Finally boosted!!!!
Old May 29, 2009 | 07:25 PM
  #41
JAMAICANLOVRBOY's Avatar
[QUOTE=The Wizard;7053360]
Originally Posted by JAMAICANLOVRBOY
Maybe I missed this, but what are you tuning with??
Race gas won't blow your motor....
With safc2 but I was being sarcastic about the blow up engine part
Old May 29, 2009 | 07:36 PM
  #42
[QUOTE=The Wizard;7053357]Why did you route the oil feed line the way you did?
Call up K&N, tell them the specs of your setup, and they will tell you how much CFM you need for a filter.[/Q
instead of using a T fitting and getting oil from the back of the motor, i got a greddy oil filter adapter which has 2 spots i can use, so in the furture if i wanted to hook up a oil temp sensor. because my aftermarket oil pressure sender unit is so big, it would not fit in the T fitting so i left it screwed in the OEM oil presure spot. kinda hard to explain unless you saw it...so will this filter be restrictive?.
Old May 29, 2009 | 07:40 PM
  #43
Originally Posted by kingpin2006
Look good, I just saw your video on youtube. What kind of BOV is that?
Where did you mount the FPR and AUX pump?
blitz BOV, no FPR, thats not mounted yet, hence the reason i havent gotten any dyno numbers yet. its my only car and i can only use the shop on wknds, so i get as much done as possible. thats going in this wknd, then imma try to get a steering column single gauge pod for the boost gauge.
Old May 29, 2009 | 07:42 PM
  #44
Originally Posted by ghostmax301
i have not approved therefore it does not exist until i receive my complimentary joyride
congrats!
lol, ight man. thanks though. when it gets tuned and i can really get on it, ill get up wit ya, right now i have to kinda baby it until it gets tuned
Old May 31, 2009 | 07:08 AM
  #45
PharoNDmist's Avatar
Nice work.
Old May 31, 2009 | 09:25 AM
  #46
thanks....a shot of the boost gauge, thought this would be a nice place to mount it, definately cant look at it while driving though...got the everything hooked up, but the damn dyno machine brokee, so i cant get it tuned until its fixed, but my next step is to invest in a wideband A/F so it can get tuned on the rd, right now its running rich so its not to its full potential yet
Old May 31, 2009 | 03:08 PM
  #47
BkGreen97's Avatar
remove the spliff tray lol. and get defi gauges ftw whenever possible.
defi.com iirc
Old May 31, 2009 | 03:17 PM
  #48
defi.com iirc
LOL@spliff tray. Defi has some good gauges, but d@mn they pricey. only gauge i need now is a wideband which im working on. i have a piece of plastic which will replace the tray so i can put the wideband there. Plus i got that boost gauge for free, cant beat that
Old May 31, 2009 | 04:02 PM
  #49
maxgtr2000's Avatar
KH3 by popular demand
I would put boost and afr on a dual gauge pod on the a pillar or steering column because you need to be able to glance at those quickly. Oil pressure or oil temp should go where you have the boost gauge right now.
Old May 31, 2009 | 05:29 PM
  #50
hmmm, good point. well when i get the wideband, i will repace the other A/F gauge on the pillar.
Old Jun 1, 2009 | 10:07 AM
  #51
wirelessdude04's Avatar
yea boost and wideband in your sight so u can quickly glance at it4
Old Jun 1, 2009 | 04:46 PM
  #52
[quote=JAMAICANLOVRBOY;7054315]
It very well could be restrictive. What size oil feed line are you using? I hope it's at least the same size oil feed line that Stillen had intended. Typically the oil filter sandwhich adapters are very small ports, and only intended for gauges to get readings from, not to feed main components.
Old Jun 1, 2009 | 08:23 PM
  #53
[QUOTE=The Wizard;7057941]
I used the one that came with the kit. The adapter hole looked the same as the t fitting provided by Stillen, I just didn't want to take oil sender out
Old Jun 2, 2009 | 09:02 AM
  #54
datdude20's Avatar
Ooooooooooooo.....nice mang.....
doesnt get my approval til u SEE ME!!!!!!!
POW IN DE FACE!!!!! (african accent)
Old Jun 2, 2009 | 09:37 AM
  #55
Ight sounds like a plan
Old Jun 2, 2009 | 04:11 PM
  #56
ok. good. I hope that works out for ya. Just making sure you don't have any reducers or anything inline to impede the flow...
Old Jun 2, 2009 | 05:04 PM
  #57
Is it normal for the S/C pipes to be really warm?
Old Jun 2, 2009 | 05:17 PM
  #58
Most definitely. Boost is hot!
