test on my turbo maxima and the result ....
Old Jul 23, 2010 | 02:17 AM
maxam's Avatar
last week I have done the final checks before tuning my turbo 99maxima
and this week i got my car tuned . this mourning I went to do a test and
training for me to shift perfectly .
the result miss shift form 3 to 2 and revving 8700 RPMs
in the 2nd gear with 10PSI on turbonatics turbo
after that the engine stopped by it self, I tried to start it so many times until it started . then later i drove it back to home , when i stopped it wont start again
water coming out from the coolant can and oil coming out from engine vaporation slot
the good thing in this sh t that the engine running but not starting
anyone please help . I want to know if my engine still good or not
Old Jul 23, 2010 | 03:33 AM
t6378tp's Avatar
Turbo 3.5
ouch, even if the engine works I would start looking
Old Jul 23, 2010 | 03:47 AM
maxam's Avatar
looking for ???
Old Jul 23, 2010 | 04:47 AM
321VQ35MAX's Avatar
Originally Posted by maxam
looking for ???
A replacement engine.... I assume. Sorry for your luck. That sucks a**..
Old Jul 23, 2010 | 05:28 AM
maxam's Avatar
nooo no dont say that
I dont want to replace ma engine
I have JWT cams with CP Pistons on it
Im gonna die
I spend two years bulding up my engine I cant let it go like that
Old Jul 23, 2010 | 06:11 AM
maxgtr2000's Avatar
KH3 by popular demand
Blown headgasket maybe? Maybe damaged valve springs too? A compression test is in order.
Old Jul 23, 2010 | 06:18 AM
maxam's Avatar
it's commetic head gaskit . it should be strong right ?
Old Jul 23, 2010 | 08:29 AM
t6378tp's Avatar
Turbo 3.5
Didn't know it was a built motor. Was it built for high rpms. Like stated above time to run some test and go from there.
Old Jul 23, 2010 | 09:03 AM
ajcool2's Avatar
3.5 it.
Old Jul 23, 2010 | 12:44 PM
maxam's Avatar
yeh it should be for high RPMs .
3.5 it ??? and throuh my pistons and cams ????
Old Jul 23, 2010 | 01:05 PM
jjwilliamson's Avatar
new head or new engine bro
Old Jul 23, 2010 | 02:44 PM
maxprivate's Avatar
Black Lion
Thats terrible man, I would have learned to shift perfectly and a garbage car not a turbo charged one. Hope things work out for you.
Old Jul 24, 2010 | 05:44 AM
doublea's Avatar
If water is mixed with oil than it's the head gasket that blowned, the other possible issue is that the block might be cracked but I would put a 2$ on the head gasket. My guess is that if the block was crack something else would have probably blown like a piston or a rod but there would be visible sign. Good luck, and buy a stronger head gasket, and dont shift till red line give yourself a chance to learn how to shift and save your engine specially on a boosted one.
Old Jul 24, 2010 | 05:51 AM
SteveB123's Avatar
Rev limiter (on the next engine) for the win.
Old Jul 24, 2010 | 07:08 AM
maxam's Avatar
ok here are the signs .
1. engine running smooth but not starting
2. water coming out from y pipe and down pipe
3. water smell when I opened the oil cap
I think if it's the block , the engine would not turns smooth .
today I ordered new cometic gaskits on the express mail DHL . I will try to finsh it quickley.
Old Jul 24, 2010 | 07:46 AM
maxam's Avatar
ok if you train your self on stock maxima for example .
http://www.youtube.com/watch?v=NBbfFDZAB6Y
you will shift like this and may be better . this is stock 99 maxima . it is just like a toy . in this max 0-60km in 6 seconds . pu l sh t . 60-150km in 10 seconds ???? . pu l sh t .
but how would you shift like this guy in this crazy maxima ????
http://www.youtube.com/watch?v=97GBvu2g-X8
look how RPMs goes very fast . look how the car pushing you . look how it accelerate
one mistake might kill you or couse a dezaster. here where would you concentrate ? shifting ? trafic ? Crowd ? gauges in your car ? or the car you are racing with ?
today I ordered new cometic gaskits on the express mail DHL . I will try to finish it quickly.
sorry for the bad words ....
Old Jul 24, 2010 | 08:45 AM
SteveB123's Avatar
Perhaps it would be best to NOT drive like a child, and if racing is something you must do, do it at the track.
Old Jul 25, 2010 | 07:12 AM
maxam's Avatar
ok if we dont have a track in Saudi Arabia , where should we go ?
and I DONT DRIVE LIKE A CHILD , BUT I DONT HAVE RACING EXPERIENCE !!
