placment of MAF
Old Dec 11, 2008 | 06:46 PM
d1max2nv's Avatar
placment of MAF
OK i am slowly but surly building my turbo set up, but I was wondering where do you guys place your maf in a 4th gen. I mean I seen some people placing them on the charge side, and other putting them on the intake. Is there a difference? thanks in advance guys.
Old Dec 11, 2008 | 08:30 PM
kzoosho's Avatar
There is a big difference. If placed pre blower you will have a hard time running a blow off valve. U will need to either tune the car for the sudden rich condition or use a recirculating valve. If you run the maf on the charge side you can run a blow of of any type as long as its before the maf. Even on the charged side if you run your blowoff post maf you will have the same rich issue. I choose to run mine on the charge side so i know how much air is actually going into the motor. Personal preference.
Old Dec 11, 2008 | 08:39 PM
akurtzer57's Avatar
also if placed on intake side and trying to use a piggy back will be impossible to tune.
Old Dec 12, 2008 | 12:27 AM
maxgtr2000's Avatar
KH3 by popular demand
I'm not sure about that comment, can you elaborate?
Running the stock maf on the charged side will max it out at 300hp+. Some people go with the z32 maf. My car idles good and I don't have any issues in regards to bovs.
Old Dec 12, 2008 | 08:40 AM
d1max2nv's Avatar
Running the stock maf on the charged side will max it out at 300hp+. Some people go with the z32 maf. My car idles good and I don't have any issues in regards to bovs.[/QUOTE]
I will be running the maf out of a Q45. When you say your car is running fine, are you running the stock maf on the charge side?
Old Dec 12, 2008 | 09:16 AM
kzoosho's Avatar
What are you power goals? U do know that the q45 maf is rather large. I am running one as well.
Old Dec 12, 2008 | 11:51 AM
d1max2nv's Avatar
Well I don't really have a power goal.... however I am going to be running a t3/t4 with a A/R.50 on the cold side and A/R .48 on the hot
kzoosho's Avatar
That will be way too small.
Old Dec 12, 2008 | 10:39 PM
mastercater7's Avatar
VQ35 FTW
Maxgtr2000 is running his maf on the charged side and his car runs fine but hes only running 7 or 8 psi and hes maxing it. On my S/C VQ35 4th gen Im running the 300zx maf and making around 13 - 15 psi depending on the temperature. Im not even close to maxing it at 7200 rpms at max boost on the charged side. I dont know anything about the Q45 maf but if its the same then use that on the charged side. Also, make sure you have either a good piggyback (emanage, utec, etc) or a nice jwt ecu tune because the ecu will receive much different signals than normal.
Zack
Old Dec 13, 2008 | 07:38 AM
essential1's Avatar
My axles cry for mercy...
So according to what I've read so far, it seems as if placing the MAF on the charged side makes drivability/reliability (and tune-ability i guess?) alot more simple. Your only limitation is how much air the MAF is cabable of metering, which is dependant on the type/size of the MAF you're running.
Correct?
Old Dec 13, 2008 | 08:20 AM
kzoosho's Avatar
Correct?
That is correct.
Old Dec 13, 2008 | 12:02 PM
streetzlegend's Avatar
I recommend putting it on the charge side. I have a stock maf, and im in the mid/high 300's, being maxed out of course, but as long as your tune is where you want it your fine. Most wont recommend that of course, if u can get a z32 maf, or make your own for a couple of dollars and pcv piping.
Old Dec 13, 2008 | 01:03 PM
mightyMax95's Avatar
this is EXACTLY the info i've been looking for. thanks a lot kzoosho and streetzlegend! +1 guys!
Old Dec 22, 2008 | 12:07 AM
ser_altima's Avatar
dumb question i know.. what is the charge side? differences? I feel dumb lol
Old Dec 22, 2008 | 12:10 AM
kzoosho's Avatar
The charged side would be the side that leads to the tb. No pre blower or uncharged side is before the blower inlet. I along with others choose to place maf on the charged side to know exactly what is going into my motor. IMHO its easier to tune.
Old Dec 22, 2008 | 12:18 AM
AceofSpds's Avatar
wat
Its easier to tune and wont run rich between shifts if you have a bov venting to the atmosphere but there is no guarantee on how long the maf will last. N62 MAFs (z32/q45) can handle it but from what ive seen on zilvia they dont seem to last in the long term. Of course depending on your power levels also.
Old Dec 22, 2008 | 01:06 PM
ser_altima's Avatar
Well looks like ill be picking up a Z32 MAF then. Shouldnt be a prob I have several buddies with them and tons of parts!
Old Dec 22, 2008 | 09:56 PM
accordingtou's Avatar
VQ30 DE T
Whats the difference between the q45 & the z32 maf?
Old Dec 23, 2008 | 01:17 AM
AceofSpds's Avatar
wat
Depends on the year of q45, But they have a bigger housing. They are also harder to tune with b/c they are so linear at idle.
Q45 is 90mm
Z32 is 80mm
Z32 can run more power although it is smaller, it has a different voltage curve than the q45's.
Old Dec 23, 2008 | 07:51 AM
DanNY's Avatar
Ad·min·is·tra·tor
i thought the MAFs will die faster if it's on the charge side.
any truth to that?
Old Dec 23, 2008 | 04:08 PM
AceofSpds's Avatar
wat
any truth to that?
yes
Old Dec 23, 2008 | 04:55 PM
kzoosho's Avatar
I know i had to do all kinds of funky stuff to get my q45 maf to work.
Old Dec 23, 2008 | 05:24 PM
ser_altima's Avatar
I am just going to stick with the Z32 MAF
Old Dec 23, 2008 | 07:43 PM
maxgtr2000's Avatar
any truth to that?
With the availability of the a32 maf being stock and no one really caring for it, it seems easier to find and replace it. I think the way the car is driven is a factor whether it will go out quickly on the charged side or not. If you are tracking the car and are going to be seeing alot of boost, might as well get the z32. I still have a full volt to play with even when I've been boosting it.
TallTom
57
Oct 14, 2025 05:16 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
ballerchris510
Sep 10, 2015 09:35 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
