another rmt up and running!
Old May 23, 2008 | 09:41 AM
XeroX's Avatar
Hella internets
well i finished the the project....and the car is running...
however i got 440cc duetch werks and walbro 255 in with the setup....and boy is is pissin fuel in the motor....i have tried to make adjustments on the eu to compensate....but i cant seem to make any noticeablechanges....
as far as setting up the before and after injector settings...i put 239 as before and 440 as after....but i dont know what to put for duration....maybe this is y i a not able to adjust?? im using emanage ultimate....
please forgive if this is a newb question...but i feel like ive tried everything...
Old May 23, 2008 | 10:25 AM
Kevlo911's Avatar
Kevlo for President
You're most likely gonna have to mess with the Injector lag time
Old May 23, 2008 | 10:44 AM
choray911's Avatar
The Crazy Azz Cracka
What kind of fuel pressure are you running? With Deachwerks 370's I have mine set about 35 PSI
Old May 23, 2008 | 11:11 AM
XeroX's Avatar
Hella internets
how do i adjust the lag time? u meen duration?
as far as fuel pressure im not too sure....i dont have a fpr....
ive been holding back on posting because ima huge newb to all this...i figured i didnt need a fpr if i have the eu....
i have a couple data logs i did if anyone with eu knowledge would like to look at it...
Old May 23, 2008 | 11:59 AM
choray911's Avatar
I'm running the E-Manage Blue, so I'm not sure what the differences in the two are in that aspect. When I put in the 370's I was having the same issue because the greater volume that the injectors allowed would douse the plugs with fuel. Once I lowered the fuel pressure a bit, she ran like a champ. Have the other EU guys kept their factory FPR?
Old May 23, 2008 | 12:35 PM
NismoVQdet?'s Avatar
wow kelly finally did something big to his car, man i thought i was going to be the only one with a turbo maxima in Sac. oh well i guess now there will be 2 turbo maximas running the streets. good luck on the project, i would like to see this setup!
Old May 23, 2008 | 12:53 PM
dfownz's Avatar
I'd say you probably have a wicked high fuel pressure which makes the injectors just dump fuel. An afpr would be the most clear way to solve this issue....I think.
Old May 23, 2008 | 01:00 PM
XeroX's Avatar
Hella internets
yea well i was thinking of pickin up an aem fpr today and setting it to 3bar.....but i figured there has to be a way to adjust the injectors with just the emanage ultimate....
any thoughts?
btw...have i ever met u? i didnt know there was a boosted max here in sac....hmmm....and u know my name....
lol
Old May 23, 2008 | 01:07 PM
umm team-driven ring a bell?
Old May 23, 2008 | 01:12 PM
Kevlo911's Avatar
Kevlo for President
In the Parameter settings, click the I/J tab. Adjust the lag time there. You adjust the injector size there too
Old May 23, 2008 | 01:13 PM
oh im not boosted yet just waiting for my exhaust to be made and my emanage blue to finally come in.. we met WAY back in 06 i think that was the meet at Elk Grove Nissan.. i've seen The Law around but haven't seen you for a while..
Old May 23, 2008 | 01:21 PM
XeroX's Avatar
Hella internets
hmm yea cause i put before as 239 and after size at 440....then i left the duration at 0....is the duration the lag time? maybe put a value of 1 in there?
Old May 23, 2008 | 01:30 PM
Kevlo911's Avatar
Kevlo for President
I/J Size 260 440
I/J Lage Time 0 0.4-1(try different values)
Old May 23, 2008 | 01:38 PM
XeroX's Avatar
Hella internets
hmm ok so leave the before duration at 0....i think im gettin it
would not having that setup properly cause me to be unable to make successfull adjustments?? cause i kept subtracting on the i/j map and it had no effect on my a/r....hopefully yhe lag time will allow me to tune at least lol
Old May 23, 2008 | 02:24 PM
Kevlo911's Avatar
Kevlo for President
Yeah try it out.
