Max boost on VQ35 with stock injectors, fpr, and walbro fuel pump
Old Jul 31, 2008 | 07:45 PM
melvinman2003's Avatar
I want to fabricate my own turbo kit and I have in the past on my Nissan Altima, looks like my biggest tackle is the downpipe and welding that thing. I really just want a few lb's of boost without going overboard. I was thinking a 3-5psi spring in the wastegate with a rising rate fpr and walbro 255lp and running that until I get the emanage ultimate and new injectors due to boost itch haha. Anyone on here running stock injectors and ecu I guess is my real question.
Thank You
_Stephen
Old Jul 31, 2008 | 08:15 PM
NiZMo1o1's Avatar
Turbo Alty huh ? Were you ever on Altimas.net before ? I was Goku ( KA-T )
Anyways back on topic , I think theres only 2-3 2k2 on boost right now.
Old Aug 1, 2008 | 05:44 AM
Ya I was NissanFreak. I had about 10-12 lbs on my car with a rising rate fpr, jwt ecu, 370cc injectors, and a walbro 255lp pump. My maxima is fast with bolt ons and im only looking for 280-300whp. I want it to be more reliable then my altima was. I would blow up things regularly. My engine had about 180k when I rolled it in the the stealership. Had about a quart of oil left in the engine due to bad valveseals when I parted with it. I guess I want to make this car more reliable.
_Stephen
Old Aug 5, 2008 | 05:42 PM
nwell2k3's Avatar
That's a good question. The two 5.5 gen's that I know of, have larger injectors. I think you should get a wide band o2 sensor and J&S safeguard. Atleast you will have some protection for your engine. And slowly turn the boost up. I'm sure someone has or is trying it but have not posted. Try to search for turbo 4.5 gens and Altimas with the 3.5L.
http://www.jandssafeguard.com/.
I just did a quick search for turbo 3.5 and this may help you. You should pm the gentleman who started this thread
http://forums.maxima.org/dyno-discus...psi-turbo.html
Good luck..
Old Aug 5, 2008 | 10:37 PM
NiZMo1o1's Avatar
_Stephen
Yeah I remmeber you , I think you came around the time me , Cthunder(chad) and BlackHornet(Fred) finshed our projects
Old Aug 6, 2008 | 05:41 PM
95BLKMAX's Avatar
Good luck..
That's my thread from when I first turbo'd my car. But it doesnt give any good info. I had 2 boost leaks that I found after the dyno first of all. But by this dyno I already had the RC 440s, 3" MAF, and FP was set to 47-50psi for that dyno IIRC. So it doesnt answer much to his inquire of the stock stuff. Sorry
Old Aug 6, 2008 | 07:20 PM
Even if you run 440's dont you still need something for you ecu. I had a JWT ECU on my altima. If I just put 440's in there it would run extremely rich. Guess maybe I will just go ***** to the wall and get the emanage and just get it all tuned. BTW 95BLKMax ever worry about sucking in water with your turbo like that. Is it by you muffler?
_Stephen
Old Aug 6, 2008 | 07:58 PM
NiZMo1o1's Avatar
_Stephen
JWT ECUs always ran rich , I had the 550 / cobra maf for the ka-t then later upgrade to 72s.. Clark had loads of fun back in the days... that was all before standalone came around in the Y2K
Old Aug 7, 2008 | 07:51 AM
95BLKMAX's Avatar
_Stephen
You're right, it would indeed run pig rich. I had been tuning with an AFC for 3yrs total on my last 3 setups (3.0 NA, 3.5 NA, 3.5 ubber low boost). But even in that dyno there you can see that I wasnt able to really smooth out the a/f much. Needless to say I finally upgraded to an Emanage Blue about 2 months ago and its MUCH better now. Should have upgraded while still NA
Nope, turbo itself sits high up against the trunk's floor board.
http://i32.photobucket.com/albums/d4...f/Muffler8.jpg
http://i32.photobucket.com/albums/d4...f/Muffler7.jpg
As you see, the filter itself (I know its missing there but just imagine, lol) doesnt sit any lower than a CAI filter sits. The rule of thumb is simple "if you wouldnt drive through it with a CAI, do NOT drive through it with RMT".
Old Aug 9, 2008 | 08:42 AM
To 95BLKMAX: Damn thats a crazy setup. Just out of curiousity hows that oil line set up? On my setup I am planning to run a oil filter adapter plate that allows you to t off the stainless steel line to the turbo. My drain line was going to run from the bottom of the turbo to the oil pan with a nipple. You must have a long pipe running to you intercooler. Its just amazing how much power your yielding with that setup.
Stephen
Old Aug 9, 2008 | 08:47 AM
To Nizmo1o:; Ya your right. I actually talked to technosquare about a turbo chip. They dont offer one. So I figured for almost the same amount you could get a emanage ultimate would would be quite versitile. No matter how I look at it im probably spending around $3500 when all is said and done. Thats doing it cheap enough to where its reliable. I talked to someone about putting a turbo kit on there mustang. They thought they can spend $1000 and get it done. I laughed and said good luck. They didnt even know they needed to run a oil line haha.
