Cooling system upgrade on FI guys.
Old Dec 1, 2007 | 08:19 PM
streetzlegend's Avatar
Well we've talked about alot of things on here, but I havent really seen much talk about upgrading the cooling system when SC or TC our vq's. If there are stickys or thread on it please lead me the way, but i havnt seen any.
Has anyone upgraded their cooling system, is it something that is needed after one reaches certain HP range. I would like to discuss this topics.
Old Dec 1, 2007 | 08:33 PM
absoundlab
I remember seeing someone on here doing some sort of thermostat upgrade but I don't remember the details about it.
Old Dec 1, 2007 | 08:42 PM
Jime was the 1st to do it on here i think, I have it done as well, its just to lower the temperature, but im wondering what other upgrades guys do if they do anything.
Old Dec 1, 2007 | 08:47 PM
doc2278's Avatar
Doctor D I presume???
I cut in a 4 inch NACA duct into the hood to reduce the temp, works VERY WELL!!!!
Old Dec 1, 2007 | 08:51 PM
You actually saw a temperature drop? Actually yesterday I put washers on the hood's bolts to lift it, at idle with a/c on, temps are lower than before. but while moving, temps are the same, I am thinkin maybe while driving there is pressure over the now-lifted hood and actually not letting the engine bay heat escape.
Old Dec 1, 2007 | 09:07 PM
kzoosho's Avatar
I am thinking about molding a scoop into a c/f hood soon.
Old Dec 2, 2007 | 12:22 AM
The ideal thing is to take air OUT of the engine bay. Air is being forced into the engine via fans/moving airflow. But if that air does not have an easy way out of the engine bay, it just builds up pressure in there, therefore reducing the radiator's efficiency and just heating everything up in general. So the best bet i think is to somehow incorporate something to let the engine bay pressure escape with ease. Hood vents I think would be best best, or like evo's with the reverse scoop thing. but dont think it looks too great on a family sedan.
Old Dec 2, 2007 | 05:26 AM
matty's Avatar
Griffen Radiator Upgrade.
[IMG][/IMG]
[IMG][/IMG]
Old Dec 2, 2007 | 05:53 AM
t6378tp's Avatar
Turbo 3.5
if you want to reduce underhood temps, I have not done anything to my max but for my truck this is what:
2inch cowl hood with air vents that face the winshield (2nd biggest affect)
bigger rad (works great all around)
bigger fans
different antifreeze
lower temp thermastat (this sucks in the winter and does not help much in summer traffic)
coated header (this had the biggest affect)
here's a link about adding functional louves or scoops: http://www.oman4x4.com/hoodvents.htm
Old Dec 2, 2007 | 07:50 AM
That griffin looks alot thicker than the stock one, My stock one started to expand due to the extra pressure, so i purchased an all aluminum one from ebay, almost identical to the griffin except its not as thick, i think the griffin is just slightly thicker.
t6378tp, I guess thats the best way of going about it, the louves. I am still thinking about that one because, i dont wanna sacrifice the look of the car and have it looking odd. A buddy of mine, cutout his own louves a row on each side on his 240, and works so great that his windshield fog's up from the heat coming out of the hood lol.
So far i have the ebay aluminum radiator, slightly modified tstat for a lower temp, my temps are about 199-203, while standing still with a/c on, it can get down to 195. while driving on the highway, its usually at 201-203. I assume those temp's are acceptable, that reminds me, i gotta look on the FSM to see whats the normal operating temp supposed to be.
Old Dec 2, 2007 | 10:39 AM
t6378tp's Avatar
Turbo 3.5
are there any companies that make a 4gen maxima with a slight bluge in it maybe 1inch or with one reverse vents
everytime I do a search for a c/f hood they are either oem or way over the top. I was thinking like you and wanted something alittle different but funcatioal and planned to have it painted to match the car so it does not really stand out
Old Dec 2, 2007 | 11:24 AM
kzoosho's Avatar
I plan to get the oem one and make my own scoop.
