dynod the frontyard boostkit
well, i turboed my car, heres what i have:
DEK
255lph pump
z32 tt fuel filter
00VI tie open
PFTB
fidanza flywheel
blitz ss bov
deltagate 38mm wg 8psi spring
3" intercooler piping
27x11x3 FMIC 3in 3out
foward feed
3" downpipe-back
innovate LC1
forge motorsports MBC
to4b h trim .58hot/.70 cold
290cc stock injectors
255/35/18 on 18x8 up front
245/40/18 on 18x8.5 rears
3rd gear pull
374hp/360lbft-tq 9psi
http://www.youtube.com/user/mdghost#p/u/0/8ZF-v6XIjDQ
DEK
255lph pump
z32 tt fuel filter
00VI tie open
PFTB
fidanza flywheel
blitz ss bov
foward feed
3" downpipe-back
innovate LC1
3rd gear pull
omg u are going to blow the hell out of that motor if u dont get some decent injectors.
lol, well here's the fun part... i was enjoying it for about 4days like that before i found out it was that lean.. i had NO idea i was making that much power so didnt think they were maxed out. Got 440ccs in now and the car is between 10.5-11.0 WOT.. too rich now. i want around a 11.8-12.0.
Any who it keeps breaking up around 3500-5000 then clears up and burns thru 3rd and half of 4th gear.. was on the way home...cruising.. got onto a little bit...... MBC=FAIL, no tune=FAIL, oil leaking past cylinder 3 spark plug gourmet=FAIL.. eased on it in 3rd.. built up to about 6-7psi..coupler blows off..i hear a noise......connecting rod is doing a cha-cha-slide in my motor.....
im going with a EBC next.. my boost creeps TOOO much now with the MBC. i have the MBC alllll the way down. and the load screw 2turns from completely out of my WG and it still creeped to about 12-14psi... i guess the injectors helped with that or something.. Anywho. motor is under warranty.. should have the other DEK in by weds. then itll get a TUNE before my foot even touches the pedal.lol
i figure the car was between 400-440whp @ about 12-14psi before she pooped on the stock DEK
my words of wisdom.. EBC>MBC ..... too rich=FAIL as much as too lean.. TUNE is the key..
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
ahh, dont worry, i actually laughed when it blew.. its been a few motors since i was upset when it blew.. i get angry at broken trannys now.. the only part ill dislike is the weather outside it suppppper cold.. but atleast i can wrap the feedpipe now and fab up some solid motor mounts..
+1 on the tuning but ill admit when i was wrong and will say, i just couldnt resist it.. it feels soooooo good.. i mean loosing track in 4th with 255.35.18s up front is amazing..when i dynod at the supra meet.. the BPUs were like
lol
but now that i got my itch for boost out the way.. i can hold off for a tune
lolbut now that i got my itch for boost out the way.. i can hold off for a tune
That motor blew faster than I thought. Sorry to hear about it but you need to learn more about tuning and how to treat a turbo car. Don't take my tone as getting on you, I'm not. Most people run a 38mm wg but if you get on it alot you might want to go with a bigger one. A smaller wg actually helps boost creep because it is not bleeding off the exhaust fast enough. Were you in 5th gear when it blew? I know on the 350z site some of the engines blew when they hit 5th-6th gear. I try not to maintain much boost in 5th gear, but I'm not a track man, just daily driving. You can still get boost creep with an ebc because they can malfunction, I noticed the quicker you get on the gas the quicker the spike, so I don't stomp it like a mad man, especially untuned.
it blew off in 3rd though.. but i noticed at about 75-80mph in 4th or 5th.. if i dont ease into it, and just got WOT, it creeps and blow couplers.lol
but with the EBC, i plan to set it about 2-3psi lower then i want so if it spikes, it wont rape the motor again. i also do slow shifts now
now i have power and boost, no need for fast shifting. so i baby the throttle cracks but just need the tune.
no offense taken.. i know how important a tune is and how to treat a turbo car..just had to try it..been waiting on boost for 3years.lol.. motors are just a dime a dozen to me. The statement about going to a bigger WG ill consider though. i do play from time to time. and still am learning little but little about cfm's, and important ish that i never would give .2cents about when i was N/A.
if i have some good days at work, ill have it in 2-3days from now.. i dont have air or a lift.. just a gravel driveway, floor jack and hand tools but.. ill try to get it in and tuned so i can come with a few other locals to the NC track meet sunday and MAYBE run.lol iv still got to try out the new 2step module i got..check it out. was about $118, google N2MBperformance and its called a WOT BOX
Good luck getting it together in time, the track meet Sunday should be the biggest maxima track meet since maxus!
It depends on what turbocharger you're making that 10psi with, more than the actual pressure. What killed this engine was lack of fuel. I'd also guess he could use some way to control timing before it starts getting warm out again as well.
I bet you'd see huge benefits most of the year with water/meth injection. Set it up to only spray under boost and keep the tank topped off and you will be much less likely to detonate. Just throwing ideas for later!
Vq35 and vq30 is the difference. More than likely it's always tuning but even still it seems like vq35s are more picky than the 30. They seem to blow left and right on the 350z forums. It's rare for a vq30 to blow.
My max is a auto to 5-speed and it has the clutch button, cruise, etc
