Considering the purchase of a SC setup and..
Old Mar 18, 2008 | 12:42 PM
DJ420's Avatar
Bad Mother Fornicator
..was wondering what I'd be up against after install. Was hoping that some of you knowledgable guys could fill a brother in on whats involved as far as tuning for proper a/f mix, etc. Im pretty much a bolt-on and remove and replace kind of guy.. I understand how boost works in principal. I am more versed in 'upgrading' cars that came with boost from the factory.. but never got involved with ADDING boost.
The kit that I am interested in is '100% complete'. The setup includes a 3.25" pulley, which is good for 9psi, if I understand correctly. It would be installed in a 96 Max, typical VQ30DE motor, with 168k and bone-stock internals. The car is a 5spd. I have a PR intake, y-pipe, greddy sp2 catback, Technosquare ECU, all installed. I have a MEVI ready to be installed.
Upon tightening the last bolt on this install, what will I be looking at for tuning? Adjustment to the FMU only? Will it REQUIRE a SAFC or eManage? Any help offered is appreciated.. I am new to boost, but eager to learn. Thanks!
Old Mar 18, 2008 | 12:56 PM
kzoosho's Avatar
If you can swing it Emamage ultimate is the best tunning device you can come by but you can get by on a SAFCII. I am sing them on my 2 boosted cars. You will want a wideband o2. If you do get emanage there is no need to be able to datalog but if you dont you need one to datalog.
A fmu is not really needed unless you plan to run stock injectors.
Old Mar 18, 2008 | 01:53 PM
With the 3.125 pulley, you won't have to tune a thing. Bolt it up and go!! Your A/F won't exactly be ideal, but it will be within an exceptable range IMO.
Now if you want to play it 100% safe and extract a little more power, then add an AFC and a wideband and learn how to tune with that first. Save the Emanage for latter.
Your stock injectors will be fine. Use an FMU with the standard 8:1 disc
Old Mar 18, 2008 | 08:55 PM
tsaulz's Avatar
Yup. You may want to remove the Technosquare ECU too to make sure that you're not adding too much timing.
Old Mar 19, 2008 | 12:43 AM
Yeah, good catch. The Technosquare ECU will have to go if you become boosted.
Old Mar 19, 2008 | 04:11 AM
DJ420's Avatar
Great info guys.. thanks! Gotta lose the TS ECU though.. I gotta drop that ECU for any boost I add to the car, huh? I realized it had to go under nitrous, didnt realize that s/cing required its removal too.. just go back to stock ecu? or JWT tuned for boost?
Old Mar 19, 2008 | 04:27 AM
98MaXeDouT's Avatar
Yea when boosting it's better to retard timing then to advance it. I would sell the TS and just get a vafc, and a wideband and your good to go. 9lbs doesn't really require you to get the JWT ecu, like everyone said, AFC and your good to go!
Old Mar 22, 2008 | 06:57 AM
DJ420's Avatar
Thanks for the good information.. appreciate it guys.
Old Mar 22, 2008 | 10:15 AM
tbergma1's Avatar
Where are you getting your setup, i am looking for a s/c kit
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
