V2 with BOV fluttering issues.
Old Sep 3, 2010 | 01:13 PM
OC_Nooby's Avatar
Hey guys,
I have a greddy BOV that comes with 2 springs, had to remove the hardest spring and pretty much adjust the BOV to its lowest setting so it could vent properly. Once I got that going at cruise speeds the BOV will "flutter" like its being sucked in and then held open by the vacuum. Its really annoying to hear it flutter.
So a buddy had a sequential BOV and he claims there isn't a spring in it or what not but again the BOV flutters.
How do you guys manage with a BOV on a supercharged system. I just want it to stay open to vent which it does at idle but when your cruising its annoying...
Maybe the vacuum source I'm giving it is weak? Should I get it from the TB?
Old Sep 3, 2010 | 01:45 PM
Quickywd01's Avatar
Try lubing the bov piston. Mine wouldn't even open and after a little motor oil it worked. Can't help you with the fluttering as I haven't had to deal with that yet.
Old Sep 3, 2010 | 01:51 PM
OC_Nooby's Avatar
It's happening to both BOV's that I tried
Old Sep 3, 2010 | 08:33 PM
Mad-MAX_SE's Avatar
Still kickin'
I have mine T'd off the fuel pressure regulator vacuum source. I'm using a Vortech Maxflo Race on mine and have absolutely no issues whatsoever.
Old Sep 4, 2010 | 08:04 AM
HomerMAC's Avatar
Donating i30 Owner
I was reading KennBell's SC articles online, and they mention the use of BOV is not reccomended.
Essentially a BOV on a turbo flutters(intentionally), as it releases the charged air is steps. Each flutter releases charged air and then closes a bit and then releases the more in the next... "flutter". This way the turbo can keep spinning (somewhat) using the exuast gas. This reduces turbo lag, spool time between say shifts.
a BYPASS used on an SC setup such as the vortech ... and bosch black gheto thing releseases all the air in one shot because the SC is spun by belt and doesnt need the BOV to help maintian the spinning. Also using a BOV is not reccomended casue every "flutter" causes like a "surge" or a "shock" to the SCer.
Some people do use BOVs on SC with success, BUT i think some BOV's release compressed air in one shot and some do it in increments "flutter".
Have you tried the regular bosch one?
OKAY so after reading the OP again.. I realized your not talking about what i mentioned above which pretains to the venting when off throttle.
Your prob most likely is the ref. line. Where are you getting vac. line from? Should it not be post TB?
How much PSI are you pushing? what kind of spring are you using?
Old Sep 4, 2010 | 09:03 AM
OC_Nooby's Avatar
Mine is also T'd off the fuel pressure regulator vacuum source
Old Sep 4, 2010 | 09:59 AM
HomerMAC's Avatar
Donating i30 Owner
have you tried a different brand. or were both the bov you tried the same greddy one.
try the BOSCH one that came with the SC. see if it responds similar or try a dedicated vac. line for the BOV.
I havnt really heard anyone using the greddy. why net the vortech mondo or whatever. Its meant for SC and it will work out better (personal opinion).
Old Sep 4, 2010 | 03:57 PM
OC_Nooby's Avatar
Both BOV are different, I didn't get the stock Bosch one with my kit.
Old Sep 12, 2010 | 09:09 AM
HomerMAC's Avatar
Donating i30 Owner
might sound stupid... BUT... have you tried a new hose for the vac ref. line. Once I had a vac prob and turned out there was abit of silicone in the vac line that was clogging it up. and well the vac. ref. was all out of whack...
Old Sep 12, 2010 | 01:55 PM
Flava_24/7's Avatar
Boosted Panda
On our superchargers, once a certain amount of boost is created and its recommeneded to use a vent to atmosphere (BOV) versus a bypass valve.
If adjusted correctly, there should be little to no compressor surge.
When I had the Tial BOV, which wasnt adjustable I would get a bit of compressor surge while cruising. Now that Im using the Vortech Mondo it is now gone.
Old Sep 17, 2010 | 07:06 PM
HomerMAC's Avatar
Donating i30 Owner
hmm... I truly think the mondo is the best for our use. I hear only good things about them.. hmm worthy future investment
BTW sent you a PM .. just now.. thanks for all your help in the past flava flav..
D Mason
Jun 21, 2016 04:43 AM
BkGreen97
Apr 2, 2016 05:47 AM
leatherneck
Sep 30, 2015 09:16 PM
97_GXE
20
Sep 17, 2015 08:12 PM
