pictures of my turbo build
Old Dec 9, 2007 | 01:38 PM
  #81
absoundlab
oil sandwich plate
2 - 1/8 ntp - 3an fittings
1 - 3" 90 degree bend
1 - 2.5" flex connector
1 - 2.5" 180 degree bend
Old Dec 9, 2007 | 01:39 PM
  #82
absoundlab
2 - 2.5" 90 degree bends
Old Dec 9, 2007 | 01:59 PM
  #83
t6378tp's Avatar
Turbo 3.5
[QUOTE=absoundlab;6125047]oil sandwich plate
are you just posting pic's of the stuff you want to get or already have
Old Dec 9, 2007 | 02:04 PM
  #84
absoundlab
already have. I got the oil sandwich plate in last week and I installed it on the car already and I went to take a picture of it and none of the pictures came out clear so I just posted the picture from ebay.
Old Dec 10, 2007 | 02:16 PM
  #85
MaxBoost925's Avatar
Drug Money
I need another SD memory card for my camera - my 2gb one went in my girl's Nintendo Wii. I wanna take pix of my parts lying around. haha
Old Dec 10, 2007 | 03:05 PM
  #86
Nealoc187's Avatar
SLOW
no, you don't. well it's ok to take pictures of them, just don't make a thread of a bunch of pictures of uninstalled parts please.
Old Dec 10, 2007 | 04:38 PM
  #87
wunfstmax's Avatar
From the looks of it your going with a reverse y-pipe setup. Your going to need some straight piping as well. Are you going to be doing the welding yourself? Are you going to mig or tig weld it. Are those the actual pipes you have?
Old Dec 10, 2007 | 09:21 PM
  #88
Drug Money
Don't worry i'm not going to haha.
Parts lying around are useless unless installed.
Old Dec 10, 2007 | 11:33 PM
  #89
absoundlab
yes im doing a reverse feed y pipe. I'm going to buy the straight pipes at my local exhaust shop. I'm going to tack weld everything myself and send it out to be mig welded. And yes these are the actual pipes that I have.
Old Dec 11, 2007 | 07:05 PM
  #90
wunfstmax's Avatar
Something to consider is buying the same materials. If you plan on using a used ypipe, then you should have either gotten all mild or aluminized piping. You have a stainless steel flex section, and what looks to be two stainless 90 degree bends. So you could be dealing with three different types of metals(although the aluminized is just mild with a coating), if this is the case you going to have to get the pipes tig welded.
Old Dec 18, 2007 | 05:41 PM
  #91
absoundlab
autometer ultra lite 20 psi boost gauge
autometer ultra lite 100 psi oil pressure gauge
progress on intercooler piping
all the couplers are going to get replaced with red ones. and also of the couplers that you see are going to be removed and the pipes are going to be welded to reduce the number of couplers in the system.
Old Dec 18, 2007 | 05:42 PM
  #92
absoundlab
the 90 degree pipe you see on the left I have to cut it to lower it a few inches and the pipe running across the engine bay that isn't the exact location that it is going to be in.
Old Dec 18, 2007 | 06:07 PM
  #93
gtr_rider's Avatar
192.168.1.1
thats a lot of stickers
Old Dec 18, 2007 | 07:12 PM
  #94
maxine'sMan's Avatar
+1
that sure is one clean bay tho.. lookin' good.
Old Dec 18, 2007 | 07:17 PM
  #95
redmaxpa007's Avatar
i SeE what you did therE
very nice indeed
Old Dec 18, 2007 | 07:30 PM
  #96
01SilverMaxima's Avatar
yea thats atleast 30 whp right there in stickers!
But really tho, nice parts and good luck with the build.
Old Dec 18, 2007 | 07:46 PM
  #97
00SEMAX19's Avatar
Keep up the good work.
Are you keeping the nitrous on it?
Old Dec 18, 2007 | 08:11 PM
  #98
absoundlab
Originally Posted by maxine'sMan
+1
Originally Posted by redmaxpa007
very nice indeed
thank you everyone and yes im keeping the nitrous but im lowering the shot.
Old Dec 19, 2007 | 03:21 PM
  #99
absoundlab
I made the mounting bracket for the turbo today. It bolts to the turbo and then its going to get bolted to the frame rail. Then I'm going to use angle iron and weld it to the bracket and then bolt the other end to the frame. And of course I'm going to powder coat everything.
Old Dec 19, 2007 | 03:47 PM
  #100
Mad-MAX_SE's Avatar
Still kickin'
you and streetz' RMT's keep me wanting to do a setup like this for my max. Nitrous is one thing, but this to me just seems to be more fun (i like challenges).