Old May 23, 2008 | 06:04 PM
matty's Avatar
My setup with 555's wouldnt even start till I messed with the lag time. Went through two sets of plugs and an oil change to be sage.
-matt
Old May 23, 2008 | 06:29 PM
XeroX's Avatar
Hella internets
well, i tried 1.00 and .4...
at 1.00 it seamed like it was going to stall out...and my a/f did not seem to be effected...and this is with the i/j map1 activated and subtracting 1.00 from everything from 500-3000 rpms...
i let the car idle for a few minutes till it started to get a lil warm...then took it out for a drive...the damn car is drowning! lol....
shouldnt adjustments to the EU while running the car automatically have results? thats kinda what im confused about...adjusting to .4 duration on the after side (under 440) seamed to (i think) have an effect on idle...
what exactly does the duration meen? im not really understanding the concept in contrast to the numbers im inputing...enlighten me?
Old May 23, 2008 | 07:45 PM
Kevlo911's Avatar
Kevlo for President
Try all the numbers at idle and see which one makes the engine act normal.
.1 through 1.4
You should find something good in the .4-.8 range
Old May 23, 2008 | 07:49 PM
matty's Avatar
Are you sure you have all the lower o-rings on the injectors ?? With the uppers, it wont leak outside the fuel rail, but without the lower, you'll just be POURING fuel into your cylinders.
Try your lag set the other way around...start .7 end 1 or something like that. I forget how I have mine set but my car was the SAME WAY. Wouldnt run even with -2.00 accross the entire I/J adj. map until I got the lag time right
-matt
-matt
Old May 23, 2008 | 10:12 PM
95BLKMAX's Avatar
I dont have an EU, so I cant help you on that.
But just to give you an idea, I previously had a Walbro190 with my All Motor setup, and used it in my RMT setup for a few months. FP was set at 51psi for the 3.5 swap.
Not doing ANYTHING OTHER than changing the fuelpump to the Walbro255, fuel pressure went up to 58psi.
An increase of 7psi AT IDLE is ALOT of fuel. Especially with the RC 440s I have.
Once you get the AFPR see where the pressure is and drop it down to the lower half of 40psi, check from there, leave it in the ballpark with fuel pressure adjustment, and fine tune with the EU.
BTW, do you have a wideband to keep an eye on the A/F?
CONGRATULATIONS BTW! where are the pictures!!!!!???!?!!??!?!!?
Old May 23, 2008 | 10:15 PM
XeroX's Avatar
Hella internets
well there was only one set of o rings on the injectors...they just slid on from what i could remember...
im really curious as to know what your talking about with the O-rings tho...
I found that .02 lag time gave it the best idle possible...
its still dumping fuel out the tail pipe so bad i ran outa gas just idling for 10 minutes or so hahaha
i noticed that if i try to subtract 1 from the i/j map even with the lag time at .02 it run worse than if i were to only subtract .5
i guess its kinda dumb to start thinking about this but i think the problem is my lack of AFPR
any thoughts on this?
pics will be up as soon as i get this thing running right so i can get the finishing touches done at the muffler shop...i have a vibrant muffler on right now and it sounds like garbage and WAAAYYYY too loud..
Im gona try a magnaflow muffler, and if possibly even order a non louver type resonator for the b pipe (i hope it wound increase lag but i gota quiet this thing down a bit...)
Pics will be up tho i spent alota time trying to out-do streets setup
as for a/f i have a aem uego wideband so yes...
i also have oil pressure, boost and EGT
not completely wired in other than boost and a/f but they will be in as soon as i get it driveable..
Old May 24, 2008 | 06:04 AM
Requin6's Avatar
sounds like an o-ring problem.
Old May 24, 2008 | 07:33 AM
95BLKMAX's Avatar
an o-ring problem could be assessed by letting the car idle and spraying brake parts cleaner on the injectors at their base. If idle jumps erratically as you spray a particular injector, you have a candidate.