Stephen
Old Aug 9, 2008 | 08:48 AM
95BLKMAX's Avatar
Stephen
plate like this? http://i32.photobucket.com/albums/d4.../Muffler16.jpg
lol
mine dumps the oil back into the engine through a barb I fitted on the side of the front valve cover. Oil dumps right into the top of the head
Old Aug 11, 2008 | 11:20 AM
NiZMo1o1's Avatar
Stephen
You might want to look into the UTEC , but you might need to do some splicin.. I guess thats why the A33/5.5 used the Emange over the UTEC , Im running the UTEC on a A34 but it all plug and play.
good luck on the project
Old Aug 11, 2008 | 03:51 PM
95BLKMAX's Avatar
UTEC is plug n play on the A34 ECU because its basically the same pinout as the Z33 ECU which they already had done. This is not the case for the A33b and below. So to use the UTEC on those, one would have to splice into it like with any other piggy back.
Now looking at it from a cost-benefit point of view... for the purposes that most people around here use piggybacks, the EU is about the best bang for the buck. UTEC is "noticeably" more expensive (granted, it IS better, but for the purposes of 98% of the people on the org, its not justifiable spending the extra $ for it)
Old Aug 11, 2008 | 04:03 PM
Kevlo911's Avatar
Kevlo for President
No one has gotten the EU to work 100% with the 5.5 gen(I will be trying soon). UTEC is teh way to go IMO
Old Aug 11, 2008 | 07:52 PM
95BLKMAX's Avatar
ah this is a good point! Last time I heard of an EU on a 5.5gen (Jime) it melted the coils. Something about that it needs resistors or diodes put inline bet'n the EU's Ign Output wires and the Coils' wires. That's actually quite common. When installing them on later model BMWs (such as E36 and E46s) one must do the same thing
Old Aug 11, 2008 | 10:27 PM
nismology's Avatar
UTEC FTW.
Old Aug 12, 2008 | 09:48 AM
98MaXeDouT's Avatar
Incorrect....my friends been running it on his Turbo setup for a few months now with zero issues.
Old Aug 12, 2008 | 03:23 PM
bkmaxima's Avatar
Dam white boy you got to it b4 me .. I was about to post the same thing about our lil yardi friend .. lol
Old Aug 12, 2008 | 05:15 PM
Kevlo911's Avatar
Kevlo for President
Is he in NYC?
Any tips? I was gonna use diodes on the setup I am gonna install...
Old Aug 12, 2008 | 09:09 PM
98MaXeDouT's Avatar
Is he in NYC?
It was done at a shop...I'll make a call and see if I can get the exacts.
Old Aug 15, 2008 | 12:23 PM
Deckdout2's Avatar
Play with my balls
UTEC is ftw......in the process of tuning mine at the moment when I find a reputable dyno shop around here. blah.
anyone need a brand new emanage blue, never used?
Old Aug 15, 2008 | 02:30 PM
So I am guessing you guys are running the TurboXS UTEC they make for the 350Z/G35?
To 95BLKMAX:
If your drain lines going to the valve cover, what are you going to do if your turbo one day blows its bearings and you get metal shaving in the top of your engine. I think a filter in between the valve cover and the dump line maybe necessary. Thats why I always ran to the oil pan. Maybe you have that?
Thank you all btw this threads been useful.
Old Aug 18, 2008 | 12:46 PM
liqidvenom's Avatar
brotherhood of tq
clear out your pm box.... i have a questions to ask you.
Note i might have emailed it to you also.
sorry to thread jack
Old Sep 16, 2010 | 04:01 AM
99dkmaxima's Avatar
watch out for vapor lock on the oil pump returning the oil to the engine problem with sts kit in my experiance in AZ
Old Sep 16, 2010 | 09:14 AM
streetzlegend's Avatar
Vapor lock? Can you explain a little more? why would there be vapor lock?
Old Sep 17, 2010 | 08:04 AM
Shift_Max's Avatar
It can be done. Wastegate spring pressure, Walbro 255lph, 350z/g35 injectors ( flow more then maxima inj ) and a wideband. But pressure has to be really low. However better alternative is bigger injectors and a utec.
Old Sep 17, 2010 | 08:26 AM
InfinitiI35Rice's Avatar
The turbo kit made by Speed Force Racing for the 2002 Maxima has 440cc injectors with stock fuel pump etc.. and the get 395 Whp with a fuel tune. Im planning on turboing my I35 and ordering their pretuned computer and getting the injectors to run 5psi boost
Old Sep 17, 2010 | 10:28 AM
Nealoc187's Avatar
SLOW
this is a 2 year old thread guys...
Old Sep 17, 2010 | 10:59 AM
ohh well i didn't even notice
Cotozic
Jun 28, 2017 08:01 PM
00MAXI
Sep 2, 2015 10:23 AM
homewrecker
Aug 24, 2015 08:56 PM
t6378tp
Aug 24, 2015 07:03 AM
Balkins
Aug 12, 2015 06:39 AM
