Turbo upgrade HX40 6-Blade (from the HX35)
What are you referring too? the pressure loss? Its not longer an issues. it was the gauge that was faulty. I only have 3psi pressure loss which is normal.
no dyno yet, one day, might go to the track first.
Is your build done yet? we should check out each others cars one day. I get bored being the only built max around here.
Where in miami do you stay at
i stay in hialeah gardens like 5 min from countyline track...lmk when ur goin to the track
yea but ive been having nothin but bad luck, blew my headgaskets about a month after the build due to bad tunin (cometic with arp studs) then like 2 months after that i destroyed 3rd gear on the highway headin to work . theres no point in having a built motor without building the tranny so im actually thinkin about put a stock motor bak in n call it a day lol ...
i got lucky n found an i30t lsd 5 speed but i dont plan on spendin anymore money for a while im startin to part out a few things n soon the motor is coming out. money is the motive lol cant afford to keep breaking things i need a reliable daily
litch
123
Jan 4, 2024 07:01 PM
