Turbo Setup Pictures
Currently having a few problems, and not everything and a few more installations to be made but vids and more pics will be up soon...
Feel Free To Comment, The Good and The Bad... All you turbo guys check ur inboxes soon.. lol
Looking good. Almost looks like my set up the way the turbo is facing. If you have money to invest in a turbo blanket, get one because it is close to the maf and heat is probably what's killing it. If you can't go with the blanket at least use some hi temp heat spray on the turbo. Is that tube on the left of the intake blocked off? If not it needs to be. Also put a filter on the valve cover thing sticking out.
^ thanks... Currently I just got a maf sensor circuit malfunction code... dont know if maybe i wired it up incorrectly? or if I need to put a different setting on the apexi neo... but the car wont go past 3k...
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
Also, check your MAF cable. That could be close enough to melt.
if i go through maf's as i was told i would with it being on the charged side, im going to move it...
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
Recommended because its one piece not a piece welded to another piece... if u know what i mean...
No i ran the same hose from the crankcase, its just not pictured..
Vac canister is under there yea, but mevi not fully connected yet... sorting out my boosting problems first... Thanks in advance man, Mevi is perfect..
You may not want to boost/pressurize the crankcase. Just put a breather filter ,or a catch can on the crankcase connection and seal off the tube on the intake. Putting boost pressure into the crankcase may cause idling and other issues with the pcv valve.
+1 on the above.
looks very clean, but you need to do some heat management or you are going to be melting the **** out of a bunch of stuff.
Did you cut some of the front motor mount away? Any pics of the piping from under the car?
Can't find some pics, but these were during the fab processs. Yes the mount was cut and reinforced. All pipes were sanded, primed, painted, and wrapped..
litch
123
01-04-2024 07:01 PM
04-16-2020 05:15 AM
bigfrank
10-01-2015 12:51 PM
