MAF position in a boosted application
Old Sep 25, 2007 | 11:05 PM
got_max's Avatar
Wants a real car
Hey Guys, Just a quick question. Ive searched around and havent quite found the answer im looking for.
I was curious as to where you position the MAF in a turbo application. on the intake side of the turbo. or the output side. if on the output side do you put it before or after the BOV. also where do you put the IACV hose in conjunction to the MAF. Im jsut a little confused because some of these things dont seem to add up from pictures ive seen. and pictures jsut dont do justice.
Old Sep 26, 2007 | 07:40 AM
pmohr's Avatar
No more Maximas...
I've seen MAFs here on charge pipes and turbo inlet pipes both.
If charged side, for the least amount of work I'd say BOV before MAF, that way you can run it atmospheric. If the MAF is in the inlet tract to the turbo, the BOV would have to be recirculated (or at least, that's the easiest method). EU has an anti-stall feature for use with atmospheric BOVs, but apparently it's not always an issue; different cars, but some MK3's have all kinds of issues running atmospheric, some oddly don't, and I've got a friend locally with a GS-T running atmospheric and his car doesn't act up after boosting. Those two types of cars have the MAF right off of the air filter, and the ones I've seen have all been on stock ECUs.
In any case, sorry for the ramble, but it should work out either way, if you set it up right.
Old Sep 26, 2007 | 10:50 AM
kzoosho's Avatar
Theres were i put mine.
Old Sep 26, 2007 | 03:19 PM
got_max's Avatar
Wants a real car
hmm thanks for the info pmohr. info helped alot. and thanks for the pic kzoosho. that made things add up alot better. makes sense now.
Old Sep 27, 2007 | 06:07 AM
meximax's Avatar
SC Overspinning Swapper!!
I can't see very well from your posted picture, but it appears that you pressurizing the front valve cover. Please tell me that you have a PCV or check valve somewhere on that line.
Boost in your valve cover is a
Old Sep 27, 2007 | 08:58 AM
dice06z's Avatar
eek @ boost in valve cover
Old Sep 27, 2007 | 04:00 PM
kzoosho's Avatar
for now till i hav ethe peice welded yes i am but hell i aint drove the car ina week so it will be fine. i plan to run a breather on it asap
TallTom
57
Oct 14, 2025 05:16 PM
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
