utec vs. emanage blue for 5.5 gen vs . haltech
Old Apr 17, 2010 | 12:17 PM
gsxrboy125's Avatar
wats upi have a couple of questions i planned to be boosted "turbo" by the middle of may.... i have been researching on the utec but i can t really find any info related to installing this in my 5.5 gen im assuming i am suppose to buy the 350z utec computer. Has any body ever did this install before???? i here its hard ....i kinda want to go with the emanage blue but i here utec offers so much.. i plan on running 8 lbs on my stock motor im using a t3/t4 turbo from garrett also what kind of wide band should i get is the aem uego and good .
Old Apr 17, 2010 | 03:58 PM
rroderiques77's Avatar
Demodded and Forgotten
Let the flaming begin..
If you can afford a Haltech, get one.
I have an Innovate wideband and I really like. If you want to log RPM, then don't get that one.
There are tons of threads on this.
Old Apr 17, 2010 | 04:49 PM
NiZMo1o1's Avatar
over kill on the Haltech...
greddy or the UTEC is decent for your needs but you need to splice them or build a harness ( I belive theres a harness for the greddy? )
Old Apr 17, 2010 | 06:14 PM
gsxrboy125's Avatar
Which Greddy should I get also doesn't it require more than 1 harness for it ..... If I get the utec do I need anything else besides a wideband 2 tune
Old Apr 17, 2010 | 07:50 PM
Gemner's Avatar
you need a wideband to tune for both of them. The greddy would be a cheaper and easier route, the UTEC has a couple more options. for both you would have to splice all the wires. I suggest you make a patch harness using old ECU and harness connectors so that you can take it out whenever you have to
Old May 18, 2010 | 10:21 AM
Deckdout2's Avatar
Play with my balls
Done.
http://forums.maxima.org/all-motor/570679-utec.html
Old May 18, 2010 | 04:52 PM
gsxrboy125's Avatar
Was it a pain 2 wire up I'm really thinking about goin with u tec
Old May 18, 2010 | 06:05 PM
Deckdout2's Avatar
Play with my balls
Honestly, I didn't do the wiring myself so no it wasn't a pain. ha
SurraTT did it for me while I was there. I was just lazy, and he knew what he was doing. It's not hard as long as you use the correct pinouts when soldiering.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Wareagle92
Sep 3, 2015 07:18 PM