Old Dec 2, 2007 | 01:30 PM
t6378tp's Avatar
Turbo 3.5
I am guessing you want a scoop to get air for your intake the problem is he wants to get the hot air out to lower his temps
I do not want a scoop on my car cause it sticks out but a hood with a slight bulge in the center with vents in the rear ,priceless things like that only another maxima owner will notice almost like a mevi
Old Dec 2, 2007 | 02:04 PM
kzoosho's Avatar
You could do a reverse scoupe a louvers maybe?
Old Dec 2, 2007 | 02:12 PM
accordingtou's Avatar
VQ30 DE T
Is the griffin radiator still available? ( I know it use to cost $400+)
I plan to use a Nismo t-stat & rad cap.
Water wetter,motul temp decreaser
I dont know obout daily driving but this combination will be good for a weekend warrior
[IMG][/IMG]
[IMG][/IMG]
Old Dec 2, 2007 | 02:16 PM
kzoosho's Avatar
400 + . O damn.
Old Dec 2, 2007 | 02:18 PM
I think the griffis are still available, however I suggest you look into the one i purchased which is a fraction of the price, i believe 138 Shipped. its on ebay.
Wat mixture do you plan to use? straight up water with water wetter and the temp decreaser? or are u going to have coolant in there as well?
Old Dec 2, 2007 | 02:40 PM
VQ30 DE T
Yeah I Was very close to clicking "buy it now" a few months back.lol
Hows the fan shroud fitment?
I will try my set up in stages (all with nismo t-stat & stock rad)
1.50/50 (It gets pretty cold here)
2.+water weter or motul
3.+Nismo rad cap
4.Ebay rad or griffin(undecided)
I want to see for myself how much these product's affect engine temps/perf.
Old Dec 2, 2007 | 03:46 PM
choray911's Avatar
The Crazy Azz Cracka
Before the turbo install, I had a ram air set up with a scoop from an 84 300z turbo. After the turbo install the temp never moved, even on days when the temp would get up to 105 degrees. The factory radiator finally let go about 6 months ago after 4 years of being boosted. I recently replaced it with the larger capacity Koyo in the Group Deals forum. Not as pretty as an aluminium radiator, but it works.
Old Dec 2, 2007 | 03:50 PM
kzoosho's Avatar
Thats what i was thinking about doing.
Old Dec 2, 2007 | 05:25 PM
doc2278's Avatar
Ohh definitely saw a temp drop,.... I ran it hard and the temp was no higher than a normal run to the local grocery store.
Keeps the engine at a stable temperature in the summer. I calculated 4 inch duct would be optimal for cooling.
Old Dec 2, 2007 | 05:47 PM
Damn that dosnt look bad at all. Im just curious, how is it that engine(coolant) temp can drop if your adding pressure to the engine bay, since that naca duct is meant for intake air into the engine bay rather than venting the high pressure.
Wait, i just noticed you have your filter located in the engine bay! which makes alot of sense of why you see a drop in temperature, probably because although there's still trapped air in there (one that comes thru the grill), ur also inducing colder air lowering the overall temp. btw what temp are you referring too? coolant temp, or intake air temp?
Old Dec 2, 2007 | 06:17 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
hey doc whats up with that website, it makes me curious no more on anything....
i also installed one of thoase naca ducet mine is made of carbon fiber and it rams straight into the intake box...
as for upgraded cooling i put a small after cooler after the turbo for the radiator fluid, like a tranny cooler but looped into the coling system..
Old Dec 2, 2007 | 06:57 PM
doc2278's Avatar
Both, it draws in cooler air as you stated it reduces both. I have to thermometer the coolant, Yet the thermostat keeps the temp at a regulated level. I will say the coolant temp is roughly 180-190. The lower part of the block on the opposing side of the NACA duct is lower than what it was when I didn t have the duct.
