guage Q's
Old Feb 27, 2009 | 08:47 AM
GOBBO's Avatar
guage Q's
i dont want a million guages in my car, but i want to know what one's i will need to watch for possible problems. i already have boost and oil pressure. which other one would you recommend for the 3 spot in the pillar.
this is for a s/c set up
Old Feb 27, 2009 | 09:01 AM
kzoosho's Avatar
oil temp
Old Feb 27, 2009 | 09:47 AM
GOBBO's Avatar
thankx
ok, oil temp it is, than you
Old Feb 27, 2009 | 12:10 PM
ser_altima's Avatar
What about your Wideband THE MOST IMPORTANT ONE?????? Holy Jesus mother of God you need that one to tune your car bro
Old Feb 27, 2009 | 03:14 PM
PharoNDmist's Avatar
wideband
Old Feb 27, 2009 | 03:32 PM
GOBBO's Avatar
wide band
yeh, i got the innovate lc-1.sorry should of stated that.
i just wanted to know what other ones are important to have to lookout for something going wrong.
what brand do you guys recommend. how are the glowshift guages?
Old Feb 27, 2009 | 04:08 PM
The Cuban's Avatar
you can't go wrong with autometer gauges.
Old Feb 27, 2009 | 04:28 PM
GOBBO's Avatar
guage q
i was looking at the series 7 elite. do they stay lit up even if your lights are not turned on? are they easy to see on a sunny day, as far as glare?
Old Feb 27, 2009 | 04:38 PM
The Cuban's Avatar
Depends where you tap for it's power source. If you tap into your cigarette lighter (for example), they'll be on all the time. Tap into the light ring around the cigarette lighter that turns on when your headlights are on, and you'll have it on only at night ect. (I can't remember if the ring is only on with the headlights, i'm just giving you an example)
Old Feb 27, 2009 | 06:12 PM
GOBBO's Avatar
pod pillar?
what company makes the best 52mm form fitting pillar for a 99.
i dont really like the idea of screwing a pillar on through the face of the pillar.
Old Mar 1, 2009 | 06:38 AM
wirelessdude04's Avatar
I think paradox makes them or try ebay.. But yea do oil temp espeically since you have a sc
Old Mar 3, 2009 | 12:49 PM
ptatohed's Avatar
Licensed to Spell
Dual intake temperature.
Old Mar 3, 2009 | 03:17 PM
Worthless.
Old Mar 3, 2009 | 07:40 PM
Flava_24/7's Avatar
Boosted Panda
So no one cares about monitoring their fuel pressure?
Old Mar 3, 2009 | 09:45 PM
With the properly sized injectors and a good fuel pump (and assuming one has a half way decent tune...), there's really no need IMO. Stock/undersized injectors on the other hand, sure, it would be beneficial to know.
Old Mar 3, 2009 | 10:50 PM
96blkonblkse's Avatar
Id rather monitor EGT.
Right now i have Boost, EGT, and Oil Pressure. If i can find anywhere else to mount more gauges without looking like a ricer or having them totally out of place. Water temp and Oil temp would be nice.
I am using Prosport gauges. They are very nice. Blacked out when they are off, illuminate blue when there on, they also have the opening ceremony thing too. Knock off Defi's basically.
Old Mar 3, 2009 | 11:40 PM
ptatohed's Avatar
Licensed to Spell
Who cares about EGT for an SC'ed application?
P.S. You might want to change that bolt to a screw.
Old Mar 4, 2009 | 06:17 AM
Flava_24/7's Avatar
Boosted Panda
Very true, unless for some reason FP drops or its limited which by monitoring youd know you right away you have a problem.
Old Mar 4, 2009 | 06:21 AM
Flava_24/7's Avatar
Boosted Panda
WB is much more usefull over the EGT, although if you dont have a WB and have no way of tuning an EGT gauge will work.
Old Mar 4, 2009 | 11:56 PM
Very true, but both is better! Me and my friend went halfs on a wideband, so we keep it till the other one needs it. When i dont have it in, i just use my EGT as reference. You can never be too safe!
Old Mar 5, 2009 | 12:00 AM
AceofSpds's Avatar
wat
Good idea, me and a friend are thinking about doing the same with an LM2.
Personally I like to have as many things i can monitor at once, just with the least amount of instruments. IE something like a PLX R500, which is discontinued .
Old Mar 7, 2009 | 03:33 PM
SleepyMax1's Avatar
I recently purchased a maxima with a 3.5 swap. The main build of this car is to run at the racetrack, not really for street. It will be street legal, but the build is for drag purposes. I've been thinking of replacing the top two dins for triple gauge din for each din (leaving me with 6 gauge pockets to fill)
The car is automatic:
Are the following Important?
Trans Temp
Oil Pressure
Fuel Pressure
LC-1
Nitrous (might move it towards the cup holder)
Oil Temp
Anything I'm missing, I'm trying to draw attention to the car (hence no triple gauge pod on the pillar), I think I've covered the more important gauges vs. the typical a/f and the pyrometer. Should I include the water temp gauge??
Cotozic
Jun 28, 2017 08:01 PM
rnb754
Sep 14, 2015 11:39 PM
95Maxi
Aug 25, 2015 08:01 PM
