil temps will dip down into lower 200s under high RPM stress road racing puts on the motor.
Originally Posted by BlackBIRDVQ
Yeah 68*C which is 154.4*F.
Courtesy Nissan lists em for 150 bux, and I don't like shopping with em. Especially since I know how much em T-Stats really cost. So I waited.
I'm still thinking of getting one though. Just semi-worried about the car not getting to operating temp soon enough. Ah well, if that is the case, I'll just switch it every May/October.
Originally Posted by absoundlab
why is it in the rear?
mounting it in the rear seems to far away to be useful
I hope you have a return pump or the engine may not like it.
I wonder how much air flow it really sees on that thing.
Did you run that cooler with rubber hoses under your car? That is another bad idea.
Originally Posted by EnervinE
How much extra oil is needed for that setup? Seems like oil changes should be fun, trying to get all of the oil out of those lines...
Originally Posted by DanNY
do you also have a pressure gauge? did it drop from running the cooler back there?
I drive 2hours round trip for work 100 miles total a day. at 3500 miles thus far, the oil has NOT changed color. looks like its working to me.
steel braided at points. the rest is wrapped in thermal wrap where needed.
Matt93SE
Apr 8, 2018 09:23 AM
Huttig2009
Sep 25, 2015 03:31 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
sometimes.