Old Jun 2, 2009 | 07:48 PM
  #59
oh ok, well all i need now is to tune this bad boy, it pulls so nice though. plus i need to know how much power its puttin down
Old Jun 2, 2009 | 07:50 PM
  #60
So what are your initial Boost impressions?!? Is it enough power for your needs?
Old Jun 3, 2009 | 06:20 AM
  #61
yea sir, its enough for what i do which is just driving to and from work. could i use more later on down the line, yes indeed. but i cant help to think i still havent peaked out what i have yet since it aint tuned. but when i first stabbed the gas and saw the boost gauge go to almost 10 psi, i was like "aahhhh, so this is what a S/C max feels like"
Old Jun 3, 2009 | 06:56 PM
  #62
BigFonsz's Avatar
No intercooler? Wrap the pipes is they get to hot.
Old Jun 3, 2009 | 07:51 PM
  #63
nope, will wrapping the pipes keep it cooler?
Old Jun 3, 2009 | 08:54 PM
  #64
perkman87's Avatar
Originally Posted by Max0224
Why dont you have any clamps on those silicone hoses between the pipes and MAF and the pipe and the TB.
Max0224 your sig is sooooo amazing!
lol sorry
Old Jun 4, 2009 | 07:47 PM
  #65
repositioned my boost gauge
Old Jun 5, 2009 | 01:24 PM
  #66
BigFonsz's Avatar
Yes sir. Damn no intercooler the IAT are not going to be happy when the fun starts to kick in.
I think you should look for some kind of intercooler. Wrapping with pipes will keep temps under control but u still need to add some intercooler.
Old Jun 5, 2009 | 01:39 PM
  #67
BigFonsz's Avatar
www.cardomain.com/ride/763858
this intercooler might work.
Old Jun 12, 2009 | 05:01 PM
  #68
I have a question, is the 3.33 pulley 9, or 10 psi?. My boost guage reaches 10 but I read on here where it's suppose to be 9, and also how would know what trim my blower is?
Old Jun 12, 2009 | 08:11 PM
  #69
Flava_24/7's Avatar
Boosted Panda
The blower should have a serial number, call Vortech and give that to them
I had a 3.0 pulley and made 10lbs with it, Im using a V1 blower which makes a bit less then the V2 so I would imagine the 3.33 on a V2 could hit the 10psi mark at redline.
Old Jun 12, 2009 | 08:15 PM
  #70
Oh ok thanks
Old Jun 21, 2009 | 05:48 PM
  #71
a little drive by video
http://www.youtube.com/watch?v=rUDPmeDroIE
Old Jun 21, 2009 | 06:31 PM
  #72
Macof2003's Avatar
SWEET......
Old Jun 21, 2009 | 08:12 PM
  #73
Originally Posted by Macof2003
SWEET......
thanks
Old Jun 24, 2009 | 10:20 AM
  #74
just got the car dynoed, made 293whp/248wtq. My friend said cuz I'm still using a stock cat, and can't rev past 6500rpm, is the reason I didn't break the 300whp mark. So needless to say test pipe going on soon, then umma be in the market for an e-manage ultimate to raise the rev to 7100rpm
Old Jun 24, 2009 | 10:34 AM
  #75
Kevlo911's Avatar
Kevlo for President
If you raise the rev limit you might overrev the blower
Do you have the graph? We can see where you are maxing out power...
Old Jun 24, 2009 | 12:34 PM
  #76
good point I didn't think of that. I'll get him to print me a copy of the run file and post it. But at 6500rpm the thing was still making power so that's y it seem like a good idea but I don't want to blow it up
Old Jun 24, 2009 | 02:36 PM
  #77
Flava_24/7's Avatar
Boosted Panda
With a SCer it will continue to build power up to whatever your rev limiter is set to, with fuel of course. But that doesnt mean its good for the blower or motor.
Old Jun 29, 2009 | 10:12 AM
  #78
i was trying to get the graph, but my friend is gonna dyno it again. while i was gettin dynoed, the wideband we clamped on the tailpipe with a vise grip fell off and got damaged, so my AF is all over the place on the graph. he says its still rich, but we waiting on another sensor to get the fuel right. im not gonna guess tune this thing.
Old Jul 1, 2009 | 01:18 PM
  #79
cardana24's Avatar
Blown
Hey man, I saw your set up at Maxus and I wanted to ask you, why do you have two blow off valves on your charge pipe?
Old Jul 2, 2009 | 06:14 AM
  #80
Tippy Toes's Avatar
I got this
instead of pshhhhhh its
PSHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH HHHHHHHHHHHHHHHHHH
