Soaked Plugs
Old May 27, 2010 | 12:52 PM
matty's Avatar
Soaked Plugs
Never really had a huge starting issue till the other night. Not sure what the issue was didn't turn over the first few cranks, then got worse there-after
I pulled one of the plugs after a bit more cranking and it was soaked. I didn't have time to change out the plugs yet but that will def cause the car NOT to start right?
Like I said, I haven't had an issue like this since I did the EU. Hopefully its not something major and the plugs is the issue
What u guys think
Matt
Old May 27, 2010 | 12:54 PM
streetzlegend's Avatar
How many miles you got on them plugs?
Old May 27, 2010 | 12:59 PM
matty's Avatar
Maybe about 10k on them. Really not sure why the car didn't start the first time I cranked. A little concerning. I'm gonna try to crank it later..if no go, then I'm gonna change out the plugs. I really know if a plug is soaked, will the car start
Old May 27, 2010 | 01:10 PM
Dont think the car will start with soaked plugs. Have you done anything different recently? before turning off the car the last time
Old May 27, 2010 | 01:26 PM
matty's Avatar
Well some days it will act weird if I start it cold and turn it off right without warming It up. I did that and its been sitting for over two weeks since I've been on vacation.
I think the plugs were on their way out
Old May 27, 2010 | 03:00 PM
Stillen Maxima's Avatar
Pay to Play
I would suggest change the plugs. Could be that they are done already.
Old May 27, 2010 | 05:50 PM
t6378tp's Avatar
Turbo 3.5
Changing or cleaning the plugs may help short term but you will have this problem again. Sounds like the car is dumping a crap load of fuel upon start, you need to figure out what is causing that problem
Maybe a injector is leaking, sticking or your fpr is taking a crap and leaking fuel pass the diaphram
Old May 27, 2010 | 06:50 PM
matty's Avatar
To be honest with you, the car has been running really good lately. Only really noticed a starting problem the last few times I started my car...then I parked it and got home from vacation and this. It may just be that the plugs are old, time wise. Mileage they arent really old but I dont really drive the car that much.
I let the car sit for 24 hours and tried turning it over. It just cranks and cranks with not even a lick of spark. Will be chaning the plugs tomorrow and see if that fixes it. No idea what else it could be. I havent even messed with anything in a while
-matt
Old May 27, 2010 | 07:43 PM
matty's Avatar
Just pulled all the plugs....they are clean but were all wet. Has to be the issue.
I think these have been in my car longer since I wanted to change them before I moved and that was about a year and a half ago. Gotta be more then 10k miles
Old May 27, 2010 | 07:52 PM
matty's Avatar
Well the injectors were new from Deachwerks when I got them. The FPR is definetly a possibility considering it is old, and I wasnt really sure of the condition when I first bought it. Could they be rebuilt, or do I need a new one?? What are the symptoms of a bad one ??
Old Jul 11, 2010 | 03:18 PM
matty's Avatar
Well I changed the plugs, no go
Just cranks and cranks and doesnt turn over. I dont wanna crank too much cause I dont wanna ruin this set of plugs. Ive never had this issue before....
What are the symptoms of a bad FPR ?? What else could it be ??
-matt
Old Jul 11, 2010 | 03:52 PM
t6378tp's Avatar
Turbo 3.5
Told changing the plugs would only be a temp fix
Old Jul 11, 2010 | 04:03 PM
matty's Avatar
It wasnt a fix at all
Old Jul 11, 2010 | 05:18 PM
t6378tp's Avatar
Turbo 3.5
try checking to see if the fuel psi is holding correctly and your fuel psi when the key is at the on position. Also pull the vac line off the afpr and see if there is any fuel leaking out
Then I would double check your injector plugs and connections, start the car get a scope or screwdriver and listen to them
Old Jul 11, 2010 | 05:46 PM
Kevlo911's Avatar
Kevlo for President
We fixed it I think, he went for drive but didn't report back
Old Jul 11, 2010 | 06:14 PM
euromaxima's Avatar
what was the problem?
Old Jul 11, 2010 | 07:47 PM
Kevlo911's Avatar
Kevlo for President
Crank sensors dirty.
On a side note, you changed your front end again? Painting entire car grey?
Old Jul 11, 2010 | 08:56 PM
matty's Avatar
Reporting back....dirty sensor that was getting bad and finally didnt let the car turn over
thanks for all your help
Old Jul 11, 2010 | 09:32 PM
euromaxima's Avatar
yeah I had ionicdynamics do the fenders and bumper wrapped in carbonfiber...guess the pic I have makes it look grey
Old Jul 14, 2010 | 02:14 PM
venompwr2's Avatar
I was having these same starting issues, I'll check out that sensor as well. However, I am having run on issues with the motor as well, runs for a few seconds after the key is off on ocassion so I think there's something else going on.
Old Jul 18, 2010 | 11:54 AM
matty's Avatar
Well I guess it wasnt much of a fix. Went to start it today and same thing, just cranks and cranks and just doesnt wanna turn over.
What should I focus on now ? Could my Walbro be dieing or on its way out ? FPR ?
-matt
Old Jul 18, 2010 | 12:50 PM
matty's Avatar
Well I got it started again after a few things:
1) Took the crank sensor out, and right at the plug, both wires are freyed down to the metal...I repositioned that but its too hard to get a good peice of tape on since its so close to the plug
2) Re-Set the engine light
Started right up.
I guess I need a new harness for that plug (crank sensor)
TKHanson
Nov 24, 2018 01:39 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