But you dont recall if the injectors had both upper and lower o-rings before installation? ALSO, before installation, you should have lubricated the o-rings with a thin coat of fresh motor oil, just like any o-ring or seal anywhere on the motor, did you do so? If not, pull them all and do it again. The o-rings will crack with the heat and cooling and will eventually disintegrate.
And yes having an AFPR with a gauge will make your life much easier as far as initial tuning and trouble shooting down the road, because Lord knows, with turbo, complete installation is JUST the start, now you'll have a month or two of trouble shooting til everything is working how you want it to lol, THEN you'll be enjoying it.
Another thing, and this is important, you dont happen to have you AEM EUGO's signal going into the EU right? Because that will not work. It will work on its own, but it will feed the EU a faulty reading. EU and EBs are meant to be used with linear output signal widebands such as PLX and Innovate WBs. The EUGO has a curve output so V signal isnt going to be linear, EU will have a faulty signal. If you want to keep your current WB, you may do so but ONLY to use alog with its gauge.
Old May 24, 2008 | 12:24 PM
XeroX's Avatar
Hella internets
well...yea ive been planning ahead lol...
AFPR was one thing i over looked...and i do remember two o-rings i was just confused as do what your talking about lol...
i used wd40 on the injectors not motor oil exactly...
ive installing the DEK injectors in when i did my VI...so i have the jist of how to put in injectors...and unless the duetch werks are different they should be in just fine..
as for the aem UEGO controller...it does have linear output.....on my data logs it gives me perfect readings compared with the actual gauge...i remember i researched that to do death before i got it...aem uego works just fine with the EU....
Im going to pick up and AEM AFPR today and give it a try...ill also try and test my o rings and c if thats the problem..i honestly think with a afpr most of these problems should go away haha
thanks for all the input! ill keep you guys posted with results...
Old May 24, 2008 | 01:03 PM
95BLKMAX's Avatar
o0o0o0, well thats a new peice of info right there. If you say it works and its comparable to the gauge's readings, o0o0o!!! :-D good info!
And yea def. Im sure you're gonna have quite the stroy to tell of where your fuel press was to begin with, what you did to it, and how its running after, etc... trouble shooting! the fun part of b00st!
Old May 24, 2008 | 01:48 PM
XeroX's Avatar
Hella internets
lol yea seriously...
there is a store over here that has an aeromotive AFPR with the gauge for like 190...kinda more than i wanted to spend but i need to get this car running properly..
My main concern is how to gut the oem FPR so that i can install the aeromotive..
I know they sell a fitting on sx7's site...but im trying to do this today...and i know you can gut the oem one...just how do you do it?
Old May 24, 2008 | 01:53 PM
95BLKMAX's Avatar
my FPR came with a set of adapters. One of the plates bolted up perfect to the side of the fuel rail. had a threaded hole at the center to which i put a barb. Ran a hose from there, and take into account the whole T-fitting deal, the sticky is somewhere here.
Old May 24, 2008 | 02:14 PM
XeroX's Avatar
Hella internets
yea i hope the aeromotive im bout to pick up has those parts...if not i guess ill just have to drill out the oem FPR till i get the sx7 fitting...i had to buy one last time for my VI install but thats on the other side of the fuel rail lol....arrgghh...
anyone know if the aeromotive fpr comes with the fuel rail fitting?
Old May 24, 2008 | 02:33 PM
Kevlo911's Avatar
Kevlo for President
*Base pressure (vacuum/boost disconnected) adjustable from 30 to 70 PSI.
*Two -10 AN inlet ports, one -6 AN return port and 1/8" NPT gauge port
*Beautifully finished with type II bright dip red and black anodized coatings.
*Alcohol compatible.
*Fuel Pressure will rise on a 1:1 ratio when referencing boost.