Old Dec 2, 2007 | 07:00 PM
doc2278's Avatar
can you clarify what you mean about the website????? Mine is also CF NACA duct.
Old Dec 2, 2007 | 08:59 PM
kzoosho's Avatar
Yea what site. I am planning on doing the duct also.
Old Dec 2, 2007 | 11:36 PM
t6378tp's Avatar
Turbo 3.5
yeah chris the scoop looks great, when gene told me about it I thought it was like this one:
you ever get to the track with your car
Old Dec 3, 2007 | 08:06 AM
kzoosho's Avatar
Any word Doc?
Old Dec 3, 2007 | 04:46 PM
doc2278's Avatar
My vb is on its way out, Im waiting for the modified vb to get here. not uncommon with boost. I m going to have to wait for our early spring track day
HOW's THE 5-SPEED TREATIN YOU??
doc2278's Avatar
Any word Doc?
Im lost kzoosho, any word on what??
Old Dec 3, 2007 | 06:11 PM
t6378tp's Avatar
Turbo 3.5
really your vb is dying, with me it was the tc. the car did not want to engage into gear and was not down shifting correctly
in traffic it sucks but on the highway or road s without alot of lights or stop signs it great. the feels like it has so much more power and hit's so hard in every gear. I can not wait to it the track again
I would suggest buying another tranny and have the shop beef it up with heavy duty clutches, vb and tc while you save up the cash and this way you still have your car while they are working on it or you could get a 5-speed swap for about the same price maybe less
living in jerz a turbo 5-speed would be a blast
Old Dec 3, 2007 | 06:20 PM
doc2278's Avatar
at 100mph, when I step on the petal, rpm's go up: speedo stays the same.--- slowly up to 110mph.
1 and 2 on the at are fine,.. 2 slams heavy but torque is strong,
shifts aren't as strong in 3 and 4, no real problems engaging into gear. I figure its the valve body by the way it behaves.
if it's the tc, I will buy kevlo911's one... if he still has it
Old Dec 3, 2007 | 07:32 PM
doc2278's Avatar
http://secure.mckinneycorp.com/AMAZI...2D4410&eq=&Tp=
in case you guys were interested, here is where I ordered the NACA Duct.
www.mckinneycorp.com
i recommend the 2inch one if you're staying N/A
Old Dec 3, 2007 | 08:21 PM
t6378tp's Avatar
Turbo 3.5
I was not saying you were wrong just telling you what my car was doing when the tranny started to crap out
so I guess a 5-speed is not in your plans
what made you pick that location with your vent
Old Dec 3, 2007 | 08:27 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
have you ever been to 2girls1cup.com?
if you havent dont!!!
has nothing to do with naca ducts!!!
Old Dec 4, 2007 | 04:30 AM
doc2278's Avatar
5-speed is in my plans for either this upcoming summer or fall. I just need a quick fix for now. I know. I am just fustrated with this auto. I know you weren't saying I was wrong. I just think you have more knowledge on these trannies than i do
Old Dec 4, 2007 | 09:29 AM
kzoosho's Avatar
U answered it in a post already lol . I was wonderging about the duct.
Old Dec 4, 2007 | 09:36 AM
Kevlo911's Avatar
Kevlo for President
Toyo red
Griffen Rad
Modded lower temp tstat
300zx Rad cap
Old Dec 4, 2007 | 05:25 PM
doc2278's Avatar
LOL. I personally love the duct method!!! got that BNR-34GTR NUR look to it
chexy IMO
Mckinneycorp takes a little time to deliver, but their product is of HIGH QUALITY!!!
Old Dec 6, 2007 | 11:29 AM
doc2278's Avatar
The temperature of the coolant drops as well due to the ambient temperature dropping in the engine bay. Hot air that was stagnant before is now moved out due to acceleration, thus cooling the radiator faster as well as the coolant lines and engine components. Making temperature regulation much more stable.
