Broken Pintles :(
Old Aug 15, 2007 | 02:52 PM
BlackCat's Avatar
RIP '98 Maxima SE
Broken Pintles :(
I just got a set of 370cc injectors and found all 4 of them to have broken pintles. Is it necessary to have them replaced? If so, where would I find replacements?
Old Aug 15, 2007 | 02:59 PM
mtrai760's Avatar
'Trynna' is not a word
Are you going to have them cleaned before installing? Most places replace the pintles and gaskets for you when cleaning.
Old Aug 15, 2007 | 03:18 PM
BlackCat's Avatar
RIP '98 Maxima SE
I've checked my yellow pages for fuel injector services and emailed one place close to me to see if they could repair them.
I've got a Z32 maf on its way here. Found a guy selling it in Florida on the FreshAlloy site and in conversation found out that he's coming up here to attend a wedding. Funny coincidence, eh?
Old Aug 15, 2007 | 03:41 PM
BlackCat's Avatar
RIP '98 Maxima SE
$35.00 apiece for flow testing at this place I contacted.
I just looked at one of the broken pintles and its just a simple plastic ring. The guy I spoke said that he couldn't fix them and I went huh? Where can I get replacements?
Old Aug 15, 2007 | 08:10 PM
Nealoc187's Avatar
SLOW
$35 a piece and they can't even perform the simple act of replacing a pintle cap? hah - avoid that place like the plague.
http://www.deatschwerks.com/catalog/...r_services.php
$16 for basic, $21 for dynamic. both services are going to blow the services of someone who can't even replace pintle caps right out of the water. both of which also include brand new pintle caps by the way...
Old Aug 16, 2007 | 01:34 AM
96_vqmax's Avatar
so neal,what's the different between basic and dynamic?sorry for the OT BlackCat,thanx.
Old Aug 16, 2007 | 06:22 AM
Nealoc187's Avatar
SLOW
dynamic gives you results for before cleaning and after cleaning, so you can know how they changed with cleaning, and gives you dynamic flow rates at 75% duty cycle and a bunch of different fuel pressures as opposed to just static flow rates. static flow is the flow rate when the injector is just open 100% of the time, 100% duty cycle - that's the # you read when you say you have 370cc injectors or 555cc injectors. their dynamic flow will be less, and that is the flow that you can actually see when the injectors are in operation in your car.
edit: btw I don't work for deatschwerks so you probably want to call them up to confirm anything else that might differ between the two. I just like their product and the guys there so I support them and I know a little about their product and services.
Old Aug 16, 2007 | 08:05 AM
BlackCat's Avatar
RIP '98 Maxima SE
I just received a 2nd set of 370cc injectors and noticed that the pintles on them are different from my first set. Both sets are the purple side feeds.
The 1st set has pintles that look like it has 4 prongs and the 2nd set are prongless and are smooth instead. Now I'm confused as to which pintle is correct.
Old Aug 16, 2007 | 10:16 AM
BlackCat's Avatar
RIP '98 Maxima SE
Found a place that will help me out.
http://www.fredholmesfuelinjection.com/
Old Aug 16, 2007 | 01:54 PM
Nealoc187's Avatar
SLOW
that's not the place that isn't able to replace the pintle caps is it?
Old Aug 16, 2007 | 02:25 PM
BlackCat's Avatar
RIP '98 Maxima SE
Oh no! This name I found recommended in a local car enthusiast website.
Old Aug 16, 2007 | 10:43 PM
96_vqmax's Avatar
thanx neal,i know u don't work for deatschwerks,you just love their product,i'm too like you,like mike at deatschwerks,he's i30 is what i'm aiming to do the same maybe.
Old Sep 13, 2007 | 05:25 PM
doublea's Avatar
About deatschwerks injectors...
I'm currently building my VQ30DEK, so I went on deatschwerks website and found the 505cc injectors would be good for my application, so I'm wondering if they directly fit on the max original fuel rail ? I have a 2k1.
AA
Old Sep 13, 2007 | 05:36 PM
Nealoc187's Avatar
SLOW
deatschwerks only sells injectors that plug and play without modification...
Old Sep 13, 2007 | 05:54 PM
doublea's Avatar
Thanks for the answer.
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
tarun900
19
Dec 20, 2021 06:57 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
jerrod99_se-l
Sep 19, 2015 06:54 AM