Old Jul 25, 2010 | 07:59 PM
streetzlegend's Avatar
If water is coming out of the engine, stop trying to turn on the car, even if it idles smoothly. Its broken, now your goal is to take it apart and fix it. Cometics HG dosnt mean your safe, even if you have a $500 head gasket, and you over rev while in boost in rpm's that you havent even tuned for, the HG will fail. Take off the heads, inspect for cracks on the block, new gasket, and see if its ok.
Old Jul 26, 2010 | 07:49 AM
maxam's Avatar
did you know that it was running like nothing happend ?
Old Jul 26, 2010 | 08:04 AM
NiZMo1o1's Avatar
drain the oil and check if theres coolant in it , sounds like a blown H/G
pull the spark plugs out to check them , do a compression test and a leak down test ..
Old Jul 27, 2010 | 12:36 PM
maxam's Avatar
I will not touch it until the new HG comes . couse everything is clear . Blown HG , the block is safe , heads need to be checked , all i need is to be patient until the new HG arrive .
Old Jul 27, 2010 | 04:10 PM
Nealoc187's Avatar
SLOW
so you did or did not do anything to diagnose the problem prior to just ordering parts?
Old Jul 28, 2010 | 08:22 AM
maxam's Avatar
no my friend . everything is clear . I opend the oil cap and I found that there is water not even mixed with the oil yet . other thing as i sayed befor I took my car back to home after what happend driving it . it was running like nothing happend .
All this are sings of blowen HG . Am I worng ?
Old Jul 28, 2010 | 08:41 AM
Kevlo911's Avatar
Kevlo for President
You won't know until you take it apart, you might have cracks in the block. You need to check it out, if everything was fine, it never would of acted funny to begin with.
Old Jul 28, 2010 | 08:00 PM
mywhitewolf's Avatar
or AT-LEAST do a compression test on the engine.
Old Sep 20, 2010 | 08:01 AM
maxam's Avatar
hello guys
I took my car to the workshop today as they Scheduled it to start all over .
they started to check it to figur out the problem.
they opened the radiator and fill it with water than they left it open
than they started running the engine . at the frist run the water came out from the radiator like a fountain .
they told me that I have blown HGs .
I told them to check everything on it . crank , block, heads ,and,,,,,,,,,,
but I have Question . is the oil pump still work or should I replace it ? couse it is newly built.
Old Sep 20, 2010 | 01:01 PM
hello guys
Get a Rev up oil pump, which handles higher rpms.
Old Sep 21, 2010 | 07:49 AM
maxam's Avatar
ok where can i find one ?
Old Sep 21, 2010 | 10:53 AM
Nealoc187's Avatar
SLOW
dude use google. you buy it from nissan. it's a stock nissan part.
Old Sep 21, 2010 | 10:54 AM
Contact DaveB on here, or any nissan dealer.
Old Sep 21, 2010 | 01:14 PM
maxam's Avatar
nissan ? you mean the oil pump for nissan Gloria ? the RWD VQ30 ? is it good for higher RPMs ?
Old Sep 21, 2010 | 06:26 PM
OC_Nooby's Avatar
It comes out of a 350z.
Old Sep 22, 2010 | 08:22 AM
Its the oil pump that comes with the Rev Up 350z. Do a search on here and you'll find all the information about it including part number, pictures, etc..
Old Sep 22, 2010 | 05:02 PM
OC_Nooby's Avatar
http://forums.maxima.org/general-max...0-shipped.html
To help a fellow org member...
Old Sep 23, 2010 | 03:43 AM
maxam's Avatar
Originally Posted by OC_Nooby
I'm going for the Z350's one , wich is easier to find .
but i have an other question. what will happen if I use bigger boor size Head gazkit ?
Old Sep 23, 2010 | 04:20 AM
maxam's Avatar
here are some pics
Old Sep 26, 2010 | 09:41 AM
maxam's Avatar
hey bad news
we found that the cylinder need to be replaced . becouse of the piston line ( where the pistons moving ) ware un even. that means the heads will not fit in some places on the cylinder surface . so I am gonna start agine with new good cylinder , taking out my pistons and reface the heads .
Old Sep 26, 2010 | 05:02 PM
t6378tp's Avatar
Turbo 3.5
it didn't cause any damage to the cylinder wall
Old Sep 27, 2010 | 11:13 AM
maxam's Avatar
no the cylinder walls is not damaged at all . but from the beginning the cylinder surfece was not even . and I found that the cranck shaft have some rust on it so I knew that the engine was mixing oil with water from the frist time that I started the engine but I was surprised that I dont have heat problems and i chenged the oil every month and I did not find any bad oil .
but some times I fill in the radiator with almost half a cup of water .
any way Im now searching for good cylinder. I found 3.5 from an altima 05 but I dont think of bueing it .