*Fittings Sold Separately
According to ebay
Old May 24, 2008 | 06:34 PM
XeroX's Avatar
Hella internets
yea i read that after i posted lol.
well i went to go pick up a aeromotive AFPR cause they had one in stock at a store here...but then i came and the system was wrong.. but they did have a powerflow AFPR that was cheaper anyways...so i got that with a autometer gauge
im gona attempt to install it...looks simple enough i just cant really figure out what to do with the 3rd hole...? i gota plug for it...i figured u just need inlet and return line...
Old May 25, 2008 | 06:18 PM
XeroX's Avatar
Hella internets
Update:
Well i installed the AFPR and just started the max right now...
no more hard starting problem...idle has settled down CONSIDERABLY...overall throttle response is nearly perfect...
The FPR was suposed to be set at 40psi...i didnt make any adjustments...but im getting a readying of about 38 psi? im going to try to make some adjustments on the emanage with that fuel pressure and see what happens...
I was told to have the fuel pressure set at around 36? or should i just leave it at ~38psi?
Old May 25, 2008 | 06:56 PM
SonicDust187's Avatar
Should be 34psi at idle.
Old May 25, 2008 | 08:23 PM
XeroX's Avatar
Hella internets
hmm thought it was 36..
lol...well, im officially givin up on it tonight...the plugs are completely fouled...
my dumb azz input -9 on the emanage haha......flooded the motor BAD...took out the plugs cleaned em up and put em back in...its started back up again...then completely turned my garage into the black sea of gasoline...then of course i did it again (-9 stupid typo lol)...the plugs are completely toast i need new ones cause the idle is horrible again...
is the difference between 36 psi and 34 at idle a huge difference?
Old May 25, 2008 | 08:58 PM
It would be nice if you had a wideband to see what your idle a/f ratio is. I would drop to 34psi and tune from there.
Old May 25, 2008 | 09:13 PM
XeroX's Avatar
Hella internets
i do have one..
on my data logs im at 10.0-10.4 at idle...
Old May 26, 2008 | 05:54 AM
even at your current 36psi? Then you def need to drop it to 34psi. I do not remember but which maf are you running? a32 or z32?
Old May 26, 2008 | 03:10 PM
XeroX's Avatar
Hella internets
yea its still pouring out really bad...im running my stock maf...
im gona go put some new plugs in it right now and see if at least it starts idling decent again....sigh...
UPDATE:
Well i got new plugs in and it seams to be idling a little better now...
I also re-installed the injectors using motor oil on the o-rings, they were already well lubricated with the wd-40 i used before, i tested them with TB cleaner for leaks...NOTHING...so its not the o-rings...
I turned down the fuel pressure to 34psi...and i still cant seem to lean this thing out...this is starting to become a big pain..gas is still pouring out from the exhaust...
Old May 26, 2008 | 05:47 PM
With no corrections in the EU from 240 (or whatever size stop 3.0 DE uses) to your 440cc injectors. You would need to turn the fp down at idle even more. If you were using a z32 maf of stock maf in 3" housing then you can leave the fp at 34psi. I think you would need closer to 30psi for it to be good as you stand right now. However, since you have the EU, I believe there is a function for injector scaling for larger injectors.
Old May 26, 2008 | 06:10 PM
grey99max's Avatar
LandShark has Cosworth
UPDATE:
Man, go look at this: Use your stock MAF... maybe you can do something.
http://forums.maxima.org/showthread.php?t=562916
Old May 26, 2008 | 06:26 PM
XeroX's Avatar
Hella internets
there is a section on there to scale for the injectors...and i input the stock size as before and after i put 440...ive been messing with the duration (or lag time as some people call it i guess?) and i keep getting varying results...but i guess thats all depending on my FP?
I turned the pressure down as low as 28psi...still had no effect on a/f...
Should i just keep dropping the FP till i start getting some kind of effect on my a/f? Im really frustrated with this...and i think im killing all my brain cells with all these damn gas fumes
as for a upgraded maf...im not going that route right now...there has to be something i can do to get my setup to function without geting a bigger MAF....