One question though, wouldn't you want the turbo to be mounted to the exhaust through hangers instead of to the frame rails? The exhaust is going to move some durring acceleration, cornering, etc. Wouldn't locking down one end of the exhaust cause stress on the other bolts and mounting points along the rest of the exhaust all the way to the motor? IDK, it might be fine, just wondering.
Old Dec 19, 2007 | 03:56 PM
  #101
absoundlab
the turbo feed pipe has a flex connector in it
Old Dec 19, 2007 | 05:52 PM
  #102
95BLKMAX's Avatar
He's doing front mount turbo meng. You can tell by the picture showing the intake tubing routing in the engine bay (along with the many ricer stickers on the hood)
Old Dec 19, 2007 | 06:45 PM
  #103
wunfstmax's Avatar
Find a place where you can mount it to the motor. I used the tranny mount, and haven't had a problem with cracking a weld yet. Just get some flat stock(1/8"), measure the width of the two bolt holes drill, grab another piece of flat stock, weld from the piece with two holes in it to mate up with the turbo mounting flange like this
This way also eliminates the possibility of messing up the threads, or shearing off a bolt(extreme) in the compressor housing.
Old Dec 19, 2007 | 08:24 PM
  #104
absoundlab
I have no clue what you are talking about but ok lol.
Old Dec 19, 2007 | 09:22 PM
  #105
wunfstmax's Avatar
Im talking about the way your going to brace your turbo/feedpipe. If you put it on a solid mount there is a very good chance of you cracking a weld. If you hit a dip in the road, you will mess up the bolts going into the compressor housing. You should really rethink the way your going to brace it before messing up your hard work.
Old Dec 25, 2007 | 12:57 PM
  #106
absoundlab
I finally finished the turbo mounting bracket. I just have to powder coat it. Now that the turbo is mounted in it's final locate I can finish the intercooler piping. I also have all the pre bent pipes for the turbo feed pipe and down pipe. Some time this week or next week I'll make the turbo feed pipe and down pipe.
Old Dec 25, 2007 | 02:16 PM
  #107
Tatanko's Avatar
Bacon Lover
Good to see some real progress.
Happy Holidays.
Old Dec 30, 2007 | 03:08 PM
  #108
Chief Brody's Avatar
Have the ebay turbos improved in quality in recent years? I remember researching a while back and the verdict wasn't too good. Some folks ran then for a while with no problem while others looked like they were glued together!
Old Dec 30, 2007 | 06:31 PM
  #109
accordingtou's Avatar
VQ30 DE T
lol
Op
By the way will your meth be controlled by a map/maf or both?
I'll be using a 3 bar map sensor.
Old Dec 31, 2007 | 09:49 AM
  #110
mtrai760's Avatar
'Trynna' is not a word
Keep it on topic. Thread cleaned up.
Old Jan 5, 2008 | 11:44 AM
  #111
absoundlab
where you see the blue coupler by the turbo that is going to be welded.
Old Jan 8, 2008 | 11:56 PM
  #112
96blkonblkse's Avatar
Looks good man. Hey i got a question, that sandwhich plate thing. Is that only for the feed line? Or can it be used for the feed/return line? Reason im asking is beause theres 3 ports, 1 i can put an oil pressure gauge, one for the feed line, and perhaps one for the return? I dont know if it would work like that but im wondering if it would?
Old Jan 9, 2008 | 05:48 AM
  #113
absoundlab
no the sandwich plate can only be used for the oil feed, oil pressure gauge and a oil temp gauge. You don't want to use it for oil return.
Old Jan 9, 2008 | 11:46 PM
  #114
#1berettaman91gtz's Avatar
your work look really nice.
Old Jan 10, 2008 | 09:28 AM
  #115
nwell2k3's Avatar
I'm curious to see how your going to route the feed and exhaust pipe with the turbo facing the way it is.
Very good build... Do I see solenoids??N2O addict...lol
Old Jan 10, 2008 | 12:36 PM
  #116
absoundlab
yup you sure see solenoids lol. im doing a reverse feed y pipe
Old Jan 10, 2008 | 05:00 PM
  #117
nwell2k3's Avatar
Ok. who is fabricating it for you?
Old Jan 10, 2008 | 05:19 PM
  #118
absoundlab
I am
Old Jan 10, 2008 | 05:40 PM
  #119
kzoosho's Avatar
Thats how.
Old Jan 11, 2008 | 03:08 AM
  #120
00SEMAX19's Avatar
Originally Posted by kzoosho
Thats how.
Who's car is that?
