Z32 MAF leak (anyone else?)
Old Apr 16, 2010 | 12:45 PM
streetzlegend's Avatar
So since I am getting 6psi pressure drop I did a boost leak test today, hooking up a compressor to my charge pipe and blocking off the ends.
I found leaking from my meth injection nozzles (fixed).
But also the Z32 maf was leaking, about a year ago I had fixed this leak, basically the top part of the maf (the square part) seperated from the rest of the body, so I put QuikSteel all over. Now I discovered that it cracked the QuikSteel all around, along the edge, I dont know if i should try a stronge epoxy or what but this sucks.
Old Apr 16, 2010 | 02:40 PM
ObsidianIce69's Avatar
Avoid the quicksteel. Zip ties and silicon are your best bet. Epoxy would work a well, but no quicksteel.
Old Apr 16, 2010 | 03:44 PM
Yeah the quicksteel is just to brittle. I bought epoxy for plastic, took some pictures of how it looks when you take off the lid if anyone is curious:
I might still put zip ties on it.
Old Apr 16, 2010 | 04:26 PM
niceguy's Avatar
I had to take apart the MAF cover on my '93 Altima earlier this year (very similar other than flow rate) to check the lead contacts and all they used (tough to get separated!) was black RTV it looked like. I had some clear silicone laying around so I went with that. I don't think you'll have any troubles with it...
Any higher temp RTV would be great due to underhood temps but with the MAF being where it is, I don't think even regular silicone will break down from heat...
Jeremy
Old Apr 16, 2010 | 08:10 PM
Thanx for the heads up, I am hoping the epoxy I used will work, I also put two zipties around it. If it dosnt work again, i might have to get another maf or do something else. I am going to be pushing 15-20psi through this thing.
Old Apr 16, 2010 | 11:29 PM
NiZMo1o1's Avatar
maybe its time to go with a MAP sensor and barometric /air-temp
eliminate the MAF all toghter ?
Old Aug 15, 2010 | 01:08 PM
t6378tp's Avatar
Turbo 3.5
I am having the same problem any updates on how the epoxy is holding up.
Old Aug 21, 2010 | 07:38 AM
maxprivate's Avatar
Black Lion
Where the MAF's purchased new or used? Curious to see why they are leaking from there.
Old Aug 21, 2010 | 08:11 AM
t6378tp's Avatar
Turbo 3.5
used
Old Aug 21, 2010 | 08:28 AM
Kevlo911's Avatar
Kevlo for President
Oh, streetz maf still leaked after trying to fix it.
I dunno if anyone has bought one new, I think they are like 300-400 bucks
Old Aug 21, 2010 | 11:01 AM
maxprivate's Avatar
Black Lion
That is a lot. Know I see why most get them used. Well you can always buy another used one if you can't fix it.
Old Aug 21, 2010 | 11:26 AM
t6378tp's Avatar
Turbo 3.5
rtv and zipties have been working so far
Old Aug 22, 2010 | 07:12 AM
After using the plastic epoxy, it hasnt leaked so far.
TallTom
57
Oct 14, 2025 05:16 PM
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
-ReLLiK-
Apr 29, 2016 06:25 PM
BkGreen97
Apr 2, 2016 05:47 AM
