Blitz BOV wont vent at idle
Old Feb 22, 2010 | 03:37 PM
brasso's Avatar
I adjusted it until the threaded post was almost all the way out and it still wont vent at idle. when i'm driving I can hear it going off so it is working in that sense. Not sure if this matters or will help you but my boost gauge at idle reads 19 on the vac side.
Thanks in advance.
Matt
Old Feb 23, 2010 | 02:38 PM
Keem's Avatar
I think i can help.... the same thing happen to be.... every time i would drive my car i would only reach 2-3 pounds.... and my BOV was leaking from the base..... try some soapy water in a spray bottle and spray around and check for bubbles.... i hope helped....
Old Feb 23, 2010 | 04:09 PM
brasso's Avatar
Thanks i will take a look and see if it's leaking!
Old Feb 23, 2010 | 08:52 PM
brasso's Avatar
So The BOV isn't leaking. I played with the screw some more still wont vent at idle but it doesn't take much throttle to get it to blow off a little bit. when i pulled the adjustment screw all the way out it was sucking air in through the hole. Is that normal?
This may be a stupid question but i will ask any way. Is there any thing a shop would have done other then adjust the BOV to stop the car from stalling out? When i first got the supercharger the car would stall when i was slowing down to a stop. So i took it to the shop that installed it so they could fix it and when i got it back the car wouldn't stall. would they have done something to affect the BOV not to vent at idle?
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
